Daytime Running Lights - Get Them! Video
#51
I'd be curious if just from automotive only perspective there's any evidence running lights make any difference. I feel like the number of crashes and number of ems response required crashes increases every year on my daily commute. I refuse to call them accidents because I believe in every case one if not both parties were doing something negligent and often negligently aggressive. I feel like a significant number motorists are living a 'Fast and Furious' fantasy life. All the safety equipment in the world won't protect from these offenders. In the case of responsible drivers I trust my own skills to fill the outlier examples. If one of the offenders get me... at least I died happy.
Also, even most lights used at night by motor vehicles and cyclists are waaayyy too bright. I can't say how many pedestrians and cyclists have been hidden in an oncoming vehicles halo only to be seen by me at the last moment. Vehicles behind can also generate some unsafe conditions by over saturating a drivers vision.
#52
If you're truly curious a 5 second Google search has the answer that you're searching for:
https://www.dot.state.mn.us/research...11/TRS1009.pdf
https://www.natlawreview.com/article...-car-accidents
etc.
etc.
etc.
etc.
#53
Quoted: 1816 Post(s)
Liked 1,346 Times
Yawn. Over in the A&S forum a cyclist was hit in broad daylight with a flasher going. At very, very high speed. I am amazed they survived at all. While nice, it is not essential that oncoming traffic see you, it is more important that trailing traffic see you, but it is even more important that you as a cyclist do not act unpredictably and force a motorist to accommodate your erratic actions. Because they may not, whether they 'see' you or not.
Likes For bruce19:
#54
climber has-been
Quoted: 3605 Post(s)
Liked 3,795 Times
"Crash situation categories
"Collisions in intersections were the most common crash situations representing 76.7% of all crashes. In 13.2% the cyclist was on the same road as the vehicle, travelling in the same or opposite direction. Door opening, cyclist running into car door opening comprised 4.3%. Whereas reversing and parking situations were rare"
#55
Cycleway town
The BIG problem with any flashing light in daytime or nighttime use is that drivers can't discern how far away you are from them. That's why i use a steady-on taillight as well as a flashing one at night. In the daytime I don't need or see the need for a DRL. Unless it's heavily overcast or raining.
Also, there's a HUGE difference between a fast-flashing light and a strobe or extremely rapid flashing light. the strobe-like lights are extremely annoying to those approaching.
Cheers
Cheers
That said, i find static ones worse, blending in with street lights etc. The small size of bike lights may be to blame, with smaller things appearing further away - a motorcycle with only a sidelight on is clearly a motorcycle against any background.
#56
Bikes: 50/34, 11-40, 11 Speed
Quoted: 142 Post(s)
Liked 73 Times
A front flashing, blinking or strobe light during the day really increases the visibility of vehicle drivers approaching from a side street. That's what I use. The same light works if you are in traffic and vehicles in front of you want to change from where they are to where you will be. For me, the light has definitely increased my safety in the situations I've described. I've seen the effectiveness of it. I also use a flashing rear light during the day too. That rear light is especially handy on places like PCH.
#57
Quoted: 2538 Post(s)
Liked 769 Times
Is the statement "...it is not essential that oncoming traffic see you..." statistically true? I ask because as an MSF instructor I can tell you that the biggest problem that motorcyclists face is oncoming cars turning into their path. It's some ridiculously high percentage of car/bike accidents. I don't know if something similar happens when cycling. But, I'd like to know.
A bicycle is not a motorcycle. Regardless of what a minority of cyclists believe, a bicycle should be operating much further to the right of the road position that is usual for motorcycles. Plus the bicycle is far slower. Plus the bicycle should be using a surfeit of caution at intersections and should NOT be the first one to blast out of the gate the nanosecond the light turns green. I have saved the day any number of times by expecting some <censored> to do something sideways like a last second turn left through the RED left turn signal. A huge no-no, but faced with the prospect of waiting (again) through the entire cycle of a complex intersection, some will risk it and run the fresh red light or left turn signal. Especially if its only a bicycle they SEE on the other side. And see you they will. Flashing light, steady light or no light, they see you. Even when distracted by their phone, they see you! However, distracted by their phone, they will not have their higher order decision processes online. They will not be driving defensively. A cyclist MUST be.
