View Poll Results: How does a bicycle steer?
Voters: 50. You may not vote on this poll
#76
Quoted: 4645 Post(s)
Liked 5,180 Times
#78
Quoted: 1816 Post(s)
Liked 1,346 Times
Interesting video. Has anyone tried building a no-steer bicycle like this?
https://www.youtube.com/watch?v=8VqXBA-sGHA
#79
don't try this at home.
Quoted: 989 Post(s)
Liked 539 Times
An entertaining video from Mike Boyd, while he attempts to ride a bike with a geared steerer that turns the wheel the opposite way of the handlebars.
The backwards bike
Minute Physics
How do Bikes Stay Up?
"Bicycles can ride themselves. Yes, once they are set in motion at a sufficient speed, bicycles can stay upright without any human intervention."
This interesting video explores the various inputs that affect a bike's steering.
The backwards bike
Minute Physics
#81
Dirty Heathen
Quoted: 897 Post(s)
Liked 950 Times
Countersteering has a different meaning when applied to cars, as opposed to two-wheeled vehicles. It’s a different technique, done at different times, for different reasons, between two-wheel cycles and 4-wheelers
The confusion comes from that more people are familiar with the car term, and are trying to understand bicycle physics, using “car” as their frame of reference.
If you’ve done any basic motorcycle training; you’d have probably heard the phrase “Push Right, Go Right “ to initiate a turn. That’s where counter steering comes in to begin the whole progression of calculus-based physics that describes how a two-wheeled cycle goes around a corner.
For a typical motorcycle, going at normal road speeds, that “Push “ is only a couple of pounds of force; because a bicycle weighs 1/200 as a moto, the force needed is correspondingly small; grams, literally; and so fleeting as to get lost in the noise of tactile feedback of riding a bicycle.
On a moto, even after it’s become second nature, you still have to make those distinct inputs in order to “steer” the bike; on a bicycle, though, those inputs are nigh-on imperceptible, unless you’re really railing it; and then you still have to be aware of it.
Likes For Ironfish653:
#82
Liked 5,180 Times
In UK motor racing we use the term “opposite lock” for car corrective steering input when the rear starts to slide out. It has nothing whatsoever to do with the dynamics of bicycle/motorbike countersteer to initiate a turn.
Likes For PeteHski:
#83
Liked 1,346 Times
Likes For bruce19:
#84
Thread Killer
Quoted: 3271 Post(s)
Liked 1,813 Times
The rub here was posted way back up in reply #8; it’s not always a different technique between car and bike/moto. Put a bike/moto in a drift, and countersteering is done for the same reason it’s done in a car.
Ergo my point about semantics being the source of the confusion, and maybe if countersteering is just how a bike needs to be steered (at least above a certain speed), it should be called something other than countersteering.
Even though steering a boat with a tiller always requires countersteering- i.e. the tiller is turned opposite the direction of the turn— it’s not called countersteering, it’s just steering, because that’s how it has to work.
It strikes me as tidier to accept countersteering is just how bikes/motos have to be steered and to save the countersteering term for when it’s an actual technique addressing a handling situation, such as in a rear wheel skid-out or drift. That would harmonize the meaning of the term with the automotive world.
I know that’s not going to happen, but some form of distinction would save a lot of the silly misunderstandings that occur whenever the discussion is had.
#85
Liked 5,180 Times
The difference with 2-wheeled bikes is that most people don't realise that turns are initiated by initially turning the bars in the opposite direction to the turn (counter-steer) simply because it is unintuitive. Just calling it "steering" is not very useful in explaining how the process actually works.
Likes For PeteHski:
#86
Quoted: 208 Post(s)
Liked 109 Times
I'm curious if I am cheating the countersteering rule when I turn my bike in this fashion: I'm riding my little cruiser which has about 90% of the weight on the back wheel. I'm in a left turn, and to turn to the right I take the front wheel off the ground, and while leaning the other way I turn the wheel right and when it contacts the ground I'm now in a right turn.
#87
Quoted: 1467 Post(s)
Liked 1,495 Times
Now we’re getting somewhere!
