Favorite Tool
Quoted: 4867 Post(s)
Liked 4,024 Times
In my pocket? My early Leatherman, gift from my sis. On (fixed gear) bikes? The Pedros Trixie hub wrench and lockring spanner. (Doesn't slip on bell shaped lockrings for 12 tooth cogs and simply the best for the rest.) On the bike bench? Those brake cable pulling 3rd hands. Work bench? A tie - bench vise - most useful and drill press (Ryobi) along with a vise that can be clamped to the drill press table and located with worm drives. The two are so satisfying to use.
I have a newer Gerber. First time I used the pliers I destroyed them. My Leatherman has done hub nuts without blinking. (Well the nuts blink. They don't like it. Go into a funk and refuse to look anything but scruffy.)
Quoted: 336 Post(s)
Liked 309 Times
I think that the 7" pliers wrench is a great all-arounder for a lot of general mechanical work - and a great starting point for someone who has never used one of these before. I don't use mine a lot on bikes, but my few current bikes don't have a lot of fasteners and fittings that have flats.
For me, the magic with these comes from:
I would recommend thinking about where you might use it (on the types of bikes on which you work, or wherever) and then pick one that is sized appropriately. These have fairly large jaw capacity relative to overall length, so for me, the choice is usually driven by the handle length required for leverage. Smaller sizes have slimmer and more compact jaws that can work in tighter spaces.
- Jaws have smooth faces to engage what one is gripping with minimal damage to part surfaces.
- Jaws remain parallel.
- They have fairly high mechanical advantage when it comes to the motion of the jaw relative to the motion of the handle when closing. So, it's easy to apply significant force at the jaws (and so engage the part firmly, and not mangle the stuff on which one is working).
If I could only have one pair, it would be the 7 inch, because they will work for spline tools and high torque items like pedals as long as you have sufficient hand strength.
Quoted: 3625 Post(s)
Liked 3,047 Times
Except for pulling derailleur cables taut, there is simply no application for a pliers in bike maintenance/repair, Knipex or otherwise. Use the correct tool.
SE Wis
Quoted: 2754 Post(s)
Liked 3,422 Times
Liked 3,047 Times
Liked 4,024 Times
But - there can be times when you not have the proper tool on hand and pliers work. That day I flatted and realized my Trixie was at home (because I'd used it for a lockring because it was better than the flat plate Park spanner for that job). So pliers, spend $25 on a ride or walk 8 miles in cycling shoes. Leading to the sulking and scruffy nuts I mentioned in my first post.
Quoted: 2026 Post(s)
Liked 1,096 Times
In that case, a "Fourth Hand Tool", such as the Hozan, is the correct tool to use. Where needle nose pliers (or hemostats) are the correct tool is to add individual bearing balls to the races of cup-and-cone hubs or headsets. They are a lot more convenient and precise than fingers.
Likes For HillRider:
Liked 3,047 Times
Quoted: 336 Post(s)
Liked 309 Times
Does a vise also have no place in bike maintenance?
Quoted: 4235 Post(s)
Liked 3,957 Times
A bench vise is the best way to hold a freewheel tool while turning the tire/rim to remove the FW. Max leverage (especially if one places their hip against the bench), max control and one can have a friend to grab two more points about the rim to better even out the twisting forces. Is a vise a needed maintenance tool? No but then solvent is also not needed, just use an excess of oil to do the same flushing out of stuff. No repair stand is needed either. No truing stand. No compressor.
While some of the above is with tongue in cheek when I started out at JC Pennys (1973) I had a 6' adjustable wrench and a flat blade screwdriver in my pant pocket pretty much all the time. But soon some bikes were coming with those new fangles hex wrench socket headed fasteners and I had to add a couple of these wrenches to my pockets. And the race to lots of tools began. Andy
AndrewRStewart
AndrewRStewart
Liked 3,047 Times
I never mentioned adjustable wrenches. I was talking about pliers. Generally thought of as toothed tools that often do more harm than good to precision surfaces. And of course vises are useful tools.
Likes For smd4:
Bikes: n, I would like n+1
Quoted: 127 Post(s)
Liked 133 Times
Mind you, nearly all cable cutters have a built in crimping tool. Sadly cable cutters seem surprisingly uncommon among those just starting out.
