Carbon wheels on a gravel bike worth it?
#76
Thread Killer
Quoted: 3246 Post(s)
Liked 1,799 Times
Bike came with a set of 42mm Travail Cannonballs (protection model) that weigh 540g ea installed. I ditched the tubes and put them on the Zipps tubeless. Just got home from a 30 mile shakedown ride and the bike felt great. So much easier to get up to speed and they upped the compliance a bit too. I took it down a brick road that I went down last week with the other wheels and it was immediately apparent that there was some added comfort with the new wheels as well. Very happy with my purchase so far!
#78
Advanced Slacker
Quoted: 2769 Post(s)
Liked 2,553 Times
CF rims are not inherently more fragile. They can be a lot stronger than AL at the same weight... or a little stronger at a little less weight... or just as strong for a lot less weight.
This has been pretty well settled in the MTB world.
Not sure if this has been posted:
The fact that some stupid light CF rim failed is not an indication that there is a problem with CF... it is that someone tried to take the lightness thing too far.
Now, is it “worth” it? Depends on your financial situation. The benefit of CF is going to be the same regardless, but the pain in one’s wallet or purse is going to depend on how fat said wallet or purse is.
Likes For Kapusta:
#79
Quoted: 7 Post(s)
Liked 5 Times
I weigh north of 200lbs and have been through 2 velocity blunt 35's in 3 years, both cracking at spoke holes, both hand built by LBS and a qualified builder. out of frustration I'm going to give building a go myself. after reading too much on the subject I'm going to try a 35mm deep, asymmetric hookless carbon rim with dt aero comp spokes. I will reuse the dt swiss 240s hubs and continue to run them tubeless(schwalbe g-one all around). after discovering the alloy velocity's cracking agin (rear drive side and some on rotor side front) I checked spoke tension with park tool deflection gauge and they are within velocity's specs and even across wheel. my assumption is my weight is contributing factor or the blunts just aren't the hoops for me.
#80
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
Likes For franswa:
Likes For nagakuraruan:
#86
