Tire Pressure calculator Comparison and Accuracy
climber has-been
Quoted: 3593 Post(s)
Liked 3,781 Times
Possibly, but the thing is, my Superpower as a Scientist has been my consistent ability to come up with hypotheses which completely and elegantly explain observations, but which, when tested, turn out to be completely wrong. So, I've learned never to fall in love with my hypotheses.
Yeah, measured width. I got that bit of learning recently, too. GP5k 25s now measure about 27.5mm on my new rims, and they're precariously close to rubbing on the chain stays. Also, the Silca calculators recommends substantially lower pressure for 27.5mm than 25mm.
SE Wis
Quoted: 2756 Post(s)
Liked 3,427 Times
Quoted: 4629 Post(s)
Liked 5,166 Times
The Silca calculator must derive rim width off the measured tyre width as there Is no input for rim width. The SRAM calculator uses rim width and nominal tyre width. But they seem to end up with the same result for my tyre and rim combo.
Klaatu..Verata..Necktie?
Quoted: 10641 Post(s)
Liked 12,293 Times
Hey, testing your hypothesis and finding out it's wrong is also some super power learning. "Getting something wrong" may be the best kind of learning.
Liked 12,293 Times
Alternatively, actual tire width is the relevant variable, and others are using rim width and nominal tire width to calculate actual tire width.
Quoted: 3065 Post(s)
Liked 1,227 Times
One of the big problems with that calculator is that the surface condition is fixed for calculating the tire pressure. Out of the Selections available and if I'm riding my road bike, I encounter all of the conditions listed except gravel, cobblestone and track.
If I'm riding my gravel bike I encounter every condition in the list except track.
So then which one is supposed to be correct?
It's not that difficult to figure out tire pressure and a calculator isn't required to do so, unless for some reason you don't have an ounce of common sense. The calculator is bogus.
Quoted: 2643 Post(s)
Liked 1,997 Times
OTOH, last week I wanted to try 32mm tires, but I didn't want to pay $50-$80/tire to get 32mm GP5Ks to replace the 28mm GP5Ks on that bike, so instead I got 32mm Vittoria Corsa G2.0s, because Bike Closet has them for $35 each. I swapped them in, pumped them up to 70/75 (roughly Silca's recommendation) and went for my usual Sunday 59 mile ride. They were comfy, yes. Not necessarily that much comfier than the 28s at 80/85. But they were definitely SLOWER. I ended up with about 0.4 mph slower average speed over that route than my all time average for it.
climber has-been
Liked 3,781 Times
So then which one is supposed to be correct(?)
It's called "optimization". Pretty simple.
Likes For terrymorse:
Liked 1,227 Times
Pick the condition where you will spend the most time (minimize total energy), or pick the condition where you will be struggling the hardest (minimize hardest effort), or pick the condition where you expect the race will be won or lost (maximize chance of a win).
Goofy thing. Seems too many folks get caught up in analysis paralysis. Just go ride.
Liked 12,293 Times
Sorry, I got hung up on the 0.4 mph less than average speed. What kind of variation do you normally see in speeds -- what's your standard deviation, to use statistics? While I don't know anything about your fitness or route, that kind of deviation from the mean is in the noise for me on a 60 mile ride. I'll see more than that if the wind is out of the north, or south, or 5 mph above some average value I don't track; or 5 degrees warmer, or 10% more humid, etc.
Likes For genejockey:
Liked 5,166 Times
Yeah. Sure. OK.
My local roads also have many different surfaces and with the knowledge that lower pressures are less of a compromise on smoother roads compared to higher pressures on rougher roads, I generally bias toward the optimum pressure for the significant rougher roads I encounter.
If you can figure out your optimum tyre pressure for lowest rolling resistance all by yourself and it’s completely different to what Siilca suggest then good for you.
Liked 5,166 Times
Likes For PeteHski:
I use a chart that uses the riders weight and the size/volume of the tire. The volume determines the PSI needed to support a given amount of weight. If the chart recommends 38 PSI for a tire I do not care if is 100% or even 95% accurate. I rode for decades and used the force needed to compress the sides of the tire to decide whether to add air or not. More complicated with mountain bike tires where there are sidewall and tread and terrain considerations in the mix.
Quoted: 1646 Post(s)
Liked 1,867 Times
Do you guys have some magical pump heads where you can pull the head off without losing a bunch of pressure? Because every time I try to pull off my lever action pump head it loses probably >5 psi just from that. Rendering any kind of precise pressure experiments moot.
Likes For icemilkcoffee:
Liked 5,166 Times
Likes For PeteHski:
Liked 1,227 Times
The other problem is that gauges are rarely correct. 3 different gauges will have three different readings. I have 3 on pump gauges and 2 standalone gauges. Every damn one of them reads something different plus or minus 2 lbs.
But accuracy isn't important with a gauge. Repeatability is. Once you settle on using one gauge then you know your magic number.
Liked 1,867 Times
Previously when I was using the push-on head with my Silca pump, the pull off pressure loss was less. But the push-on head had other annoyances. Nowadays I use an air compressor with the lever-flip head. It works well with different stem thicknesses, but the trade-off is pressure loss getting it on or off.
Bikes: Time Scylon, Lynskey R350, Ritchey Breakaway, Ritchey Double Switchback, Lynskey Ridgeline, ICAN Fatbike
Quoted: 485 Post(s)
Liked 569 Times
Prestacycle claims that their digital gauge is +- 2% accuracy with .5 PSI precision. While I don't know which sensor they are using, I have been working on a farm machine product that uses a sensor that gives better accuracy than that and costs less than $3.00 Add another $.50 for the display and $1.00 for a low end microprocessor along with the other parts needed and you could have a pretty good gauge that cost under $10 to make.
Liked 5,166 Times
No, from the time I flip the lever, to the time I actually manage to wrestle the head off the stem, it continually loses pressure.
Liked 5,166 Times
I do have several gauges and they agree within a couple of psi, so I know I’m not miles out.
Likes For PeteHski:
Cheerfully low end
Quoted: 650 Post(s)
Liked 1,067 Times
It’s easy for me to consistently set tire pressure using a Meiser Accu-Gauge. I’m now on my second one in 45 years.
The new line has a bleeder valve so you can slightly overinflate with the pump and then bleed the pressure to the intended setting with the gauge. They have dial gauge models with ranges of 15, 30, 60 and 160 psi.
My gauge has a range of 100 psi, which has apparently been discontinued. I can read it to 1/2 psi easily.
The 30 psi gauge could be read to 1/10 psi. I can’t find a spec for the accuracy they claim but they are very consistent, which is what matters if you use the same gauge. And you don’t lose much air taking it off the valve.
Otto
Otto
Likes For KerryIrons:
Quoted: 404 Post(s)
Liked 315 Times
Has somebody seriously not yet invented a tire pressure measuring valve stem for bikes? Cars have this. It could broadcast to a phone or whatever and we could all continuously monitor our tire pressures,
As with hydraulic brakes, the tech comes to cars first and then eventually finds its way to bikes.
Advocatus Diaboli
Quoted: 4813 Post(s)
Liked 1,553 Times
Liked 5,166 Times
