Shimano RD Cable Keeps Fraying Inside Shifter
#51
Quoted: 996 Post(s)
Liked 596 Times
But... back to the shifter. I have a 22-year-old bike with Ultegra 3x9 on it that has never had a cable fray. To be fair, the bike only had about 8,000 miles* on it when I changed to trekking bars recently, but the cables were completely intact. Is it possible that the OP's particular shifter has a stress riser of some sort inside the mechanism; a rough edge or something? I would be pretty unhappy with having to change the cable every 1,000 miles even though on average that's every few years for this bike.
*A lot of those were in southern Wisconsin, so plenty of shifting was going on.
#52
Quoted: 5995 Post(s)
Liked 2,932 Times
I strongly doubt that it's anything specific to the OP's lever. The large number of people reporting the same is very convincing evidence of the problem being inherent in the system.
Likes For FBinNY:
#53
Sock Puppet
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 1031 Post(s)
Liked 863 Times
This is "cyclic fatigue"... one of the banes of my life as an endodontist. I'll pitch a $20 instrument after one use rather than have it break off in a root canal.
Likes For Lombard:
#54
Quoted: 572 Post(s)
Liked 517 Times
Carry a few inches of cable with the nipple attached, then when you need to bodge it to get home you can thread the cable through the rear mech to hold it in one of the lower ratios.
#55
Quoted: 996 Post(s)
Liked 596 Times
EDIT: Hmmm... maybe you're right... it was the brake cables that were under the bar tape.
#56
Sock Puppet
Liked 863 Times
I have a bike that has 5600 and the cables are external.
#58
Liked 2,932 Times
+1 On tours or long day rides I carry a 2" brad, or direct pull spoke with the 5mm hex key that's the main part of my road tool kit. I set the RD for my favorite cruising gear, and ride 2s to get home. If there's a longish climb, I'll get off and "shift", then shift back at the top.
FB
Chain-L site
FB
Chain-L site
#59
Liked 2,932 Times
Likewise, we have large numbers of this kind of cable failure. I know how and why they fail and don't think about the cables that don't. For all I know, those bikes simply haven't been ridden far enough yet.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
#60
Sock Puppet
Liked 863 Times
There is clearly a problem with these shifters. We don't know why some people put many miles on these shifters without a problem. That would lead to a QC issue although there is clearly a design flaw as well.
Likes For Lombard:
#61
Quoted: 117 Post(s)
Liked 27 Times
My Cannodale synapse has Ultegra R8000 shifters.
I have this bike for 9 yrs. Since its not my only bike I estimate 10000k on it.
I'm still using the original cable housings and wires.
However, I very rarely ride in wet conditions, but ride a lot of hills therefore a lot of shifting.
Recently, my left shifter jammed because of dirt in the mechanism. However, the wire was not frayed and looked ok.
Decide to replaced cable housing and wires at this point.
#62
Just Pedaling
Bikes: YEP!
Quoted: 357 Post(s)
Liked 589 Times
#63
Quoted: 3663 Post(s)
Liked 3,100 Times
When are they going to invent something to replace stainless steel wire cables? Something that won't fatigue. Like carbon fiber cables or something?
#64
Liked 2,932 Times
However, it's very possible for makers improve cable life. The biggest improvement would be to increase the cam's radius. And/or It shouldn't be difficult to improve cable suppleness.
The goal should be to get the cam's and wire's free bend radii more closely matched.
Alternately, the overall design could be modified to avoid winding the wire around the cam, and having the pull in a straight line, as do brake cables.
One other possible consideration may be rider habits. Aggressive, crisp shifting may be harder on the cable. The higher peak tension during the bend may increase strain and shorten fatigue life. I offer this only as something to think about. It would take some practical experiments to move this from conjecture to theory or proven fact.
Anyone curious can do a simple experiment with the scrap end next time they replace a cable. Bend it over your thumb or finger. If it springs back straight, it won't fatigue in use. If it takes a set, the tighter the set, the shorter the expected life.
#65
Sock Puppet
Liked 863 Times
#66
Method to My Madness
Quoted: 2082 Post(s)
Liked 1,570 Times
#67
Quoted: 996 Post(s)
Liked 596 Times
In your line of work, do you think about all the teeth that are OK, or do you focus on those needing root canals?
I don't doubt that you have seen many more of these problems than I have, or ever will. But, as you like to say, give me a little credit: I'm not saying that because I haven't *personally* had this problem that it doesn't exist.
#68
Liked 1,570 Times
#69
Liked 3,100 Times
#70
Liked 1,570 Times
I don't have electronic shifting on my bike; I do have it in my car. I also have automatic watches and fountain pens. Being a parent, I am sick of Thomas the Tank Engine and his colleagues, but I do want to marvel at how you added networking capability to your typewriter in order to post here on BF.
#71
Liked 2,932 Times
Didn't think you were, nor was I.
It's not about how common a problem is, it's about understanding causation and process by which these failures occur.
The mechanism is well understood beyond the bike industry. It's common to all cable systems, and there are a number of engineering specs written around it, covering things like miminum pulley diameters and elevator cable replacement schedules.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
#73
Liked 1,570 Times
As alluded to above (and expressly noted in other threads regarding the RD cable fraying within the shifter), the issue arises from the cable traveling through a relatively right bend within the shifter body so that it exits largely parallel to the longitudinal axis of the shifter body, to allow the cable housing to be hidden under the bar tape and/or partially within the handlebar. This is a departure from the previous (Flight Deck?) models in which the cable exits in a perpendicular direction from the side of the shifter body. So, it seems to be a design limitation rather than a design flaw -- but regardless of which -- due to a design choice adopted by every manufacturer.
#74
Sock Puppet
Liked 863 Times
