cross wind question
#51
What you've said may be true, but that's besides the point. I'm sure I've ridden at 18mph in both 15 and 20mph crosswinds, even if measured at ground level. In fact, I've ridden in much higher winds. Granted, I am slower in heaver crosswinds, but then the apparent wind angle only increases and emphasizes my point. I was merely demonstrating that it is not rare and definitely not unrealistic to have apparent wind angles of >30 degrees.
#52
Bikes: Many
You might be interested in this https://forum.slowtwitch.com/Slowtwit...24mph_P2474619 and the interview with Josh Poertner referenced there https://nyvelocity.com/content/equipm...-josh-poertner
I would say that the rarity of the situation is not as extreme as he is allowed to claim in an interview, but there it is.
#54
Have you ever met or talked to Josh? Having had many exchanges with him, I believe him to be as honorable as any researcher I've ever met. For implying that he would distort the science to suit the marketing, I believe an apology is in order.
#55
I am going to simplify the math somewhat, but basically: If you do a vector force analysis you will discover that the side force that the rider is feeling has to be countered in some manner or the rider is going to be knocked over. That is done by the rider and bike leaning into the wind. The force is now balanced in such a manner that it is transferred to the ground. In effect, you and the bike get heavier.
It might seem counter-intuitive at first glance. Now, how much force and how much effect is questionable and nearly impossible to calculate, but I would guess it is pretty small in the big scheme of things.
In my experience dealing 30+ mph crosswinds, the force can be very significant as noticed during gusts where a sudden change in wind direction can mean moving a few feet laterally on the road. It's quite normal to find the relatively heavy trash bins blown all over the street during the high wind days which demonstrates the amount of force the wind can apply to an object with a decent cross section.
#56
Bikes: Many
This thread is becoming silly. I'm sure that Zipp guy is great, but it doesn't change the fact that heavy crosswinds are not rare, depending on where you live. Who cares if I ride slow and average 16 mph during the winter? Doesn't change the fact that occasionally the 20mph winds here do create a high apparent wind angle. This entire argument is tangential to the original argument about whether or not deep rims reduce "work" in heavy crosswinds anyways.
#57
In the meantime, as I said above, we have lengthy explanations by the leaders in the field of cycling aerodynamics explaining what yaw angles are reasonable, and then we have you saying in effect "I refuse to believe it."
#58
Bikes: Many
Nor does any of this change the fact that you impugned the honesty of someone you don't know. I guess in a couple of days we'll get the clarification of what you really meant.
Like I said before, I'm not talking about 90% of riding conditions. ZIPP wheels are manufactured for efficiency in 90% of riding conditions. We are talking about heavy crosswinds. It almost sounds like you are denying that heavy crosswinds exist. Pretending that "leaders of the field" agree with you doesn't make it so.
#59
Bikes: Many
I was using the layman's definition of efficiency. You get the point.
Places near where I live: https://www.wunderground.com/weathers...p?ID=KMACAMBR9
https://www.wunderground.com/weathers...p?ID=KMAMEDFO7
#61
Keyword here is "suppose."
#62
Bikes: Many
Calculations based on this: https://en.wikipedia.org/wiki/Wind_gradient
It's reasonable to estimate that at 1 meter the wind speed is 70-90% of the wind at 3 meters off the ground. But even if it was 50%, the angle is still >30 degrees with 30mph gusts.
I can see that this conversation has basically run its course.
#64
serious cyclist
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times
#65
Bikes: Many
Bikes: Many
Furthermore, "the ground", as Bah Humbug is probably talking about, refers to the anywhere that you can reasonably cycle. I'm pretty sure that if you ride up an exposed mountain pass or along the coast, winds can get pretty high on "the ground".
#69
Bikes: 2006 Cannondale CAAD8
Yes. On the ground isn't referring to 1cm above the ground- it usually means .5m to 1.5m from the ground.
#70
Bikes: Many
#72
Why do you think it's pointless? All viscous flow is based on the hypothesis of what happens "on the ground" To understand precisely what someone believes is the operating physics on the ground is crucial for understanding everything about their analysis of viscous flow. In other words, it's impossible to understand what happens at 1 m, if you don't understand how "on the ground" is treated.
#73
I understand your question. Unfortunately you can not assume everyone will know what you mean. Like asgelle said, on the ground means something totally different to different people studying different things. If you want to know if a cyclist ever experiences 20mph winds at their respective height, that is a different question.
#74
Bikes: Many
I'm not a mind reader. To me "on the ground" means "on the ground," 0 elevation. To someone studying non-continuum flows, 0.1 micron is way off the ground. To an astrophysicist, 10,000 m might well be considered on the ground. There's a really good word for distances slightly away from something else, it's called near. For example, "Do you believe the wind speed ever reaches 20 mph near the ground?" Though in the context of this discussion, it would be better to ask "Do you believe the wind speed ever reaches 20 mph 0.5-1 m above the ground?" None of those was the questions asked.
I was talking about how wind speed affects wheel performance. Wheels are on average about .4m off the ground. Cyclists are on average 1-2 m from the ground.
If this were a engineering forum, I would have used more specific language. It was a mistake on my part to assume that you could gather from context that "on the ground" was not meant in the most literal sense of the phrase.
#75
Bikes: Many
I think, as someone stated earlier, we aren't actually disagreeing on anything besides definitions. Let's lay this thread to rest.