Likes For msu2001la:
#88
Thread Killer
Liked 1,813 Times
#89
Dirty Heathen
Quoted: 897 Post(s)
Liked 950 Times
One of the main differences between cars and cycles going around a turn, is that where a cars center of gravity is always between it's wheels, its very hard to roll over during a turn (on flat, dry pavement, without some outside interference)
A cycle (moto or velo) has to lean to the inside of a turn, to keep from turning over to the high -side (outside of the turn). Cyclists believe this is accomplished by simply shifting ones weight; motorcyclists know that it takes a distinct input to the bars to initiate the turn: Push Right, Turn Right; actually steers the front wheel to the left, and now the CG is to the right of the wheel track, so the bike starts to fall to the right. Cycles, particularly motorcycles, want to stand up and go straight. You actually have to steer against that, in order to hold the line on a sustained turn. Go in to a long, fast turn like a cloverleaf ramp, and you'll realize that you're having to hold that pressure against the inside grip, to keep the bike going around the turn. Basically you have to steer against the force trying to throw you off the outside of the corner.
Riding a motorcycle, you notice this much more, because while the forces and inputs involved aren't dramatically high, they are hundreds of times higher than what's required to affect a similar change in direction on a bicycle.
#90
Thread Killer
Liked 1,813 Times
The main source of confusion is that we're using the single term "Countersteering" to describe two different techniques, done for different reasons, at different times, between cars and two -wheel cycles. You've got the automotive version, also known in motorsport as "Opposite Lock" down solid, although it really doesn't apply to cycles, except, as you mentioned, a skid or drift situation; which very few cyclists, and road going motorcyclists encounter; so again, trying to describe the handling of a two-wheel cycle, using "car" as your reference.
#92
Dirty Heathen
Quoted: 897 Post(s)
Liked 950 Times
I don't understand the purpose of creating a carve-out by saying few cyclists encounter countersteering as it's used in cars. It does not seem at all rare to me; it happens all the time in MTB, and nearly every kid goes through a skidding phase. And the fixie guys? C'mon...
The Car definition of countersteering, also known as Opposite Lock, or “Backing it in,” or “Getting Crossed Up” is what you do to correct or control a slide, drift, or oversteer condition, where your rear wheel(s) are to the outside of your line through the turn. Essentially, you’re pointing the front wheel(s) in your intended travel direction, because the rest of the vehicle is not.
The Moto/Velo description of countersteering -“Push Right, Go Right,” ie: initiating and controlling a leaning turn, on a two-wheeled, single-track vehicle by applying pressure to the end of the handlebar on the inside of the turn, happens every single time you make a turn above walking speed.
They are not the same thing, and I don’t use the term interchangeably.
#93
old newbie
Bikes: Specialized Roubaix
Quoted: 602 Post(s)
Liked 405 Times
https://youtube.com/shorts/ePusygscM...k8lht3MQsbIMof
Some are confusing counter steering with steering into a skid.
Counter steering is a small input-very slight pressure on the handlebars.
Steering into a skid is a much larger movement.
#94
Thread Killer
Liked 1,813 Times
Because it’s the same word, applied to two different techniques, done at different times, for different reasons.
#95
Quoted: 7740 Post(s)
Liked 3,683 Times
How does a steer bicycle?
#97
Liked 5,180 Times
I think you've gotten confused, because you seemed to understand before that your "car definition" above is also applied when cycling/moto. It's what's pictured upthread in post #8, it's what's shown in the video in post #90, and it's what you said happens in post #89 when you wrote, "You've got the automotive version, also known in motorsport as "Opposite Lock" down solid, although it really doesn't apply to cycles, except, as you mentioned, a skid or drift situation."
Ironfish653 was simply pointing out (very clearly) that they are completely different scenarios. The only thing in common is that they both involve a steering input in the opposite direction to the turn (countersteering).
Likes For PeteHski:
#98
Thread Killer
Liked 1,813 Times
Judging from your persistent engagement with my posts, it's clear you were "overly distracted," too.
#99
Liked 3,683 Times
I see this is a poll ... are we to understand that "How a bicycle steers" will be decided by this thread? How exciting!
#100
Liked 5,180 Times
No need to move the goal posts to get me to agree with that, as my interest here has always been about the use and meaning of the term countersteering, not in a generic discussion about how bikes steer, particularly not in a single, arbitrarily defined condition.
