Concussion prevention and helmets
#51
Zoom zoom zoom zoom bonk
Bikes: Giant Defy, Trek 1.7c, BMC GF02, Fuji Tahoe, Scott Sub 35, Kona Rove, Trek Verve+2
Quoted: 558 Post(s)
Liked 736 Times
Folksam insurance company in Sweden tested and published results of MIPS vs. non-MIPS helmets in 2015.
I chose a POC based on the results.
Be sure to download the full study (14 pages) from the following page.
https://www.researchgate.net/profile...na-Stigson.pdf
#52
Advocatus Diaboli
Quoted: 4823 Post(s)
Liked 1,557 Times
As I understand it, all helmets are supposed to be built to a minimum safety specification, the more $$ you throw at it means more aero and more lightweight (and probably closer to the minimum threshold of meeting the safety requirement). Technology like Mips might be more effective if you don't wear a beanie or helmet liner underneath, but a lot of that talk is marketing.
Older thread on MIPs, someone said helmets with MIPS come with instructions to not wear a cap/liner underneath. As I always wear one (in summer for UV protection; in winter for warmth), MIPS is a non-starter for me. YMMV
#53
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4383 Post(s)
Liked 3,054 Times
I have looked at a lot of MIPS helmet manufacturer sites and I don't see this warning anywhere. Not in the helmet sites, not on the MIPS technology site; which I think it would be if it were an issue. It's absolutely NOT in the Giro MIPS manual that came with my new helmet.
I've heard this rumor as well, and seen it posted in here somewhere (quite often from you), but never anything official.
I even found the original thread I think you're referring to: Best ventilated helmets
It references the BELL helmet manual and a consumer support e-mail response, but the liner warning is not in the current version of the BELL helmet site either: https://www.bellhelmets.com/bellspor...l_B5000433.pdf
So maybe it used to be in there. Maybe some customer service monkey confirmed that. But if it were important it would be highlighted, so I'm going to call BS unless shown otherwise.
**Not making any statement on the concussion prevention ability of MIPS, just that wearing a HeadSweats shouldn't factor into your decision.
#54
Quoted: 174 Post(s)
The force necessary to crush the styrofoam in your helmet is force that isn't applied to your skull and the brain inside it. Relative to skull fractures...by spreading out the area of impact it results in less focally applied force therefore some degree of lower risk of skull fracture. Helmets are potentially beneficial.
#55
Advocatus Diaboli
Liked 1,557 Times
I've seen the bell manuals online.. and I don't think I could find their sister company's giro helmet instructions online. Please note however.. that while there is no helmet liner or hat warning, there's also NO mention of the word "MIPS" anywhere in this online "Owners Manual".
I guess if I was in the market right now for a new helmet, and thought I wanted a MIPs helmet, I would redo a direct query to a couple helmet makers to ask the question about safety of wearing clothing articles underneath these.
#56
Quoted: 4651 Post(s)
Liked 1,787 Times
That is a sort of lower window to minor injury or concussion, even though the helmet is able to absorb a much greater impact by destroying itself.
#57
It's MY mountain
Liked 3,054 Times
I have referred to this old thread a few times. I kinda saw that thread as an easily-buried and overlooked, but a fairly important one.. if all that was said in that thread is in fact true.
https://www.bellhelmets.com/bellspor...01076300-C.pdf
So we agree. There are no current helmet manufacturers, as far as either of us know, who print in their user manuals, that caps or doo-rags should not be worn under a MIPS helmet. And the MIPS corporation themselves also make no such warning. And nobody should be claiming otherwise.
#58
Advocatus Diaboli
Liked 1,557 Times
The BELL manual for Aus/NZ says not to wear anything under your helmet - any helmet, no mention of MIPS. How does that affect your decision?
As to your reference of "print" manuals, I have absolutely no idea. I wouldn't outright claim @howheels is lying though (who was referring to the printed instructions that came with his helmet). So far, in this thread, we're all quoting online (not print) genericized manuals.
I'm also not sure there'd be any benefit to the MIPs company(?) publishing anything that doesn't concern them directly.. they're licensing to helmet companies, not selling directly to consumers. What they might tell the licensing companies that use their tech could be different than what choose to present in their own online public-access material.
#59
Wearing a cycling hat or do-rag under a MIPS helmet should have no effect. The slip plane of the MIPS technology would not be impacted by anything under it as long as it doesn't between the parts that are designed to slip.
J.
J.
#60
Liked 1,787 Times
You would hope that thin fabric would have little more effect than the hair many of us have up there.
