Show us your gravel/cross bike...
#5026
Sunshine
Quoted: 11056 Post(s)
Liked 7,607 Times
Brought my gravel bike into the Chicago burbs for an extended 4th of July visit.
Did some mixed surface riding- road, crushed stone paths, basic singletrsck, and wooded bridle paths. No gravel roads within 20mi of where I visit, so the mixed surface routes have been a fun experience to link together thru the years. Surprisingly, overall climb is decent too as I ride on both sides of a couple rivers.
Likes For mstateglfr:
#5028
Bikes: 2002 Eddy Merckx Team SC Resto-Mod; 2019 Ibis Hakka MX; 2017 Spot Brand Ajax Belt Drive
Quoted: 169 Post(s)
Liked 192 Times
I picked this up used earlier this year, along with a set of 700c Ibis wheels. Took off the dropper post, replaced the saddle, and down-sized the chainring to 32. These wheels have 47mm WTB Venture tires and a 9-46 cassette. The other wheels have 42mm Rene Herse Snoqualmie Pass rubber, which are closer to slicks, along with a 9-39 cassette. I just washed it, so I figured I'd snap a pic before I get it dirty again today.
Likes For mattcalifornia:
#5029
Sunshine
Liked 7,607 Times
It's a mix of roads and paths thru Darien, Lemont, Palos(one of em), Western Springs, and Burr Ridge.
Waterfall Glen is the crushed path area and this double track as well as some single track is McMahon Woods and Cranberry Slough preserves in one of the Palos towns.
#5030
Quoted: 5 Post(s)
Liked 7 Times
I figured I had to finish this up; it was intended to be a winter bike.
Made in USA with True Temper OX, this piggish Trek now has a bunch of lipstick applied. Built with Sora shifters, Deore crank, XT cogs and derailleurs, and TRP mini Vs. Its a nice daily rider; has a decent steel ride and rolls well. I was a bit worried about the 70mm stem but its not an issue.
I used bikegeocalc.com to match the position to my Ritchey Swiss Cross, so this should be a nice cheap stand-in.
I want to see if some fenders will fit in there now.
First, what stem is that? It looks like a quill stem with a 31.8mm bar clamp and a removable faceplate. The angle and extension look just right.
Second, what crankset/drivetrain are you running? 2x or 3x? I'm looking to add some newer Shimano STI brifters to my stock Deore DX components but I'm not sure what front derailleur and crankset combo to run.
Some issues I've researched being:
- MTB front derailleur not being compatible with left brifter
- Road front derailleur not being able to shift into the outer chainring of an MTB triple crankset
- Chainline being incompatible because of 135mm rear dropout spacing and road/mtn crankset
#5031
Quoted: 582 Post(s)
Liked 1,027 Times
This is awesome! A couple of questions since I'm building a similar era Trek 520.
The crank is a Deore M6000 10sp 28/38 170mm. The shifters are Sora 3000 9sp. My first attempt with using a M737 XT front derailleur was a no-go. The modern Sora shrakes use a 10+ speed cable pull up front; so I used an Ultegra 6700 10sp front derailleur; it swung out far enough without issues even though the height / chainring curve match is not ideal. Rear is a 737 XT derailleur and 9sp XT 750 11-34 cassette. Chain is 9sp KMC. Shifting is perfect in this setup.
Stem is a Nitto UI-12 70mm 90deg 31.8 with removable front plate for modern bar compatibility. I wanted to use a modern compact flared drop bar (EA50AX). This was an expensive part of the build but I needed a 70mm extension to match my other bike.
Hope this helps.
Likes For DorkDisk:
Likes For gios:
#5033
Quoted: 5 Post(s)
Liked 7 Times
Thanks, I had the same concerns as you re chainline but it turned out to not be a big deal in real life. So this one has a 135mm rear with a 130mm wheel, which makes the chainline worse with a spaced out modern MTB crankset. I put the BB spacers on the non drive side to not make the issue worse and the shifting is fine in all combinations with no rub or odd noises anywhere. Chainline is visibly not great but functionally I don't have any issues, aside from a wide MTB Q factor.
Hope this helps.
Hope this helps.
But it also sounds like 5mm difference in chainline isn't a huge deal in real-world usage. Some bikes probably come with road front derailleur and 135mm rear spacing stock from the factory. I guess at this point I just have to experiment in order to get a proper STI brifter setup to work.