How many times have you heard cyclists say "ride like they can't see you"? Don't you find it interesting that with that mindset uppermost, some cyclists still invest a small fortune in lighting equipment and other hi-viz accoutrements to make themselves seen? Makes no sense. I am convinced that a lot of cyclists don't really know what it means to "ride like they can't see you"? It means eating a lot of humble pie when the contest is between a 220lb. rider/bike combination and a 5,549lb. driver/SUV combination. Don't even get mad. Don't try to get even. Just let it roll off and keep moving. Words to live by.
#58
Quoted: 1218 Post(s)
Liked 298 Times
I grew up under the False narritive that cyclist need to stay as far right as possible.
after a way too many right hooks, and people pulling out in front of me. (lights made no difference). I started taking my lane in the intersections. I have not had a single car right hook me or cross my path since taking my lane.
I think there are several things wrong with being on the right edge of the road. 1. you blend in with the objects along the road. 2. that is not where driver focus their attention. 3. if they do see you over there, you are just a slow bicycle. (if you are slow then a right hook won't really matter, unless you have no brakes, or are trying to brake from the hoods on a drop bar.)
I am not condoning being an ass to car traffic here. If I have a car behind me, I may slow to allow them to get to the intersection first, then I'll take my lane. I see it as all part of the flow and yielding to faster traffic. at the same time making my world the safest place possible for me.
Communication is Key too. Knowing that many people fail to use turn signals. I'll signal my intentions of going straight at intersections. This has had a few people turn on their turn signals, that otherwise wasn't using them, to indicate they are turning left across my path.
EYE CONTACT is important. If you don't have it, they probably don't see you. Even if you have eye contact, they might not register 'cyclist'. just part of being aware, and being ready.
this is all my experience, and my opinions based on my experience.
and the law by the way , at least here. Is not to ride as far right as possible. It is to ride as far right as safely possible. My view on that, don't impede traffic. Navigating an intersection is not impeding traffic, so use the lane. and be in the focus part of it.
acknowledge, communicate, be seen, be friendly, smile, all things that makes traffic better.
Likes For Metieval:
#59
Liked 1,346 Times
#60
Quoted: 1324 Post(s)
Liked 927 Times
Cheers
Likes For bobwysiwyg:
#62
Been Around Awhile
Bikes: Vaterland and Ragazzi
Quoted: 12 Post(s)
Liked 1,592 Times
#63
#64
Quoted: 800 Post(s)
Liked 218 Times
I have frequently posted:
Apropos of the advice cited above in this thread my aphorisms include:
a. Make yourself as visible as possible, and assume nobody sees you.
b, When riding at night, look for cars, not just headlights
c. To know where a car is going, watch the front wheels, not the body or hood.
d. You don’t have the right-of-way until the other yields it to you (learned from my teacher in driver’s ed)
e...i…
In particular, @Leisesturm wrote“ ‘ride like they can't see you’? Don't you find it interesting that with that mindset uppermost, some cyclists still invest a small fortune in lighting equipment and other hi-viz accoutrements to make themselves seen?.”
I interpret this to mean invest yourself with as much visibility as you want, but don’t think it is necessarily effective.
… Plus the bicycle should be using a surfeit of caution at intersections and should NOT be the first one to blast out of the gate the nanosecond the light turns green…Flashing light, steady light or no light, they see you. Even when distracted by their phone, they see you!
…Forget about eye contact; to be safe watch the front wheels of the vehicle. If the front wheels of the vehicle stat moving then either the driver doesn't see you or the driver doesn't care or is distracted.
So often on these threads about calamities or near misses, I post about my mindset that I believe gives me that extra edge.
I try to keep safe with certain aphorisms in my head that come to mind to alert me when I encounter a situation where unseen dangers may lurk, such as “Like a weapon, assume every stopped car is loaded, with an occupant ready to exit from either side.” or“Don’t ride over an area (such as puddles or leaves) when you can’t see the road surface"
Over the past few months I have come to realize that my safety aphorisms (link), collected over the years by personal or vicarious experience, are my way of actively aligning the stars in my favor, to anticipate those unseen and otherwise unanticipated dangers.
