View Poll Results: Bottom Bracket Fixed Cup Removal Schedule
Never
2
3.28%
Only if damaged
27
44.26%
Only if it comes out on the first try
6
9.84%
On a regular basis
26
42.62%
Voters: 61. You may not vote on this poll
Bottom Bracket Fixed Cup Maint/Removal
It is easier to clean the cup and place bearings and grease out of the frame. If it was installed properly once then it can be installed again. Who says the initial installer did a better job than you can?
Likes For Narhay:
Quoted: 4577 Post(s)
Liked 6,565 Times
Does your definition of "proper tools" include the Sheldon Brown nut-washers-and-bolt system?
When I took the 1959 Capo to CyclArt for a repaint, I needed help removing the fixed cup. Jim Cunningham had a bench vise mounted atop a long pole in the middle of a large room, and that was the only way we could garner enough leverage to break it loose.
For an ISO, British, or Swiss-threaded BB, I can justify removing the fixed cup, but how about Italian or French? I find I need to use Loctite to keep those fixed cups "fixed." Is it really advantageous to take these in and out and grease the threads when they inherently have trouble staying tight because of a major (self-loosening) design blunder?
Properly servicing the threads can insure them from becoming a problem.
I have never had any cup come loose that I know of.
Quoted: 2588 Post(s)
Liked 4,829 Times
DD
Liked 6,565 Times
If it wasn't done correctly or is seized, damaged, worn and ignored it will be rectified right then and there.
Likes For merziac:
Liked 6,565 Times
Liked 6,565 Times
Minority now.
Liked 4,829 Times
Oh, I still leave mine in all the time otherwise. Even Sheldon tha God says that way's the bee's knees:
DD
Fixed Cup:
"For normal servicing, only the adjustable (left) cup need be removed. It is a bad idea to remove the fixed (right) cup for a routine cleaning and repacking. The fixed cup should only be removed when it is going to be replaced with another one, as when replacing an entire crankset."DD
Liked 6,565 Times
DD
Fixed Cup:
I get it and in our case you have the experience to make the call, full well knowing the potential pitfalls that may befall you down the road
Respectfully disagree with St. Sheldon on this statement as we all know.
He wasn't afraid of a seized cup so he didn't bother with them, competent shop mentality where production is the priority.
My concern is leading new inexperienced folks down the garden path as happened here in the thread that spun this one off.
I think newbies should learn the correct way before they learn the shortcuts that can be a problem later.
DD
Fixed Cup:
Likes For gearbasher:
Quoted: 2368 Post(s)
Liked 1,763 Times
Likes For madpogue:
Liked 4,829 Times
Does anyone here remove the cups from the head tube, re-grease, and re-install when overhauling their headset?
I get it, I'm not normally one for shortcuts, either, but this one's a no-brainer.
DD
Likes For Drillium Dude:
Liked 6,565 Times
merziac seems to be doing most of the defense on this thread that I started. Much appreciated. I've said this before and caught hell for it. But I'll say it again, there are a number of things on Sheldon's site that I disagree with. This being one of them. Hey, there's even more in the Bible I disagree with and I'll probably catch hell for that. Literally.
I understand the many reasons for the esteemed members here working around this task and fully acknowledge that they can make there own calls on this knowing the consequences if it goes south.
That being said I will reiterate for this, a good defense is the best offense, I take these head on and have never failed to get one out and make sure all is very much right when I get done.
I was a flat rate master auto tech for 20 years, if you didn't do something that should have been done and it came back for anything related to that it usually really sucked to be you.
Now days there are shops where you will be charged back for the repair you attempted and you will be charged back for somebody else to correct your mistake. Maybe a formal reprimand or worse as well, depending on who has it out for you, some get crucified, often when it may not have actually been your fault after laying hands on it.
Should have been more thorough, gone above and beyond, should have known, found it while you were there, etc.
Likes For merziac:
Liked 6,565 Times
It's not a bad shortcut, tho. One can inspect the bearing surfaces on the fixed cup easily enough, and can clean old lube/lay in new with it in place, too. Slide pre-greased bearings (assuming caged) over pre-greased driveside of spindle and insert. Heck, even if I got the bike from somebody else, and servicing without removing showed a clean setup including the fixed cup, I wouldn't be concerned in the slightest if the cup might be seized. Why would I? Because a fixed cup is supposed to be as close to locked in place as possible, a stuck one, in a way, is somewhat of an asset if you aren't planning on a refinish during your time of ownership - and you've ever had one unwind on you 50 miles into a century.
DD
DD
Wouldn't be a bad idea considering how many stuck stems and other HS problems crop up.
Again, you and I make these decisions knowing full well they could suck, we have had our eyes opened wide by many things that prepare us for this sort of thing.
Our big boy pants have had tools in them for a long time.