I definitely like the look of the silver Nitto UI-12 in 70mm at 0degrees on these vintage Treks. I'm actually running a similar stem on my Trek 520, a Crust x Nitto UI. The main differences are longer extension and stem angle is 15 degrees. I really like the look of the silver better though. If only it had taller extension it would be the perfect stem. Another similar stem I have found is the Discord Fingerling Stem, which essentially acts as a beefier Nitto Technomic with a 31.8mm bar clamp and costs a whopping $195.
Anyway, here is my retro gravel tourer on some Panaracer Gravelking SK 700x43c tires. Shimano 7-speed bar end shifters are mated to a Deore crankset (50-45-28t) and a 12-32t cassette which provides a pretty nice range of gearing. The 46cm Salsa Cowchippers also offer some control in the rough stuff! Steel is real but the newer bikes in this thread are so tempting haha
Likes For indofulioh:
#5034
Quoted: 582 Post(s)
Liked 1,027 Times
Thanks! This was really helpful. As I suspected, getting the front shifter/derailleur/crankset combo just perfect can be a huge challenge when mixing Shimano road/MTN components.
Anyway, here is my vintage gravel bike on some Panaracer Gravelking SK 700x43c tires. Shimano 7-speed bar end shifters are mated to a Deore crankset (50-45-28t) and a 12-32t cassette which provides a pretty nice range of gearing. The 46cm Salsa Cowchippers also offer some control in the rough stuff! Steel is real but the newer bikes in this thread are so tempting haha
Likes For DorkDisk:
Likes For tdilf:
#5036
I'm in shape! A round one
Bikes: Konas: Jake the Snake-Fire Mountain-Zing Supreme, Surly Long Haul Trucker, Santana Arriva tandem, Montagues: Paratrooper-Fit, Trek 1200, Bianchi Ocelot, and an old Bridgestone 200 I rebuilt as a singlespeed.
While it wasn't my original intent to use my Montague Fit frame for gravel, playing with 650c shows that I can fit 42mm tires with plenty of clearance, while keeping geometry pretty close to what I had at 700x28. Still tweaking the cockpit, but the bike moves pretty well for its extra weight (folding frame) and fat rubber. I do have the 700c wheels still, and plan to wring it out with both sizes once I get the saddle and stem where I want them.
Likes For spacerconrad:
#5037
Sunshine
Liked 7,607 Times
#5038
Bikes: Kona Kahuna DL Drop Bar - Sensah SRX Pro 1x11 (2012 Frame), Giant Toughroad GX 1 - Shimano Road Hydro + SLX 1x10 (2018), Diamondback Sync'r - SRAM NX 1x12 (2020)
Quoted: 160 Post(s)
Liked 97 Times
I'm still waiting on my gravel wheels to come in, but for now my drop bar MTB is in trail mode (ft. -2 degree headset from Works Components)
Likes For DarKris:
#5039
Bikes: N+1
Quoted: 94 Post(s)
Liked 419 Times
Work in progress… 1991 bianchi volpe. I swapped in a tiagra rear wheel so I could use these 9 speed ultegra shifters. Mid 90s xt rear derailer shifts so smoothly. Next is a new crank, but undecided if I want to go compact double or stick with 90s era xt or similar. I’ve been using it exclusively on mtb trails so far, so leaning towards the xt.
Likes For Flatforkcrown:
#5040
My 2021 Diverge. On Fulcrum 5 wheels, converted from grx400 2x10, to 600 1x11. With GK SKs.
Got some Teravail Rutlands on the factory wheels waiting for our British winter…
Likes For Simonix:
#5041
Doesn’t seem like they get much love anymore but here’s an OG gravel bike. My unbreakable Salsa Vaya doing Salsa Vaya stuff.
Likes For Wspsux:
Likes For Caliwild:
#5044
I just upgraded my2021 Giant Revolt Advanced 2 to a 2021
Advanced Pro 1 through Giants upgrade program.
Likes For mwatt65:
#5045
I declare this shall be my final budget Schwinn hybrid -> gravel conversion
Apparently you are only allowed a 'reasonable number' of Schwinns before the wife calls it 'hoarding' and 'irreconcilable differences.'
(the source bike was a used Schwinn Volare 1200 purchased for $60)
Likes For mikehuangsd:
#5046
Occasional Visitor
Bikes: 1972 Schwinn Paramount, 1993 Merlin Extralight, 2016 Lynsker Cooper CX, 2021 Lynsker GR 300
Liked 8 Times
Farewell to my GR 270 build before I tear it down and transfer most parts to a new frame.
Likes For WheelsRolling:
#5047
New tires,saddle, seatpost,QR levers,chain,chainring.
Likes For BoozyMcliverRot:
