Ruler and Chain Checker are Diverging
#51
The roller isn’t wearing. The pin wears and allows the roller to follow something of an elliptical path as it goes over the cog and chainwheel. New chains follow a circular path so they engage the pitch of the cog and chainwheel properly so they don’t wear the edges of the teeth like a chain where the rollers can shift.
The question I have for you is how do your propose to measure roller wear if that is what you think is causing the problem? I can think of no way to measure roller wear separately from pin wear. It is possible, and even quite common, to measure secondary effects to measure a primary phenomena. In chemistry, for example, we often react two chemicals together and then further react the products of that reaction to see what the concentration of the unknown of the first two chemicals are. Pin wear and roller wear are related. Measuring pin wear also measures the effect of the rollers on the cogs.
Frankly, if you are worried about cog wear, you should probably be using one of these. I have one but find them to be mostly useless.
And why would you need to measure roller wear separate from pin wear? They work together to create pitch. That's what a chain checker does: Measure the composite of pin and roller wear.
![Kontact is offline](https://www.bikeforums.net/images/statusicon/user_offline.gif)
#52
Mad bike riding scientist
Liked 4,335 Times
![](https://cimg4.ibsrv.net/gimg/bikeforums.net-vbulletin/400x267/73e24df5_ffaf_4336_9ec5_9d644d3fe708_e2288614594e88031f27978acef03d4bacaaf9bc.gif)
![](https://cimg5.ibsrv.net/gimg/bikeforums.net-vbulletin/400x268/f6575438_9f36_44a9_83f1_ce9dab4019d3_e89085e9fa6b92d5a8faf63fc1ce844027a9b2d3.gif)
Stuart Black
Stuart Black
![cyccommute is offline](https://www.bikeforums.net/images/statusicon/user_offline.gif)
#53
Have you ever observed any kind of growing on a roller? Since the roller is wider than the chainwheel or cog they are rolling over, it should be readily visible. Sheldon Brown has two pictures of extreme chain wear that are illustrative of how chains wear. You can see several different wear patterns on the pin and on the plates. I’m not sure what to call the bit of the plate that stands up away from the body but you can see that is is worn to match the wear in the middle of the pin. The roller may wear it a little also but the pin is seeing the highest concentration of the pressure of riding and the most wear. The whole chain becomes worn and the rollers fit sloppily inside the chain itself.
That’s just a restatement of what I asked you. How would you measure them separately? You are the one who brought up the issue so it is up to you to resolve it. The rest of us use the tools we have a hand…either ruler or a chain checker.
Simultaneously
With a chain checker.As I said in the first place.
And if rollers don't wear, that makes the OP pretty mysterious.
#54
Liked 619 Times
I have a Mitutoyo dial caliper on my bench so use Campagnolo's hard rule that you toss anything over 132.60mm which, though I have not checked, might be just under 0.5%. It is quick and easy and chains are relatively cheap so I follow their advise to "immediately" replace if even one measurement is over 132.60mm.
![easyupbug is offline](https://www.bikeforums.net/images/statusicon/user_offline.gif)
#55
Sock Puppet
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Liked 863 Times
Some people put so little energy through their drivetrains that discussions about chain wear, lubricants, etc seemingly don't apply to them. Congrats on your long chain life - you really must not be hammering. You're in the same class of people that go years on the same disc brake pads and object when anyone says they wear quickly - there's always someone like that on a bike forum.
My disc brake pads actually lasted 5000 miles before the rear needed replacing and the front still had life left. Somehow soon after, both pads became contaminated and needed to be replaced.
![Lombard is offline](https://www.bikeforums.net/images/statusicon/user_offline.gif)
Likes For Lombard:
#56
Liked 2,621 Times
This is my attitude, too. I am pathologically conservative of many things. I compost when I can, I recycle glass, paper, aluminum, blah blah blah. But I do not squeeze all the life I can out of my chains. It's the one place where I allow myself to be wasteful. Cleaning chains is not rewarding, and neither is replacing worn cassettes. Change the chain more often than you should. That's all.
![noglider is offline](https://www.bikeforums.net/images/statusicon/user_offline.gif)
Likes For noglider:
#57
Liked 4,335 Times
Simultaneously
Stuart Black
Stuart Black
Likes For cyccommute:
#58
And around and around we go. There isn’t a way to measure pin and roller wear separately.
Captain Obvious has just sailed into view!.
Rule or chain checker will work. I don’t object to rules as long as someone isn’t trying to convince me that estimating the measurement is “more accurate”. Personally, a chain checker is quicker and easier and just as good. I’ll go with a chain checker every time.
Captain Obvious? More like Captain Oblivious. Geez.