Likes For merziac:
Quoted: 899 Post(s)
Liked 2,342 Times
Bottom bracket service is just part of the job. It doesn’t need doing very often unless you ride a lot more miles than I ride. I have about a dozen or more bikes that I ride in rotation so now that they have all been done, I’m good for a while. The main bike I ride has a Phil BB so that one is a “get out of jail” card. The last BB fixed cup I removed was at a friends house who also removes the fixed cup for service and he asked if I could help. I said sure , fully expecting to struggle , he took out a very nice tool that has a T handle and two piece screw together driver from both sides of the cup. Man that made it much easier. We still had to steady the stand while he turned the cup free. I usually am by myself so I lay the bike down on a rug and work against my knees tapping the wrench with a brass hammer. Not my favorite job but a heck of a lot better than a stuck stem or seat post!
Likes For Kabuki12:
Liked 1,763 Times
Quoted: 964 Post(s)
Liked 1,453 Times
Wow, this thread really blew up!
I am surprised nobody has yet mentioned the quasi-permanently-installed fixed cups on the old Raleighs, which were commonly painted with the frames. This seems like a manufacturer's vote for leaving the cup in place - and a manufacturer with a reputation for building things to last!
Maybe that's also why Sheldon preferred to leave them. He did love an old Raleigh, and often espoused their way of doing things.
I also wonder if it's down to personal anatomy. I have long fingers and can easily reach through a BB to clean the bearing race on an installed fixed cup. It is not a problem for me. I am confident in my ability to get all the old grease and crud out of there. It occurs to me that others may not be so endowed, and this may change their situation.
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 551 Post(s)
Liked 1,095 Times
Bikes: Yes
Quoted: 3300 Post(s)
Liked 4,088 Times
Here I think you've dug yourself a hole. There's a very good case to be made for taking out the fixed cup when you first acquire a frame. The case for taking it out again when you're the one who installed it and are confident you did it right is, IMHO, weaker. Encouraging inexperienced home mechanics to do a job which might not be necessary and, if it is, might require extraordinary amounts of force just seems like a bad idea. The chances of something bad happening in this case seem much greater than the chances of accomplishing something good. By all means instill the value of doing things the right way, but there are just some things you shouldn't try until you know what you're doing.
My Bikes
My Bikes
Liked 6,565 Times
Your logic is as flawed as mine in the inverse IMO.
What happens if they shortcut, miss a problem and blow up a whole Campy bottom bracket that they still don't know how to get out and may not be able to find or deal with.
As I stated before, I have been a professional senior master auto mechanic most of my life and have trained several new techs. Advocating and teaching shortcutting is a cardinal sin upfront and a disservice to all that are involved. I realize that working on your own things is a different situation but if we send them down the garden path and they get lost, that's on us and not acceptable to me.
We'll have to agree to disagree and having done a lot of this sort of thing for a living, I'm sticking to it.
Likes For merziac:
Happy With My Bikes
Quoted: 888 Post(s)
Liked 2,359 Times
Likes For Chuck M:
Quoted: 1633 Post(s)
Liked 2,257 Times
Its a risk decision. What is the likelihood of a bad assembly of the BB if the bike is C&V, the races look good and the function, when assembled, is smooth without the cranks attached?
What would be the impact of a bad assembly? Is there evidence the risk has turned into an issue?
If it is done right the first time, which may have been several k miles ago, why "fix" what isn't broke?
What is the likelihood of disassembly followed by incorrect installation of the assembly and what are the impacts?
Which has the lower risk score, servicing with or without fixed cup removal?
The biggest impact, IMHO, is damage to the fixed cup and the lock ring during disassembly and installation. Most effective mitigation is to use the right tools designed for the work on the parts.
Bikes: 1964 Huffy Sportsman, 1972 Fuji Newest, 1973 Schwinn Super Sport (3), 1982 Trek 412, 1983 Trek 700, 1989 Miyata 1000LT, 1991 Bianchi Boardwalk, plus others
Quoted: 589 Post(s)
Liked 712 Times
I’m of the leave well enough alone school of thought. I have had to take out some for damage or replacement, and haven’t had to resort to very extreme measures. One even included a 64 Frejus that was uneventful. My trepidation has been in frame damage potential. I believe that I have read here about ruined frames in unskilled attempts at removal. We desire thin tubes and light steel which may flex when ridden. I am somewhat reluctant then to put a 3 foot lever on a BB cup to prove a point when all looks fine from the other side. That force seems like more than was baked into the design. Mystery cracks in BB lugs, etc might be a reward, but probably not, but unnecessary stress could be asking for problems easily avoided. A rare BB failure is different than a ruined vintage frame, and isn’t a terminal outcome.
Likes For sd5782:
Quoted: 3261 Post(s)
Liked 2,583 Times
The best method of removal is:
Cup in shop vise, grab frame and turn it the correct way. If you have the tools, frequently might be the best answer. If you don't, one of the other answers could be the best one.
Quoted: 418 Post(s)
Liked 606 Times
Merziac needs no defending.
Doing the job correctly is the reason I do all of my own work. I've ceased to trust anyone else taking the time or knowing what they're doing.
but that might just be me