Bikes: a couple
Quoted: 563 Post(s)
Liked 869 Times
Ideal linesman pliers
Quoted: 336 Post(s)
Liked 309 Times
I agree - toothed pliers do not belong near bicycles. What kind of animal does that?
My vise is probably my second favorite tool. On my bike bench is a “Reedsman” - a 1944 Craftsman branded Reed 203R. Tiny beast. My garage vise is a monster - ca. 1908-1911 Reed 405-1/2.
Likes For aggiegrads:
Liked 3,957 Times
This is why we are arguing. We are talking about pliers-wrenches and you entered the conversation to excoriate toothed pliers. I use the Knipex Pliers-wrench exclusively as an adjustable wrench. It has completely replaced crescent wrenches in all of my toolboxes - bike and general hand tools. They also make surprisingly good small vises for holding small parts that cannot be put in a bench vise.
My vise is probably me second favorite tool. On my bike bench is a “Reedsman” - a 1944 Craftsman branded Reed 203R. Tiny beast. My garage vise is a monster - ca. 1908-1911 Reed 405-1/2.
I also have a Wilton 3" Bullitt model that is coming home soon (had been loaned to the bike shop). It needs some serious refurbishing. If I can do that I'll post when done. Andy
AndrewRStewart
AndrewRStewart
So help me, I even took the time to detail in a post in this thread some of the functional characteristics of the Knipex pliers wrench. I, too, have run into some situations where the fit-up is so poor that a "proper" open end wrench produces terrible results - and a pliers wrench is just the ticket.
When it comes to "gotta have teeth to get the job done", well, the Knipex Cobra pliers are there!
Likes For John Valuk:
Quoted: 1325 Post(s)
Liked 1,967 Times
So now that the plier dust-up has settled a bit, My favorite tool is/ are the battery powered drills and impact drivers on the workbench. I reach for them when removing nuts, bolts, and even freewheels. Small light weight and portable, and they get the job done faster with less chance for broken or damaged parts. JMHO, MH
Quoted: 1848 Post(s)
Liked 1,723 Times
My favourite tool is a small ball peen hammer that was given to me by my father who in turn received it from his father who was a master mechanic
Bikes: '87-ish Pinarello Montello; '89 Nishiki Ariel; '85 Raleigh Wyoming, '16 Wabi Special, '16 Wabi Classic, '14 Kona Cinder Cone, 2023 Surly Disk Trucker
Quoted: 706 Post(s)
Liked 415 Times
My favorite tool is a very old VAR cable cutter. I've had it since I was a mechanic back in the day (early 1970's). After 47+ years it shows no sign of wearing out and still cuts a cable clean and square.
A dental pic. Absolutely strong. Good at extricating dropped chain, at home anyway. I use this around the house as well. Invaluable.
Likes For Freerojo:
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,488 Times
This is the correct answer. Park PH-5 is by far the most used bike tool. PH-6 and PH-4 also get some play
Vintage sounds cool, I have an AWS-1, and I'd like for that to be my #1 favorite do-all tool, but the two arms you're not using too often hit stuff and can't spin freely (like trying to work the bolts that adjust seat angle)
Plus the ball- and straight-ends on the PH-x wrenches is immensely useful for low-torque spinning and high-torque tightening/loosening
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,488 Times
For coolness though, my favorite tools are my vintage Campy wrenches:
"Peanut butter" 15mm tracknut wrench
Pedal/BB cup wrench
Pedal/BB cup wrench
Bikes: 2013 Custom SA5w / Rohloff Tourster
Quoted: 1252 Post(s)
Liked 338 Times
Easy choice. 4/5/6 Allen key Y tool. This one is 10X more useful than the clumbsy thick Park tool.
amazon.ca/IceToolz-Allen-Wrench-4mm-Sockets/dp/B0028NANNQ
The rubber on mine wore out of course, so I put some PL glue there.
Most used tool by far for all my DIY, is my bench vise.
I've never used or wanted a bike stand in my life. I have no clue how I would hold a wheel up in the air and tighten the nuts.
I true spokes while mounted on the bike. Elec tape across the stays is 100% accurate for round. I can adjust it as close as my eyes can see.
The most neato idea I've seen, is the hole on an adjustable wrench is made to fit a nut. Too bad it's a size I never use. LOL.
Of course they patented the idea, so it didn't get far.
Oh and as for that Knippex wrench?? LOL For almost anything on a BIKE.