FWIW, for my own information at least, my other aphorisms beside those above [see the link: Total of nine (9)]
e...i…
… I feel like a significant number motorists are living a 'Fast and Furious' fantasy life. All the safety equipment in the world won't protect from these offenders…
…Regarding overkill, the few instances I have encountered have been on MUPS with oncoming cyclists with blazing, blinding headlights. I often think that they believe a cone of light is a force-field that will protect them, even from oncoming cars, so the more the better.
Here in Boston, most of my route is visible even with just ambient street illumination.
Likes For Jim from Boston:
#65
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
US DOT looked into it and found that DRL made no difference in accident rates, other than with light trucks I believe. There are various other studies, particularly in Northern European countries, that claim 5-10% reduction in crash rates. Some, like the US showed little or no crash reduction.
I strongly suspect that most if not all of the reduction of crashes from DRL arise from having them on during low light conditions at dawn and dusk. The countries showing the greatest reductions are also more typically have lower light conditions would bear this out. Personally I turn my lights on in those conditions religiously so I suppose I have daylight running lights in a sense, but I see no point in having them on during the rest of the day.
#66
Liked 298 Times
in 24 hours here we had 2 head on collisions, one was on the Phone, the other high speed and a corner. He went wide and crossed the center line on a curve. The third accident, a guy left the road and hit a telephone pole. 3 crashes where DRL wouldn't have made a difference, regardless of if they do or don't.
In short, drivers here are just flat out incompetent drivers. Stories I hear from friends, tells me that this sh***y driver problem is Nationwide. What safety measure would make a dent in crash reduction, other than quit giving out driver license like prizes in a cracker jack box?
my point is DRL will not fix stupid.
#67
Bikes: 84 Pinarello Trevisio, 86 Guerciotti SLX, 96 Specialized Stumpjumper, 2010 Surly Cross Check, 88 Centurion Prestige, 73 Raleigh Sports, GT Force, Bridgestone MB4
Quoted: 278 Post(s)
Liked 71 Times
I have owned motorcycles as well. Motorcycles have the speed and power to operate anywhere in the road a car does. Motorcycles are often to the left of the center of the leftmost lane. If not seen (noticed) by an oncoming car that is turning left there might be a collision. I suspect in a majority of these crashes the driver SAW the motorcycle, but ass-u-med that the bike would yield. Then after the fact the driver LIES and says they did not see the bike. It's hard to blame them. Are they really going to say, "yeah, I saw them, hit them anyway, sue me." What lawyer is going to allow his or her client to throw away their defense like that? Do motorcyclists understand that the "I didn't see you" is code for "I'm <censored> unless I can come up with a good excuse for running that poor sod over"?
I ride as if I am invisible. I also do not exceed the speed limits which helps.
The "I did not see them" excuse is a lie. They did see the motorcycle and are lie out their axx. I do not trust eye contact. I have developed a keen intuition over the years and usually will begin an evasive action before the cager even sees me (which they do) and then decides to ignore me which is the truth. Like a Spidey Sense from Spiderman.
The biggest concern I have on my bicycle is getting hit and side swiped from behind. Yeah cars will cut across me turning left just as on a motorcycle but again I just assume they intend to. But getting hit from behind is hard to take evasive maneuvers, some times there is nowhere to go. And this is the big difference between a motorcycle and a bicycle, maneuverable as a bicycle is, a motorcycle has, again, the speed, power and braking to out maneuver virtually any vehicle on the road, if I do not want somebody behind me, I hit the afterburner and they are not there any more.
I take that speed and power thing back, this Monkey, I ride it like it is a bicycle:
I have the flasher kits on my tail lights and on my head lights, and I am sorry, but they work and the same with the rear flasher on my bicycle. The flashers that get the most attention are those that have the double strobing type pulse or erratic flashing.
And there is plenty of evidence that daytime running lights on cars help. I had a cop pull me over once a few years ago when the running lights were becoming common safety feature on cars. He did a U-turn to pull me over. He was complaining (loudly) about driving with my headlights on in the daytime, so he could apparently see me. He told me to turn them off. I told him they were factory installed OEM Toyota daytime running lights and cannot be turned off but he is welcome to show me the switch, well there is not one.
