UAE On Rim Brakes
#76
On Your Left
Quoted: 3004 Post(s)
Liked 2,434 Times
Likes For Ed Wiser:
#78
Quoted: 3261 Post(s)
Liked 2,581 Times
Likes For seypat:
#79
Quoted: 8432 Post(s)
Liked 9,371 Times
#80
I thought I remember seeing that even the carbon layup was specific to each rider. Don't ask me to back that up but I thought that was the case. In any event I really don't think its even remotely a challenge for these bikes being used in The Tour to made with discs at the minimum weight limit, regardless of manufacturer.
#81
#82
Quoted: 4611 Post(s)
Liked 5,155 Times
#83
Quoted: 338 Post(s)
Liked 408 Times
With tubulars it's fairly easy to reach the 6.8kg at UCI weighting rules (with pedals, bottle cages, transponder and Garmin mount) on a light disc brake bike. If the frame is heavy (as some aero ones are) or you are not running tubulars, it becomes more difficult and the weight savings become somewhat relevant.
They aren't choosing rim brakes for their superior braking performance.
#84
Quoted: 4038 Post(s)
Liked 7,619 Times
I heard from a reliable source that the reason they switched to rim brakes was that they traded their disc brake rotors to another team for spare tubes. Apparently, supply chain issues are hitting the TdF pretty hard.
#85
Liked 2,581 Times
What I heard was that because of the steel shortage, their team food preparers were having a hard time getting blades for their meat cutting machines. They had to convert a lot of the disc rotors to cutting blades. They also had to get some of their beef out of Spain, so we might see a few failed drugs tests in the near future.
Likes For seypat:
#86
Quoted: 20810 Post(s)
Liked 9,456 Times
Well, that was dumb of them to trade for tubes. Don't they know that they're ~55% less likely to win a Le Tour stage with clinchers vs tubulars?
#87
Liked 7,619 Times
#88
Bikes: Pinarello; Canyon; Lauf
Quoted: 75 Post(s)
Liked 48 Times
I started riding again last year due to the pandemic and my rim brake equiped bike promptly started to overheat and emit a burned rubber smell as I was descending at around 35-40 mph; I started losing confidence in my braking. I switched to a disc brake equipped bike and although it still overheats during fast descents (and does require some adjustments to reduce brake rub), there is no smell and I have more confidence in my braking power. During foggy/wet conditions, it's no contest.
With lighter bikes these days, the argument that rim brakes are lighter is not an argument, anymore. It's all about what you're used to and pros do not like change as stated previously.
Likes For msu2001la:
#90
Quoted: 1467 Post(s)
Liked 1,495 Times
Also, it seems pretty clear that the main reason they switched was so that they could tell the riders they were getting special climbing bikes that were definitely faster than their regular bikes.
#91
Liked 9,456 Times
Likes For WhyFi:
Likes For melville:
#93
THIS.
The whole move to disc brakes is money driven. Cheap for manufactures to make one style of bike than two. The cycling industry is so centralized on a few equipment markers now days compared to years ago. When there where many equipment group makers. It’s funny when people talk about bikes now days. Perrry much everyone is using Shimano. To the point that everyone is riding the same bike.
#94
Quoted: 75 Post(s)
Liked 48 Times
would make sure you buy good disc brake wheel if you are causing brakes to heat up like that. Disc brakes require a very good spoke set up. As the force to stop is carried by the spokes. Rim brakes use the rim itself.
#95
Liked 7,619 Times
They both transfer the stopping force via the spokes.
#96
Liked 2,581 Times
#97
Habitual User
Quoted: 5105 Post(s)
Liked 8,416 Times
#98
climber has-been
Quoted: 3586 Post(s)
Liked 3,771 Times
#99
Liked 2,581 Times
Likes For seypat:
#100
Liked 5,155 Times
That must have been a very long time ago. I've been cycling for 40 something years and it's always been Shimano vs Campag in that time (except for Suntour on cheaper setups). SRAM wasn't even on the scene in road bikes back then and only had their grip-shift. What others did I miss?
