This Puch Bergmeister followed me home last night.
#51
Quoted: 3866 Post(s)
Liked 3,459 Times
Have had undamaged road bikes with the correct size wheels come through whose shells were as low as 9 5/8" and as high as 12 1/2". The latter figure is oft encountered in "19" " production bikes whose makers achieve the frame size by raising the shell. Not much help for the small rider concerned with standover clearance.
#52
Quoted: 1088 Post(s)
Liked 1,207 Times
Closing in on completion. Just need to file cotter pins, wrap bars, and finalize front derailleur. Cables and housings are still a bit long pending final adjustment...
#53
Polymultiplié
Bikes: Yes, please.
Quoted: 2220 Post(s)
Liked 4,793 Times
Looking good!
#54
Quoted: 137 Post(s)
Liked 6 Times
Can you explain some more on how you cleaned the white hoods. I have the same pair that have a yellow tint to it and it looks even worse since ive installed brand new white housing which makes it worse. Any other alternative products I could try?
#55
Liked 1,207 Times
Sure - I used a toothbrush, mild dish soap, and Bon Ami mild abrasive powder, just a bit. It's in a gold cylinder, and you can get it for 80 cents at Target.
I've heard you can also use Bleche White, which I understand to be for cleaning white wall tires. Haven't tried it, though...
#56
Liked 3,459 Times
One product I have found helpful for this is Soft Scrub cleanser. It has a mild abrasive which seems to do a good job at getting out ground in dirt/discoloration.
Like to finish up with an application of amine-free dressing for vinyl & rubber such as 303 Protectant.
#57
Bikes: 1978 Motobecane Grand Touring, 2015 Trek Speed Concept, 2010 Trek Madone, 2009 Kuota Kebel and a few more
Hey there!, great job, I wonder if you can share the technique for the 'bath' to remove the rust on the parts they look amazing! I'm leaving mine in copper color and putting on some Campy components that I had laying around from other projects. See updated pics in this link.
https://goo.gl/photos/FGsc438XAjvPF3y56
#58
Heck on Wheels
Bikes: In Signature
Quoted: 206 Post(s)
Nice Puch!
There have been many threads on rust removal in this forum. Unfortunately, the Forum's builtin search function is quirky. Try using a Google search with the inurl qualifier: "rust removal inurl:www.bikeforums.net/classic-vintage/".
I found this thread pretty enlightening. Abrasion, Evaporust, and Naval Jelly (Oxalic Acid) are all mentioned; only the 'Aluminum foil for surface rust' was left out :-).
"I had a great ride this morning, except for that part about winding up at work."
Bikes so far: 2011 Felt Z85, 80's Raleigh Sovereign (USA), 91 Bianchi Peregrine, 91 Austro-Daimler Pathfinder, 90's Trek 730 Multitrack, STOLEN: 80 Schwinn Voyageur (Japan)
#59
Liked 1,207 Times
As for the frame, I just sanded, but did not treat the frame at all. I want to ride it first and make a decision later, so I just sanded the worst of the pitted areas. If I decide to keep the frame, I'll most likely use some sort of rust converter and have it powder coated, or maybe rattle can. I really like the look of your bare copper frame, but the pitted finish on mine is wrecked, so I couldn't go that route.
#60
Went looking for the evaporust at my local walmart, didn't have it on stock but will buy it from another place thanks for the advise on this.~!
#62
Liked 1,207 Times
I'm calling this one finished for now. I need to ride it for a little while to decide on the saddle, and that will determine the bar tape color, so I am leaving them unwrapped for now. First test ride around the block indicates that the fit is perfect, but we'll see as I get more miles on it. This is not the first tear-down rebuild I've started, but it's the first one I've finished, and it feels good to have everything work properly, and to know that I did it right (for the most part).
I'd like to file the tab on the rear fender to get the fender line just so -- I've seen with other 27-inch bikes that it's difficult to get the mount high enough. I got a price quote for a powder coat, but likely will not act on it for a while, if ever. Brakes squeal like a banshee, so I'll need to clean the pads and rim surfaces, but they work just fine. Wheels pinged a few times, so my first wheel build is not without issue, but they are true and strong (for now).
#63
Liked 1,207 Times
#64
Liked 1,207 Times
Here are a couple of sunset glamour shots after a joyride. I managed to get the toe-in right to eliminate the brake squeal, and the trickiest part was getting the front derailleur dialed in so that I wouldn't toss the chain off of the rings. It's a bit kludgy a fix that involves a short length of housing, a Campy DT cable stop from a 72 Mondia (tossed in free when I bought a rear der some time ago), and two zip ties, but it feels rock solid now.
The long wheelbase allows 27 x 1 1/4's with fenders and no toe overlap...
#65
Liked 3,459 Times
What a fine job!
Beautiful work with Herr Bergey and with the documentation.
He's looking most excellent now.
BTW - Huret offered natural rubber covers for those shift levers in case it may be of interest:
(usual colour is an off-white/light grey)
Part nr. 1851 -
[IMG][/IMG]
What a fine job!
Part nr. 1851 -
[IMG][/IMG]
#66
Nice job!
Thank You for saving this bike, so far from its home. Hope it enjoys the new stable.
#67
Polymultiplié
Bikes: Yes, please.
Liked 4,793 Times
That turned out really nice! Well done!
#68
Liked 1,207 Times
Thanks, everyone!
#69
Liked 3,459 Times
Blade question -
Noticed his blades exhibit the characteristic Styria dimple on their inner face. They appear to be almost round at the top , become more oval out in the middle and return to round at the distal end. Is this correct?
It is almost as if the manufacturer is inviting the owner to fit larger cross section tyres than machine fitted with ex-works. Expect there might be clearance to run a 1 3/8" piece of rubber.
Blade question -
#70
Liked 1,207 Times
Blade question -
Blade question -
#71
Quoted: 7 Post(s)
Great job on that bike. When I read the header I first thought you picked up the most sought after Puch Vintage Racing Bike.
The Bergmeister with the split seat tube of the late seventies.
#72
Liked 1,207 Times
I just did a quick search and it looks like you're referring to the Puch Mistral Bergmaschine. No such luck, but it's for the best -- I would have been reluctant to do all of my own repair work and turn it into a beater commuter.
#74
Liked 1,207 Times
I'd be tempted to upgrade the rack if it hadn't arrived for the unbeatable price of "free." (It came with the bike.) I started polishing it, but I got impatient and just wanted to ride and have a place for my panniers. Also, I think it adds to the theft deterrent to have a blemished rack...
#75
Liked 3,459 Times
AND, it's a germanic rack for a germanic bicycle
one small bit you may wish to keep an eye out for is the Pletscher stabilizing/support bar. keeps the rack from slipping down the seat stays and means clamp does not have to be so tight. one may turn up at a co-op or junque yard near you..
Edit:
Just came across this image of someone mounting one inverted from its usual arrangement:
