Tubular or Tubeless Wheelset?
#51
Quoted: 7163 Post(s)
Liked 11,368 Times
When I was young and new to my profession, I would inwardly laugh at the old-timers who would lecture us about “how we do things.” Almost always their rationale boiled down to “we do things this way because we always have done them this way.“ They were a big factor in my decision to retire young.
Likes For Koyote:
Likes For KJ43:
#53
Quoted: 4644 Post(s)
Liked 5,178 Times
This coming from the king of misinformation.
#54
Quoted: 2407 Post(s)
Liked 3,002 Times
Wow ... interesting range of character studies ...
here is my input (I say that to warn everyone to scroll past the rest of this post):
snip
Tubulars have always offered a safer (run-flat) and generally superior ride (lighter, more supple) but were less durable and required a major hassle to repair in the field (my understanding, supported only by many, many anecdotes.) On another hand a lto of people think changing a tube is a major hassle ... and anyone who has triedd to wrestle off an ultra-tight tubeless tie which couldn't be plugged ....
Best part is ... thee days from now this thread will be closed and three days after that everyone will have forgotten it and the OP will buy whatever he does and no one will really care ... because it is the internet interaction, not actual cycling experiences, that bring us to BF.
snip
![RenRad](https://www.bikeforums.net/images/smilies/rennrad.gif)
Life is too short not to ride the best bike you have, as much as you can.
Likes For squirtdad:
#55
Thread derailleur
Bikes: Croll '94 & Cannondale Supersix '15
Quoted: 383 Post(s)
Liked 483 Times
Little bit disturbing to see some of you guys railing on Dave Mayer.
Sure, he came on with some strong assertions. No need to work so hard together to discredit him.
You accuse him of misinformation and bias, yet there you go coming back with your own brand.
Replace his use of 'tubular' with 'tubeless' and you all would've been heaping your praises upon him.
#56
Liked 5,178 Times
Given that the OP is aiming for an ultra-light climbing bike and is comparing tubular weight against a tubeless setup, then carrying a spare tyre defeats the point of the marginal weight saving. It should at least be taken into account in the weight weenie analysis.
Likes For PeteHski:
#57
Liked 3,002 Times
in any case for total weight comparison, one would need to consider tire weight, sealant, innertube weight, patch kit weights, spare tire in all the combos. I would think tubular will still come in lighter.
I am not a fan of tubeless for anything 32mm and under and that the ability to do field fixes is more difficult on tires that are hard to get on and often need special tools/compressor to get the bead to sit, but it seems that plug fixes have gotten a lot better in the last couple of years
#58
Quoted: 4895 Post(s)
Liked 4,067 Times
I commuted for decades on tubulars because the change was so fast. I was never late for work and I felt real comfort knowing that if I flatted in a shady neighborhood at night, in 5 minutes I'd be on my way. (Probably on a very crooked tire but they always got me home.) And whatever caused that flat wasn't going to cause another. I didn't even have to look to find it. And you can do that change in the rain, in the dark, in the snow, inebriated (well that might take a little longer) or in any combination.
Likes For 79pmooney:
#59
Quoted: 4076 Post(s)
Liked 7,666 Times
Good point.
Likes For tomato coupe:
#60
Liked 5,178 Times
as I recall there is difference between the rolling/rotational weight and weight you are carrying so not sure how much difference that would be.
So yes, you do have to weigh all the repair items, sealant etc to do a direct, true comparison. It might still work out lighter with tubulars, but you can’t ignore the weight of a spare tyre, which is going to be pretty significant in this comparison.
Dynaplugs are pretty effective for punctures that refuse to seal and I’ve never had to remove a tubeless tyre at the roadside. But I think the OP is already familiar with tubeless setups anyway.
#61
climber has-been
Quoted: 3605 Post(s)
Liked 3,794 Times
Likes For terrymorse:
#62
Rotating weight is the single most important performance aspect on a bike. Climbing effort is not just the static weight of the bike and rider combined, but overcoming the dozens of hard surges on each long climb. During these accelerations you'll be on the limit of popping off of the back. If you get dropped, woe is you.
So light wheels may only get you 5 feet of distance gain over a few miles, but this 5 feet is the difference between a cozy energy saving draft over the next XX miles, and the monumental suffering trying to connect back with the group, which may never happen. We all know the terrifying urgency of losing the wheel ahead; this is when light wheels make the difference.
