Gates belt drive weight savings, where do they get 10 ounces
Generally consistent with what I found when I converted: the "sprockets" are heavier for the Gates system but the belt is *much* lighter giving a lower overall number. Don't care to argue about the magnitude of how much lighter personally. I find a number of other benefits to the belt system in addition to the lower weight.
Yes the bike will ride the same either way. Like most bike bling you will very likely not be able to tell the difference in how the bike rides. But it WILL look cool and make you feel way better riding the bike. And, not speaking for all tandem teams here, but if I cannot look good riding the bike at least I want my bike to look good with me riding it
Bikes: '06 Bianchi Pista; '57 Maclean; '10 Scott CR1 Pro; 2005 Trek 2000 Tandem; '09 Comotion Macchiato Tandem; 199? Novara Road; '17 Circe Helios e-tandem:1994 Trek 2300
Quoted: 150 Post(s)
Liked 98 Times
Most timing chains would weight 340-360g, which is around 240g heavier than the CDX belt. This means that the whole Gates system is more than 200g than the conventional timing chain.
The X11Sl retails for $90, but is often on sale for $70. Since you need to buy a pair, the KMC timing chain will cost $140. I suppose that you can keep the extra links for a 2nd set, but it seems like a hassle for no particular benefit.
The Gates CDX system came in at 277g, or 290g lighter equating to a .639 pound savings, nearly 2/3 of a pound.
The Recumbent Quant
Of course, remember the weight savings matters for the whole system. So you're saving (almost) a pound, compared to easily 200 lbs for everything (two riders + bike).
Bikes: 2022 Calfee Tetra, 2023 Giant TCR
Quoted: 120 Post(s)
Bicycle design has been marked marked by a series of incremental improvements (STI shifters, 10 to 22 gears, cassette with ramps, threadless headsets, splined BB, kevlar tire bead, clipless pedals, aluminum frames, carbon frames, etc) that add up to a lot of improvement. I can't think of another component upgrade that will match the Gates for weigh reduction, cost, lower maintenance, and longer useful life.
Let's flip the question. How many tandem teams would take on 200-250g of unnecessary weight during a fast century ride or an epic climb?
Bikes: Co-Motion Speedster Tandem, S-works 29r, Specialized Tarmac SL4
Quoted: 14 Post(s)
We ride a steel CoMotion Speedster. Probably several, if not more, pounds heavier than a lot of the new tandems and we have a rack and bag on the back full time. Why? Makes it more convenient. Is it "necessary"? Probably not. Weighs a bit more than 1 pound.
I just bought a new set of timing rings for our tandem after considering the Gates drive system. CoMotion sells the 2 FSA rings, bolts and a chain for $60. Heck of a deal. We've done plenty of centuries over the 12 years we've been riding and many epic climbs. The original timing rings worked just fine and so did the rack and bag.
Quoted: 120 Post(s)
By unnecessary, I mean a significant weight penalty just to save a modest amount of money. For teams who care about light weight, the Gates will save 200-250g for about $100 (in addition to other benefits). This is a far better deal than buying lighter wheels, frame, handlebars, pedals, etc.
There are other teams who are not concerned about weight and think that $100 is too much. You're happy with your ride and that's the only thing that matters.
Bikes: 2015 Calfee Tetra tandem,2016 Calfee Tetra Adventure Tandem, Ventana ECDM 26 mtn tandem, Ventana ECDM 29r full suspension Mtn tandem ,Ventana Fat tire tandem, Calfee Dragon Fly, Santa Cruz Carbon 5010, 907 Whiteout fat tire
Quoted: 57 Post(s)
Liked 6 Times
Wow this thread is still going. I replied over 5years ago. We are still using the original belt and sprockets that we used back then and still going strong. This is many many thousands of miles ago and the bike has been taken apart at least 25 times since then and zero issues. We run it at much lower tension then the specs and no adverse BB issues. One trip in Turkey we had a coupler come debonded and the belt probably held the bike together for 5 days of riding. I would never go back to a chain again. The prices have come down and the clean factor alone is worth it.
Just do it!!
Just do it!!
Bikes: Cannondale tandems: '92 Road, '97 Mtn. Mongoose 10.9 Ti, Kelly Deluxe, Tommaso Chorus, Cdale MT2000, Schwinn Deluxe Cruiser, Torker Unicycle, among others.
Quoted: 279 Post(s)
Liked 207 Times
"Sorry honey, I didn't bring a spare belt. I'll steer up here, you take care of the stoking until we get the thing fixed!"
What a golden opportunity wasted by unnecessary ingenuity. Enjoy the ride!