#61
Quoted: 174 Post(s)
The force initially applied to your noggin will be whatever amount of force it takes to exceed the yield strength of the styrofoam - which is somewhat hard stuff. So your head is going to be met with at least that much force before the styrofoam's structure collapses and the foam begins decelerating your head. Up to that point the helmet is going to feel like it is made of pine.
#62
Advocatus Diaboli
Liked 1,557 Times
#63
Liked 1,787 Times
Exactly - peak deceleration. The helmet is designed to for a significant impact, not more minor ones. Those are going to hurt.
#64
It's MY mountain
Liked 3,054 Times
1. The current Giro owner's manual says nothing about this (not on-line but I have a hard copy).
2. The current Bell owner's manual says nothing about this.
3. The current Bell owner's manual for NZ/AUS says not to wear anything under ANY helmet - whatever this is it's not a MIPS warning.
4. The 2016 Bell owner's manual apparently said something either about MIPS or any helmet.
5. The Consumer Support e-mail to user @howheels appears to have been written by a marketing person who copied some blurb and made an unsupported conclusion.
Originally Posted by ConsumerSupport-Bell
Hi
Thank you for your email. MIPS stands for Multi-directional Impact Protection System, which is a leading slip-plane technology inside the helmet designed to reduce rotational forces that can result from certain impacts. So nothing can be worn with mips protection. Thank you
Hi
#65
Quoted: 4896 Post(s)
Liked 4,067 Times
The key words are "under your helmet". So, no jersey, no shoes, no shorts. The odds are very good the police will show up before an ambulance is needed!
Ben
#66
Right, thats exactly what they meant :-)
Or maybe its just layer talk, to prevent liability, in case people decide to wear hair clips, hats with metal bits or any other untested headgear. Maybe.
#67
Advocatus Diaboli
Liked 1,557 Times
Except that THERE IS NO ISSUE.
#68
Liked 1,787 Times
And in my experience, the Headsweat keeps my helmet more securely in place, it slides around more when I don't wear the Headsweat.
#69
In online squabbling, telepathy is generally accepted as valid arguments. Didn't you know? :-)
#70
Advocatus Diaboli
Liked 1,557 Times
I doubt it.. but I don't think it's too hard to imagine that yes, a person having a lot of hair will have a helmet fit differently (and probably somewhat less safely) than someone with less hair.
#71
Liked 1,787 Times
Given that, consumers have to choose how they want to deal with such warnings, including whether they will benefit from MUPs if they have thick hair, and whether Bell's silence on hair actually means that the helmet won't work because you had a thin do-rag on. And if they don't work in a crash because of your do-rag, if you are actually going to care that this might limit your ability to sue Bell for damages.
#72
It's MY mountain
Liked 3,054 Times
This whole thing smells of urban legend... along the lines of eating PopRocks and drinking a Coke.
#73
Quoted: 243 Post(s)
Liked 234 Times
A good source for bike helmet information is helmets.org. They even have a picture of a helmet designed to prevent concussions.
#74
Advocatus Diaboli
Liked 1,557 Times
This demonstrates why the warnings offered are about litigation and not safe operation. If Bell was concerned with safe operation, they would quantitize the amount of acceptable loose fiber (hair or not) that can intrude between the helmet and bare skull. Physics doesn't change because your thick, wavy hair isn't made of cotton.
The question: "I have a product question related to your cycling helmets. Can you advise if either MIPs and/or Non-MIPS helmets are safe to use with a helmet liner/cap underneath (eg. headsweats, skull cap, cycling cap, balaclava, etc.)? The literature is unclear on this."
The response:
"This is a great question. Technically, we have to advise against this, as all heads are different, and there are an infinite variety of caps, balaclavas, etc. one can wear under a helmet. However, if the helmet is snug and properly adjusted per the owners’ manual, and the cap is thin (a cycling cap, skull cap, etc., not a thick wool winter hat), we have never seen an issue in our retention testing. There is no research on this issue, perhaps because of the huge variety of caps available.
Certainly any cap will raise the helmet up and reduce the covered area of the head. Thicker caps would raise the helmet substantially more, and in some accidents this could present a serious risk.
I can tell you also that many of us here wear cycling caps or thin skull caps under the helmet, in particular in the winter.
Thanks.
Thom Parks
Senior Director of Product Safety
Bell Sports, Inc."
#75
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
Serious question: have you (anyone) ever refrained from wearing a cap under your helmet because you thought it would be less safe?