Saying lighting does not help visibility is like saying airbags do not work if everybody would just wear their seatbelts. Airbags work and so do lights if properly installed and used.
Likes For Loose Chain:
#68
Bikes: 2 many
Quoted: 1266 Post(s)
Liked 323 Times
Laws of Discussion Forum Comments
1) One outlier negates all other data points and observations.
2) If nothing detrimental has occured for X years while performing act Y, nothing detrimental will ever happen.
Uh oh. A contradictory observation to law # 2. I'm guessing 10 years isn't long enough to be valid. Wait 10 more years.
#69
I don't think I've seen anything that says lights make me LESS visible so I'll continue to use them, even if it's a minor gain, along with every other option I can to keep myself safe.
#70
rebmeM roineS
Quoted: 654 Post(s)
Liked 348 Times
.Eye contact? Often not even possible between motorists and cyclists due to tinted glasses, tinted windscreens, reflections, glare, positioning, etc. I often can't see if a motorist is even looking in my direction, much less see their eyeballs.
#71
Liked 298 Times
This is from Wiki: 'Eye contact occurs when two animals look at each other's eyes at the same time.'
here I'll grab it for you
"Eye contact occurs when two animals look at each other's eyes at the same time. In human beings, eye contact is a form of nonverbal communication and is thought to have a large influence on social behavior."
So do you think that there is a possibility when someone says "eye contact" they might be referring to the "non verbal communication" between humans? Did i even need to add the "between humans" here? Apparently so, I mean it is a discussion about humans on bicycles and humans in cars.
#72
Quoted: 800 Post(s)
Liked 218 Times
…Communication is Key too. Knowing that many people fail to use turn signals. I'll signal my intentions of going straight at intersections. This has had a few people turn on their turn signals, that otherwise wasn't using them, to indicate they are turning left across my path.
…acknowledge, communicate, be seen, be friendly, smile, all things that makes traffic better.
When it comes to safety issues of bicycling, I consider the Aphorisms of Hippocrates, Greek, so-called Father of Medicine:
Life is short,
and art long,
opportunity fleeting,
experimentations perilous,
and judgment difficult.
and art long,
The alternative, “experimental” methodology was previously described, in this case about cadence:
…Extrapolating from individual experience, done on a trial and error basis, means: You think it worked better (or didn't work better) for you...
Roughly thats it, unless you were trained properly, in a controlled setting and tested in a validly designed and executed study. Then, if the results for a large enough group of people were taken in aggregate, anomalous factors accounted for properly, then those results would mean something more. In this thread...
Originally Posted by Pascal
–God is, or God is not.
–Reason cannot decide between the two alternatives
–A Game is being played... where heads or tails will turn up
–You must wager (it is not optional
Let us weigh the gain and the loss in wagering that God is. Let us estimate these two chances. If you gain, you gain all; if you lose, you lose nothing…
#73
Bikes: Nashbar Road
Liked 341 Times
But generally no, I don't you'd need to in order to get a general measure of accident reduction from using DLR. You'd look at total number of accidents, and break it down into discreet categories if you have the data.
Likes For wphamilton:
#75
1/2 as far in 2x the time
Bikes: Yes, Please.
Quoted: 499 Post(s)
Liked 285 Times
"Studies?..We don’t need no stinking studies…"
When it comes to safety issues of bicycling, I consider the Aphorisms of Hippocrates, Greek, so-called Father of Medicine:Many disputed safety practices, while maybe ineffective, are of themselves relatively harmless, e,g daytime lights, rear view mirror; perhaps less so, FRAP vs Take the Lane.
The alternative, “experimental” methodology was previously described, in this case about cadence:I like to consider the perceived risk benefit ratio (based on my own experience, and/or advice of trustworthy others). Or, not to be religious, but in a similar vein, consider Pascal’s Wager:If you believe in eye contact, you gain uncertain information, and may get get hit anyways...you lose. If you ignore eye contact, you gain nothing, but lose possibly uncertain information, and maybe a friendly smile.
If you ignore eye contact and stop, you don't get hit, and still may get the friendly smile.
I'm not sure why, but we just seemed on different wavelengths...Do me a favor, keep me out of your imaginary conversations. and I will in future, refrain from commenting on yours. Best regards, Eric