Quoted: 120 Post(s)
Belts are widely used in cars and motorcycles because of their light weight, durability, and quiet operation. I'm not aware of Harley owners being advised to carry a spare drive belt on long trips. The belts with carbon fibers are so reliable that they only needed to be checked once or twice per year (or just before a long tour).
No recollection of any Gates failures (certainly none I know of with the newer CenterTrak design).
I've personally observed at least one failure of conventional timing chain, so there must be more.
I wonder if LV2TNDM carries a chain tool and spare links?
Clipless in Coeur d'Alene
Exactly how to you THINK a belt will fail spontaneously (without prior mishandling, ie: bending)? Next, ask yourself... "self, is there any indication of this belt having a history of failure?". Then, it is a golden opportunity to slap yourself upside the head and wonder why?
Quoted: 57 Post(s)
Liked 6 Times
The only time my stoker had to pedal like that was when we had already given our quick link to another team whose timing chain broke and a few miles later ours broke. Go figure I'll take my belt.
Quoted: 14 Post(s)
For teams concerned about weight the biggest impact for the lowest cost is to lose body weight.
I know - easier said than done.
Bikes: Canyon Dura ace, Pinarello Asolo Super Record, Holdsworth Nuovo Record, Duratec Di2 Tandem, Brompton
Canning wax/Paraffin
No greasy/oily stuff on our tandem chains.
We've used the hot wax (canning wax/paraffin) method for the past 35+ years.
Have ridden a tandem porototype with the belt years back; was not overly impre$$ed.
Just our input/experience.
Want to save weight? Carry one less waterbottle!
Rudy and Kay/zonatandem
What exactly is the lubricant you use (can you buy it on Amazon?).
35 years of usage pricked my interest = probably very good.
The Recumbent Quant
Not sure I understand your meaning. Are you saying that 200-250g weight reduction is not important to 200-300 lb tandem team?
250gm is 1/2 lb so that's 1/400 or 0.25%. Professional racer? (and no other effects?) Sure. Otherwise, it's a tiny effect. (Remember that aerodynamic drag is still a large effect, so 0.25% weight savings is not a 0.25% power gain).
The thing that spurred me to try a belt was not weight reduction, but rather the fact that I was starting to transport our bike inside our old "land bruiser" SUV. After removing a rear seat in the SUV I can now roll the bike inside on its rear wheel, clamp the front fork to a fork mount and close the rear hatch. It's nice to have the bike inside the car by only removing the front wheel for certain trips, but the maneuvering and packing of other vehicle contents risks having the timing chain leave a mark on something. The belt eliminates that concern, and happily we have noticed absolutely no reduction in efficiency, and some improvement in smoothness.
I tension our CDX systems a bit less than the recommendation, about 30-40 Hz when plucked. The cranks spin as freely with the drive chain disconnected as they did with a timing chain. The conversion cost ~$250 per bike, but hey, it's only money. And money spent on bikes comes from a different place.
TKramer
Bikes: Paketa V2r, Co-motion Equator Co-pilot, Bingham BUILT. tandem
Quoted: 14 Post(s)
Good old fashioned paraffin wax. Gulfwax from the canning section of the local market. I like to add beeswax to help increase the tackiness of the mixture - straight paraffin tends to flake off quicker. 1:4 bee-to-paraffin.
Super Modest
Quoted: 11039 Post(s)
Liked 4,781 Times
I like the ease of adjustment and no backlash. Combine that with no grease or oil and I'm all in on the Gates belt.
Btw, over the last 35 years, I've broken two timing chains. Luckily, my wife and I are close enough in size that we switched places and made it home.
Keep the chain tight!
Also while at locations, we have been renting a smallish mini-van (Nissan Quest). The tandem fits inside ok, with the rear wheel slipping down between the 2nd row seats and the front of the tandem resting on the front gates ring/belt. It stays upright in the Quest with the help of a couple cargo straps holding the capt. seatpost from each side of the van. So again, the belt setup is super clean and makes for easy and painless transport.
Obviously I am not babying the gates belt or rings and still no problems.
Quoted: 29 Post(s)
I've just done the conversion to a Gates Carbon Drive on right hand drive side. Being SSD I removed the eccentric BB and reversed it so that the adjustment bolt is accessible from the left hand side.
Weight reduction is 178g over 2 x FSA 42T rings and one and a bit SRAM 11 speed PC1130 chains.
Looking forward to cleaning and lubing only one chain.
Next project is to remove the BB30 to BSA adapters and replace both cranks with BB30 cranks. Then the fork. Then a Calfee frame with my geometry.