Yeah, yeah, there is is this arbitrary UCI weight limit thing, but nobody checks this at low-level events and weekend warrior rides. Regardless, wherever possible, if its a matter of dollars, save weight on the wheels vs. the frame.
#63
Quoted: 1291 Post(s)
Liked 1,392 Times
Likes For Atlas Shrugged:
#64
Quoted: 2660 Post(s)
Liked 3,226 Times
I imagine that the OP is perfectly aware that carrying a spare tubular will defeat the purpose of buying the lightest possible wheelset but doesn't care---it's the thrill of owning what is potentially the lightest bike and wheelset he's after.
And it doesn't matter to the poster you're responding to that guys like RChung have proven through science-based studies that rotating weight is no more significant in races than weight elsewhere on the bike---it feels good to believe that he knows better than the science guys and the result of us.
Which isn't uncommon---there are still plenty of people willing to argue that aluminum frames absolutely are harsher-riding than steel frames, that titanium is the ultimate indestructible frame material, etc. No amount of evidence to the contrary will persuade them, either.
Likes For Trakhak:
#65
Liked 7,666 Times
#66
Liked 5,178 Times
See episode 4 below for more info.
https://www.swissside.com/pages/podcast
#67
Liked 11,368 Times
Such hyperbole.
Likes For Koyote:
#68
Quoted: 1468 Post(s)
Liked 2,108 Times
The difference in rotational vs static mass is insignificant when climbing. Total mass of bike and rider is all that matters in calculating how fast you will climb the mountain.
the dynaplug (or whatever) might seal the puncture - but tire can not be inflated … so tube is required to complete the repair / ride
#69
Liked 2,108 Times
not me - nuh uh … the groups I rode with were nasty … so nasty they only ate the heads off animal crackers
![Smilie](https://www.bikeforums.net/images/smilies/smile.gif)
Likes For t2p:
#70
With a mighty wind
Quoted: 1134 Post(s)
Liked 926 Times
I’ve had both.
The advantages of better cornering and rounder tires probably doesn’t exist anymore. Not nearly as many options for tires as there used to be but I doubt they’ll cease to exist any time soon.
Still, I would consider using the tubular in this situation.
You already have a great wheelset you’ll be using most of the time. The majority of your miles will be spent on relatively user friendly clinchers. That will cancel out most of the negatives of using a tubular setup as a daily driver.
Steep days where there may even be a car waiting for you on the top. Sure, go for it. It’s the wildly impractical second wheelset. It’s supposed to be fun.
I would love to lace up set of wooden wheels for my road bike. I’d ride them a few times a year.
A couple things I’d think about before getting anything, in this particular case, it’s a consideration for both wheelsets you’re looking at.
-Most wildly steep climbs tend to be on mountains that have frost heaves and potholes, descending those mountains can be fast!!.
-You’re probably not going to be able run tires larger than 28mm.
-What do you weigh? Hopefully not over 160lb.
Does this give you the heebie jeebies?
I’m not necessarily saying it should, but those things all need consideration in the ultralight world.
#71
Liked 5,178 Times
potential issue with tubeless flat is when the bead ‘unseats’ and will not seal again using the co2 or pump (or whatever) carried on the ride
Likes For PeteHski:
#72
Liked 7,666 Times
#73
Liked 11,368 Times
I agree, but never had that particular issue. But then flats are a rarity since I went tubeless. Literally 1 in 3 years and it deflated slowly enough not to unseat. It was actually on a pretty quick straight descent when I ran over a sharp piece of metal. I needed to plug the cut with 2 Dynaplugs to seal it, but it inflated fine with my mini-pump.
Would a tubular tire have worked as well in this situation?
![](https://cimg4.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x2000/hipstamaticphoto_723775616_697460_3ae029d7883402f3c9e30b390eb353b7b1b11229.jpeg)
#74
Liked 11,368 Times
#75
Liked 1,392 Times
Actually, giving you the benefit of the doubt I just assume you have no experience with tubeless. Once seated, especially after sealant been applied, it’s actually quite challenging to unseat tire and extremely rare occurrence when out ridding. Such a catastrophic failure would mean any other tire would have been destroyed as well. Throw in a tire liner and TPU tube and you are good to go.