#59
Got a new bike in early December but only 1500 miles on it due to Covid recovery. Took off the chain and cleaned it yesterday. Hung it on a nail alongside a new and degreased chain. Zero wear. Both were exactly the same length. I guess I have no wattage or the Silca wax is doing its job. At $75 per chain, $400 per cassette, and $881 for rings, I'm not guessing on chain wear. It ain't take no rocket surgeryist to remove no doubt. 0.4% and they are in the bin. I have cassettes with over 30,000 miles that are fine.
Pads? I am halfway thru my second set!! I am either fat, brake too much, disc brakes suck, too much rain, too much salt on the road, it is too hilly here or a combination of these.
![GhostRider62 is offline](https://www.bikeforums.net/images/statusicon/user_offline.gif)
Likes For GhostRider62:
#60
Expired Member
Would anyone like to speculate as to why 11speed and up should be replaced at .5 (or whatever fractional corresponds) vs the older .75?
![shelbyfv is offline](https://www.bikeforums.net/images/statusicon/user_offline.gif)
#61
Purely speculation, though.
#67
Liked 1,420 Times
Got a new bike in early December but only 1500 miles on it due to Covid recovery. Took off the chain and cleaned it yesterday. Hung it on a nail alongside a new and degreased chain. Zero wear. Both were exactly the same length. I guess I have no wattage or the Silca wax is doing its job. At $75 per chain, $400 per cassette, and $881 for rings, I'm not guessing on chain wear. It ain't take no rocket surgeryist to remove no doubt. 0.4% and they are in the bin. I have cassettes with over 30,000 miles that are fine…
![](https://veloviewer.com/SigImage/4f56090/2/5/I/s/jlnizznmij.png)
![mschwett is offline](https://www.bikeforums.net/images/statusicon/user_offline.gif)
#68
Measuring my own (non campy) chains from new, in the way recommended by campy, they measure right about 132.25mm according to my digital calliper. 132.6mm is then 0.26% "wear" before binning it, and the campy method even includes roller wear (enlargement of the hole in the roller, - the outer diameter stays roughly the same), that in my experience is more pronounced than actual chain elongation. Seems overly conservative to me and I've certainly gone much further with no issues. 133+ mm before I even consider replacing the chain.
![Racing Dan is offline](https://www.bikeforums.net/images/statusicon/user_offline.gif)
#69
Good question. Who came up with these values and why. Industry standard is 1% and there is no logical reason it why its either 0.5% or 0.75% depending on 10s vs 11s. In shimano cassettes the actual cogs are identical in 10s vs 11s. Only spacing and # of cogs differ slightly. Not to mention its unclear if its 0.5% actual elongation or roller wear should be included. Park used to have a tool that included roller wear, now they have one that doesn't, but the recommended values stay the same even if different methods give very different results. Makes no sense what so ever.
#70
Liked 4,335 Times
Good question. Who came up with these values and why. Industry standard is 1% and there is no logical reason it why it’s either 0.5% or 0.75% depending on 10s vs 11s. In shimano cassettes the actual cogs are identical in 10s vs 11s. Only spacing and # of cogs differ slightly. Not to mention it’s unclear if its 0.5% actual elongation or roller wear should be included. Park used to have a tool that included roller wear, now they have one that doesn't, but the recommended values stay the same even if different methods give very different results. Makes no sense what so ever.
The rule method, by the way, replaces chains at 0.5%. 0.75% would be 3/32” and 1% would be a full 1/8”.
11 speed and above chains are thinner with regards to overall width. Perhaps the thinking is to replace them at 0.5% since the pressure on the pin is greater.
Stuart Black
Stuart Black
#71
Liked 619 Times
Really?
#72
Liked 4,335 Times
Again, my main objection to the rule method is the use of a 12” rule and the estimation of the 1/16” wear while simultaneously claiming that the rule method is “more accurate”. Get a 13” rule and I’d have zero problems with the method. I still don’t think it is more accurate than a chain checker.
Stuart Black
Stuart Black
#73
Pin wear and any roller wear (which is vanishingly small) are combined in any measurement you make on a chain. I will not say that chain checkers are more accurate or measure roller wear over the rule method. The amount of wear measured with both methods is the same and either method can be used. I find the chain checker to be quicker to use with the same result. If you think differently it is up to you to demonstrate how the measurements can be disconnected.
You can disassemble the chain and remove all the rollers and it will be the same length when you put it back together without them.
#74
Liked 596 Times
![sweeks is offline](https://www.bikeforums.net/images/statusicon/user_offline.gif)
#75
Liked 619 Times
The rollers have zero influence on how elongated the chain gets from pin and link wear and absolutely will not show up if you measure the chain with a ruler. Pin to pin distance is entirely a measure of how the inner links and pins contact each other. Having a ring around the two won't change that.
