Bad shifting Ultegra 6800 groupset
Does the shifting change if you pull the brake levers slightly first?
There's a weird interference that develops with these shifters where the inner lever needs to release before the outer can shift, so they have external lever arms that cause this one/two release to happen. As they wear, this sequence gets screwed up.
If that's it, you fix it by bending the release arm fore or aft.
Quoted: 696 Post(s)
Liked 467 Times
However, before I replaced the hanger (I mentioned this earlier as well) I had my old hanger adjusted twice, by 2 different shops, while they worked on my bike, and after alignment, it did not fix or alter my shifting in any way. So I really don't think it's the hanger causing this issue.
If you adjust the cable tension, can you eliminate the sluggish shifting on the (a?) cog that’s got the problem - ignoring the fact for now it might mess everything else up.
Likes For choddo:
I have had the bike in the shop 4 times, and adjusted it myself 3 times (cable tension etc.). None of it has fixed this.
I'm going to try to get to 10 posts today, so I can post pics and a link to a Youtube video so you all can actually hear and see what is going on.
Here is a timeline of the work done:
1. Started shifting badly, so I adjusted both front/rear derailleurs myself. Couldn't fix it. Took it to LBS, had them put on a new chain, adjust the hanger (they said it was bent a bit), and adjust F/RD. Took it home, still shifting poorly.
2. Took to a reputable shop in another town (only have 1 local LBS, small town), where we checked the cabling. The cabling was getting worn, so I said to replace it with cabling that was on the same level (Jagwire was on it, and it's what I asked for, they said they had it in stock). At this shop they also adjusted the hanger. I picked it up, brought it home, and tested it. Still bad. That is when I noticed the cable housing was not Jagwire. So the next day, I took it back to that same shop and let them know they didn't give me what I asked for, and didn't fix the issue. They put the bike on the stand, tested it a bit and said it was fine. I said, no, it's not fine, it's horrible. Since they didn't have any quality housing (just the crappy Shimano stuff they had put on), I went down the street to another shop and bought Bontrager Pro cabling set. Went back to the shop, had them put on the cabling. They got done, I took it outside and test road it and it was still horrible. I got super mad and just left.
3. Next day, drove to the big city to a Trek dealer. They sold me a new rear cassette, R8000, and adjusted stuff, and said it was as good as they could get it. It was still shifting poorly.
4. I cleaned my shifters really well, lubed em up. I tried adjusting the RD again myself after another thorough clean/lube, still no joy.
So that is where I'm at now. I do have an appt. with the shop that put on the cabling, as I wrote a review of their service on Google and the shop manager contacted me, said he wanted to make it right. That's not until next Tuesday, as he is out of town this week.
Quoted: 1956 Post(s)
Liked 2,201 Times
Just wondering, how many miles do you have on this bike?
John
John
Likes For 70sSanO:
Let's see if I can now upload some pics and a link to a video.
This is the wear I'm referring to on the new cable. It was hidden underneath that broken housing.
Housing that is broken, removed it.
Hello John,
I don't know the exact mileage, but I'd say I probably have ridden it about an average of 2500 miles a year. Some years more, some less. I don't ride in the rain or snow or muck, only when it's dry. In the winter I ride it on my trainer. The first 4 years I had it, I was in WA. state, in the desert. The last 3, I've been on the Oregon coast.
Quoted: 833 Post(s)
Liked 1,981 Times
I have a Kestrel with Ultegra 6800 and when I went from a 11-28 to a new 8000 GS rear mech and an 11-34 cassette the shifting was noticeably rougher in the 27-30-34 shifts.
I learned to live with it in that it took about 1 1/2 turns of the crank to complete the gear shifts vs the previous cassette with closer gear ranges. It required more finesse in my pedal stroke to nail it.
Just my experience. Don't know what cassette you are running?
Likes For CAT7RDR:
Quoted: 4606 Post(s)
Liked 1,766 Times
Is the cassette on tight?
Likes For Kontact:
My bike came with the Ultegra 6800 groupset, with the 11-28 cassette and 50/34 crankset. I replaced my cassette earlier this week, and now have the 11-28 R8000 cassette.
One thing I noticed today is that my freehub is sticking a bit, when I backpedal the bike on the stand the tire starts moving/picking up speed as I backpedal. I just ordered a new freehub from Trek, and will get that installed. Not sure if it will help with what I'm experiencing but it needs doing, so might as well do it now.
Liked 1,766 Times
Was the cassette changed before or after the beginning of the problem?
How about a picture or video of the whole derailleur from the drive side of the bike.
Likes For Kontact:
LR÷P=HR
Bikes: 1981 Holdsworth Special, 1993 C-dale MT3000 & 1996 F700CAD3, 2018 & 2019 Cervelo R3’s & 2022 R5, JustGo Runt, Ridley Oval, Kickr Bike 8-)
Quoted: 891 Post(s)
Liked 1,245 Times
I wouldn’t goof with it further until the new hanger has been aligned.
Barry
Barry
Likes For Barry2:
Liked 2,201 Times
I’ve been running Jagwire housing and Jagwire slick cables and have never seen a coating that peels. Unless Bontrager has cut some deal with Elixir… lol.
I’ve seen a shift housing liner pull through because of the wrong cable housing ferrule. But having the liner there means it is missing somewhere else. I’m guessing the cable is running against the housing strands where it broke loose.
John
Likes For 70sSanO:
I apologize if this is new tech that I’m not familiar with, but none of that looks good.
John
John
Yeah, it seems off to me. My bike is in the shop right now getting the freehub replaced, and when I go pick it up next week I'm going to have the mechanic cut the end cap off the cable and I'm pulling it out to look at it. There should be no wear there at all. If there is, it's because the shop that installed the cabling messed it up. I'll know more this coming week. Until then I guess I just will take a break from thinking about it haha.
Liked 1,766 Times
Hi John,
Likes For Kontact:
LR÷P=HR
Quoted: 891 Post(s)
Liked 1,245 Times
Please do have them align the new hanger while it's in the shop.
It's a cheap job.
The new hanger I installed on my Cervelo R3 was WAY off and beyond the 3mm / 1/8" Shimano spec.
I know, not all new hangers will require it, but if yours does you'll never get great shifting.
Barry
It's a cheap job.
Barry
Liked 1,766 Times
The "wear" on the cable and "broken housing" appear to be things now missing from your bike. Current Shimano derailleurs have these little black guides that are supposed to be replaced with the cable that help prevent the coating getting rubbed off.
Liked 2,201 Times
John
Likes For 70sSanO:
I am potato.
Quoted: 1832 Post(s)
Liked 1,710 Times
I fully support and endorse the only possible solution to problems of these epic proportions: Dura-Ace. It's the only fix.
Car dependency is a tax.
Likes For base2:
Liked 1,766 Times
Likes For Kontact:
Quoted: 863 Post(s)
Liked 1,108 Times
A longshot but remove the wheel and grab the stays to check for movement in case there is a slight crack developing somewhere on the bike. If nothing else you can at least rule that out.
Likes For Crankycrank:
Quoted: 696 Post(s)
Liked 467 Times
So that bulge in the cable tail thing was that stuff in the first photo? That doesn’t look like the kind of coating I was expecting. Wonder what that is.
Shimano outers are fine by the way, I don’t have any issues with them.
Likes For choddo:
What looks like the bulge in the 'cover with tongue' seems to be just the piece flaring out, since it is cracked. You can see the inner cable through the crack.
Likes For KCT1986:
