What did you do for your Hybrid today
#551
Quoted: 5234 Post(s)
Liked 3,609 Times
did not know about this thread. does adding prospective tires to your bike's wish list count?
#552
Quoted: 1587 Post(s)
Liked 1,226 Times
So she's weighing in at 16 Ibs 12 oz with the potential to drop a bit further.
I've got a new Crane Creek headset to come to replace the terrible steel thing they pressed in
and I'm after some full carbon forks ( legs and steerer ) to replace the 700 gram forks that came with it.
So maybe another 200 g ish to drop.
The bike is loaded with titanium bosses, bolts and washers anywhere I can get then in...and there's more to come.
On the road she's quiet, fast and smooth and I grin at the response I get when I put some power into the pedals.
OK...she's not a ' full on ' carbon racer but I've not ridden a bike this light before - it's so lovely.
Hills ?
What hills....?!!
I'm slightly over £700 down but where could I get a bike for that price that weighs so little, is dripping in Dura Ace bits and looks like that ?
I also learned a lot too from this build, particularly taking my time instead of rushing to get it out.
Been there !
Hills ?
What hills....?!!
Been there !
Mine came stock with that same crap headset, by the way -- replaced it after the first year (along with most everything else) once I knew the bike was a keeper.
#553
Bikes: Spesh Sirrus Pro, 2 x Scott and 1 X Giant mtb's
Quoted: 10 Post(s)
Love it....
Fantastic job! I like light bikes too; you might have inspired me to go a little further with mine for the coming season As pictured below (2010 Sirrus Comp frame/fork -- pretty much the same construction as yours): 19.1 lbs w/pedals.
I think yours is a fair bit better and newer than mine but similar - ish on the eye.
If it's at 19 now there's still plenty to drop off it if you empty your pockets a bit
I'm also after a KMC chain with the hollow pins and slotted links and i've also toyed with just having one chain ring.
That's about another pound in weight with the chain but I may also miss the gearing flexibility....undecided
My only benchmark is a 23 pound MTB so you can imagine how my new build feels compared to that !!
Hey, give it a go....we can start a weight weenie section of our own
#554
Quoted: 10 Post(s)
Closer inspection...
I see a naughty pair of CX9's hiding in there.......
#555
Liked 1,226 Times
Very well-spotted! They have been, quite simply, fantastic. Silly expensive for v-brakes, but since installation in spring of '11 not a single adjustment has been needed, other than twist the barrel for pad wear. Not one. I've replaced the inner cable on the rear once, cleaning the noodle (compressed air) at the same time just for maintenance, and replaced the pads once. That's it. They simply work -- flawlessly. Levers are Avid SD7.
#556
Liked 1,226 Times
So not a weenie build at all, but even so down to the 19ish mark from stock, and much nicer to ride. Carbonizing the post and bars would probably drop another 500 grams or so; might do that.
Main thing is the geometry/fit/ride, which suits me perfectly. I was pretty sure it would when I bought the bike, but waited a year to do the rebuild just to make sure.
#557
Bikes: 12 Diamond Back Topanga custom build, 16 Niner Air 9 custom build, Slightly modded 16 Polygon Helios F5
Quoted: 21 Post(s)
I picked up a 2016 Polygon Helios F5 last weekend and I've already bought parts. This weekend i'll be swapping out the junk 25mm Schwalbe Luganos for 28mm Conti 4 seasons, adding my Selle seat, and a carbon seat post. Also cutting a couple inches off the handle bars and adding foam grips and carbon ends. It's supposed to be nice out so I'll be posting pics as soon as I get out for a ride.
#558
Bikes: 2015 Giant Roam 1 | 2002 Giant Sedona LX | 1980s Norco Monterey SL
Quoted: 131 Post(s)
The weather here in central Canada is starting to shape up, the high for today is +2C, tomorrow is +4C... spring is likely still a few weeks away, but we're certainly getting a taste of it and tired of winter! That's getting me itchy for cycling, so in anticipation of an early spring and return to riding, I bought the following accessories and upgrades for my 2015 Giant Roam that I acquired last fall:
NEW TIRES: Continental Speed Ride 700x42
GRIPS: Ergon GP3's:
REAR RACK: Axiom Journey
FRAME BAG: Banjo Brothers (Small)
BOTTLE CAGES: Blackburn Design Alloy (2 of 'em)
Looking forward to getting this new gear installed when it arrives in a few weeks and then hitting the trails with my new upgrades! Will post pics of my ride with the upgrades installed then.
