Is the fully integrated cockpit inevitable?
#51
Quoted: 20810 Post(s)
Liked 9,456 Times
Likes For WhyFi:
#52
Quoted: 741 Post(s)
Liked 412 Times
Can't remember where I saw it, but they already thought up the variable width handlebar and length stem issue with integrated cockpits for road bikes. Ahh, the Canyon Aeroad. Not stem length, but IMHO that's a thing you should get a bike fit first. Then order the bike per your fit coordinates. Not the other way around, buying bikes then buying more junk to adjust the fit.
With TT bikes integrated cockpits already adjust up, down, pad width, pad tilt.
It will just take a while for the tech to trickle down cost wise.
Again though, the process is:
-get bike fit
-take coordinates to order a bike to those fit coordinates
-ride bike
The process is NOT:
-buy bike
-ride bike
-hate bike
-buy new random stem or bars for bike
-ride bike
-hate bike
-finally get a fit
-buy right stuff
-ride
-get bike fit
-ride bike
The process is NOT:
-buy bike
-ride bike
-hate bike
-ride bike
-hate bike
-finally get a fit
-buy right stuff
-ride
#53
Advocatus Diaboli
Quoted: 4813 Post(s)
Liked 1,553 Times
#54
Bikes: SuperSix Evo | Revolt
Quoted: 733 Post(s)
Liked 815 Times
Some are going more extreme than others, but yeah - aero concerns have more people looking at narrower options. I think that guys running 36cm are going to be outliers, but people nudging down and making 38-40 more common probably isn't a bad bet. I recently moved from 44 to 42cm, and think that I could certainly go a little narrower without ill effect.
Likes For Rides4Beer:
#55
Liked 9,456 Times
I bet - the bars on my gravel bike feel wide to me, too, more so that I would have guessed for 2cm difference. I suppose it's possible that they're being measured differently, though, and the the difference is even more than the nominal would suggest.
Likes For WhyFi:
#56
Sunshine
Quoted: 11097 Post(s)
Liked 7,695 Times
If the trend is for bars to go back to the widths they were between the bike boom and mid90s, I will happily add the trend to my long list of trends I dont participate in.
I could see someone adjusting their bar width between bikes based on trail geometry. A higher trail bike having wider bars for leverage and a lower trail bike having narrower bars.
#57
Liked 9,456 Times
Are you measurably more aero with bars that are 2.5" narrower? If not, whats the benefit? I dont know how I could even accurately measure how much faster I am due to 6cm narrower bars- so much of my speed(or lack of) varies on a given day due to how I am feeling that day, wind, surface quality, route I ride, etc
That said, cyclists have been able to measure the drag differences between balls, 2", 3" and 4" in diameter, using methods like RChung's virtual elevation; bars that are 6cm narrower should be much more significant and much more easily observed.
Likes For WhyFi:
#58
Sunshine
Liked 7,695 Times
So there's no benefit to something unless you can personally measure it? While you may not see the value in specific, small optimizations, in and of themselves, it doesn't mean that they're not there and it doesn't mean that they don't add up. Hell, much of the recent history of road cycling, both professional and enthusiast, has been shaped trampled by this concept.
I was asking if the gains arent measurable, what is a measurable benefit. Examples could be the narrower bars are noticeably more comfortable, or stable, or faster steering.
But if its just marginal gains, then cool. Thats as legit a reason as any, but I wasnt sure if there was something noticeable too.
#59
I eat carbide.
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 1326 Post(s)
Liked 1,307 Times
Narrow bars will be the Faux-hawks of the 2020's
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
Likes For Psimet2001:
#60
Quoted: 3261 Post(s)
Liked 2,582 Times
Interesting article. Pro and cons each way. To stay on topic though, you better get that stuff worked out before you get an integrated cockpit!
https://www.starbike.com/weightweenies/blog/?p=870
#61
I eat carbide.
Liked 1,307 Times
So...the blog - skinny and small dude. He could ride anything he wants and really not notice much of a negative physical effect....and yet has issues with narrower positions.
So to get back to what I was saying earlier....like long negative stems that are slammed and huge saddle to bar drops - these narrow bars will remain the thing all the young skinny kids will want because they think it looks cool and they believe it makes them faster.
Removing one's head will make you faster as well....at least aerodynamically.
