Spoke tension meter
I have the Park tool and used it to build a few pair of wheels now and it really does make a difference in how the wheels perform. It's been 5 years now since the last build and I have never had to re-true a wheel.
Quoted: 5967 Post(s)
Liked 2,874 Times
Not to start a debate, but don't you think that experience, practice, and skills improvement might also factor into that?
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
https://www.aliexpress.com/item/4000048763228.html
This digital one from AliExpress. Cheaper and 100 times better than anything else out there. Only $40 dollars.
I doubt that. I had no experience, practice or skill. Maybe by the last pair I did, but not the first two. I don't have a truing stand or dish tool either. My fingers are my feeler gauges.
Bikes: Lemond '01 Maillot Jaune, Lemond '02 Victoire, Lemond '03 Poprad, Lemond '03 Wayzata DB conv(Poprad), '79 AcerMex Windsor Carrera Professional(pur new), '88 GT Tequesta(pur new), '01 Bianchi Grizzly, 1993 Trek 970 DB conv, Trek 8900 DB conv
Quoted: 759 Post(s)
Liked 811 Times
Please do report back how that tool is performing and how it does versus your calibration check. It would be interesting data and helpful to some.
Quoted: 759 Post(s)
Liked 811 Times
While I don't doubt that skill can sufficiently replace a tensiometer, this discussion reminds me of the old joke..
"I can tell you how to make a million dollars...first, you start with a million dollars and then you invest it in..."
Bikes: yes, i have one
Quoted: 1152 Post(s)
Liked 1,197 Times
sure will. was planning go. got my spokes yesterday and installed the new one. pretty true now. will finish up once the gauge gets here. i am very curious myself how well it performs.
Quoted: 559 Post(s)
Liked 501 Times
Does it not come with tables to translate readings to values? If I have to build a calibration jig I might as well make a tensiometer too, sounds like a fun Arduino project.
Yes comes with a chart but how accurate it is I have no idea, hence the jig, the repeatability is excellent so no issues there
Quoted: 2639 Post(s)
Liked 1,989 Times
And of course there's the bike shop owner's lament. How do you make a small fortune running a bike shop? Start with a large fortune.
Likes For pdlamb:
Liked 1,197 Times
for what it is worth this is what i bought and the following is a demo of the repeatability. i have not had a chance to compare the actual tension measured with a calibrated tool yet.
looks like two spokes need a bit of tightening.
https://www.amazon.com/Bicycle-Measu...7YQQQC8L&psc=1
Likes For spelger:
Liked 2,874 Times
How do you get 4 significant level of precision?
FB
Chain-L site
FB
Chain-L site
Liked 1,197 Times
do you mean 2 significant figures after the decimal...? i have very very good eyesight...bugs bunny is jealous.
the gauge only has integer graduations so there is clearly some 1/10 of a unit eyeballing going on. the rest is just because i highlighted the spread sheet and applied 2 decimal places because of the average and standard dev columns. that is all lost in the graph anyway.
Liked 1,989 Times
Really Old Senior Member
Anytime you have electronics involved that convert a voltage to a reading, one really needs to take the temperature coefficient of the tool if expecting "ultra precise" results.
Some may be fine in a laboratory environment, but may differ significantly in the temperature ranges the tool may actually be used in.
I used to build optical oceanographic instruments that used an LED of a specific wavelength for a light source.
LED's tend to have pretty wonky temperature characteristics and it was supposedly "impossible" to temperature compensate one.
It turns out most of the cheap electronics are not too good in this respect. My "free" Harbor Freight voltmeter reads 8% high. That's about 1 volt difference on a 12V battery. That's at room temp- Who knows.....
Put your tool in a baggie and stick in the fridge for a 1/2 hour and test vs. the same tool laying in the sun.
A simple digital display is +/- 1 digit + a % error that varies by the quality of the display.
Not venting on your specific tool, but just in general to people that assume if its digital, it's spot on perfect.
Liked 1,989 Times