Cheers
TRJB
GRIPS: Ergon GP3's:
Cheers
TRJB
#559
Bikes: 2016 Fuji Absolute 1.7
Quoted: 13 Post(s)
Bikes: Trek Hybrid, will enter model number once I know
I live outside Philadelphia and I've been hybrid riding since Moby Dick was a minnow, if not earlier. My heart says get a road bike but the roads around here say no way--it's Pennsylvania, The Pothole State, after all. Mine is a Trek 7.5 with 3 chain rings and a 9-gear cassette, and I use 700 X 28 hard case tires. It's not as fast as a road bike or as rugged as a mountain bike, but I can use it for either type of riding. If I want to do a 20- to 35-mile weekend ride on roads with light to moderate traffic, I can do that, and if I want to use one of the paved trails I can go that way too. The latter is much flatter terrain so I can use more speed, within reason of course. As for the computer, the only reason I don't use one is I don't want any more "junk" on my bike than I need. Yup, I still do it old school when I map my rides, but I'm beginning to wonder how long that will last. Anyway, enjoy your ride and do it often.
#562
Liked 3,609 Times
#563
Liked 3,609 Times
doesn't take much to feel faster
#565
Bikes: 2011 Trek FX 7.3 | 2015 Trek FX 7.4 | Lotus Classique
Quoted: 171 Post(s)
Liked 22 Times
i don't think it's placebo... i went from 32mm to 25mm tires on my trek fx and the improvement riding around and on hills was definitely real! my average speed went up too.
#567
The Moose
Bikes: 2016 Giant Roam 2, 2004 Norco Torrent, 1969 Raleigh Grand Prix
Quoted: 108 Post(s)
The snow subsided and the weather warmed to 18c. Took the bike and kids out for a cycle. Thoroughly enjoyed the upgrades that I made over the winter. Race Face 1X crank, Gravity carbon handlebar and FSA stem.
#568
The Moose
Quoted: 108 Post(s)
I pulled apart the hubs,cleaned them, greased them and put them back together. Then I cleaned the cassette and installed a new chain after cleaning the 1x. Adjusted and cleaned the derailleur as well. She is running smoooooove.
#571
Quoted: 1218 Post(s)
Liked 298 Times
The first picture, Nomad Resist 700x35
Second picture, Clement X'plor MSO 700x40
Last 2 pictures, Panaracer Pasela PT Folding 700x38c 'skinwall' mounted to 2005 era Mavic Ksyrium elites (half way de-badged)
Brakes are Magura HS11 post mounted hydraulic rim brakes.
#573
Regarding the brakes, how easy are they to set up and how easy is it to squeeze the wheels in and out, and does it make the brakes go out of adjustment??
#574
Liked 298 Times
As for why I switched I am pretty much 99.5 % tarmac on this hybrid. On occasion I will hit a bit longer than average limestone gravel drive way. And I have 4 miles to a 1 stop light town. and then 12+ miles to any other town worth riding to from where I live. (one way distances) So I switched for something a bit easier rolling. Less wattage required per mile, and also looks. I was also Meh about them, and LBS told me $40 each.. So I went for it. lol They are huge salsa Marrakesh fans anyways which come with these tires. So I already knew how they rode. they ride really nice and roll fast.
the brakes are super simple to set up, yet sort of annoying. Throw the horseshoe bracket on the posts. Looking at the post you bolt the left side on and it has a peg that goes into a hole in horseshoe bracket right above the post. the brake cylinder is like a ball joint. put pad where you want it and tighten two bolts. one being into the post, and the other being into the peg that inserts into the hole. The right side has a quick release setup on the post. Once the pad distance / angle etc is all set. you can release the right hand caliper all you want with no issue.
I just find it annoying because on all my brakes I squeeze brake lever and then tighten stuff down, for toe in I always slip a zip tie under one side of pad. Can't do that with these brakes..... If you do, you'll be doing a bleed job.
I had some issues with rear squeaking, and I tried all sorts of adjustments. Now the squeal is gone, and It doesn't seem to matter how it is adjusted, So I moved it all to be how I want the brake lever to feel and it's golden.
Never grab a handful of both brakes at same time. It will launch the rider!! lol best brakes I've ever had on a bike. I haven't ridden in the wet though.
30 miles in running shoes the other day, I run around 40-50 psi. It was a dream to ride... well aside from the front hub needing adjusted. (fixed now)
#575
1. I absolutely love the MSO's! my next set will probably be the 700x36 version.
It's nice to have an N+1 for different kind of riding. That way you can tweak it to perfection. I have the MSO's on my bike and I understand what you mean when you say you wanted something easier rolling. The days that I ride on asphalt only, I wish I had another wheelset with something more road oriented. But since I do about 50/50 road/off-road the MSO'S are a great compromise.