#62
Quoted: 252 Post(s)
Liked 67 Times
I just came across this integrated cockpit assembly video, it leaves out quite a bit of the process to qualify as instructional video but still gives an idea how complicated it is. But if you master the process, so you don't need to backtrack because you forgot to slide some nut on the assembly, it is doable.
The only part I didn't get is at the start of the video, just 15seconds in. He tapes something on the top frame tube? I think what is seen at those 15s is the frame end where the seat post goes into the frame. No idea what that is about.
Otherwise I think that outside of the pro racing where it might do better in aero considerations, this will always remain and be motivated as a 'bad ass look' purchase for the top end of the bike lineups.
#63
Liked 9,456 Times
The battery for the groupset - looks like he's taping it in place while he connects the leads.
Likes For WhyFi:
#64
Quoted: 645 Post(s)
Liked 797 Times
Eh. I think that a lot of things will go wireless and electronic, but I don't see brakes on bikes going that route very soon. The liability of failure for a fly-by-wire braking system is just too high, even with redundancy (which would be a tough sell in road cycling [think of the grams!])
#65
Quoted: 733 Post(s)
Liked 815 Times
Are you measurably more aero with bars that are 2.5" narrower? If not, whats the benefit? I dont know how I could even accurately measure how much faster I am due to 6cm narrower bars- so much of my speed(or lack of) varies on a given day due to how I am feeling that day, wind, surface quality, route I ride, etc.
#66
Sunshine
Liked 7,695 Times
I don't have a wind tunnel, but as anecdotal evidence, I will submit that in the last year and a half or so of riding my regular loop 3-4 times a week, ~42 miles w/ ~3,000ft of elevation, I have only averaged 20mph once, and that was last spring, on my previous road bike, in good weather, with deep wheels. Well, that was until I got the new bike, not sure how much is attributable to the narrow bars, or the fact that Cannondale put some aero focus on the new SuperSix, but I have now averaged over 20mph four times in the last 10 days on that loop, all on windy days, with shallow wheels. I will allow for some new bike magic, but it has been consistently faster, and I would guess that at least some of that is due to my narrower position.
4 long rides in the last 10 days? And here i am looking forward to just getting out on a bike at all tomorrow!
#67
Quoted: 1814 Post(s)
Liked 923 Times
Bike I built last year I ended up having to narrow down to 42 form 44. I haven't gotten smaller so I am not sure why other than maybe something has changed as I have gotten older. That said we have always run narrower bars at the track. The pro ranks are pushing ridiculously narrow bars and the elimination of the IAB position by the UCI will simply lead to more of these flexible and death wish prone 20 something racers wanting to push the narrow bar look.
Think of them as the handlebar bags of the pro peloton.
Do you mean like the 38cm bars that were normal in the '60s-'70s?
#68
Quoted: 4889 Post(s)
Liked 4,053 Times
I'll stay away from these integrated cockpits. I hear the "fit is everything" but I can set up a new rig as an exact copy of the fit of another bike and I am still going to tweak stuff. Handlebar height and rotation. Lever placement. (In recent years I've started rotating my bars and levers far down so my wrists are turned down to avoid hand numbness and pain, both riding and after. Nobody is going to make tooling for what my hands need.)
And last, the idea that anybody can fine tune my fit better than I can out on the road with a wrench?
Likes For rubiksoval:
#70
Likes For aclinjury:
#71
Liked 9,456 Times
Likes For WhyFi:
#72
Quoted: 850 Post(s)
Liked 344 Times
Corollary: Wireless shifting and hydraulic brakes will become the only option for high end or even mid-grade groupsets in the future. Hell, it's basically true already.
Likes For smashndash:
#73
Quoted: 850 Post(s)
Liked 344 Times
I have 38cm bars too but somehow that seems more acceptable to people.
#74
Bikes: bikes
Quoted: 2622 Post(s)
Liked 1,429 Times
I'm 5' 7" and people have an aneurysm when I tell them I ride 165mm cranks. I watched a bike fitter have a meltdown over it. I have a friend who's 5' 5" with legs so short that he couldn't ride a size S emonda (seat mast wouldn't go low enough) and even he was told he didn't need anything less than 170s.
#75
Liked 4,053 Times
Black woman in the pilot's seat, Hispanic co-pilot? I think we are still a few years away. (But I can dream.)
How 'bout black anodized stem, gold anodized bars. Now I could ride that. It would look good on my Mooney.
