Tire Pressure calculator Comparison and Accuracy
#76
Ah ok, it doesn't show that part on my phone for some reason. That's a safe pressure, but takes no account of rider weight, road conditions or rim width. It isn't likely to be optimal for either speed or ride comfort for most riders. Pirelli at least provide a weight and rim width chart and suggestions for dry vs wet conditions and also front vs rear pressures. Of course you can run them at 95 psi and not worry about it, but you will likely find gains from using the lower pressures from the Silca calculator.
i remember that with Continental GP 4500/5000 - 23 mm I used 10 PSI below Continental recommendation. I used to trash 23 mm rear tires after around 9000 km and it was not due to rolling surface wearing, but due to side walls wearing.
The above suggests me that using the much lower pressures from the web calculators might decrease the life of the tire due to premature side wall wearing. At least for Continental GP 5000.
#77
Quoted: 4629 Post(s)
Liked 5,166 Times
I think in my case everything is around average: my weight (incl. bike), road quality, weather (I always avoid rain/wet). I use 5 PSI below Continental recommendation for rear tire and 10 below for the front tire. It means 90 PSI rear and 85 PSI front. But still, these pressures are much bigger than the maximum recommended by website calculators (max. 78 PSI - "Rene Herse").
I am always conscious of the fact that running 10 psi too high loses far more speed than running 10 psi too low.
#78
All tires have recommended pressure listed on the sidewall, hence calculations for optimal values should start from there and (usually)should not go out of those ranges. Technically this is also true for some rims albeit it's harder to find data. For example one 23mm road tire could be 5-7BAR and other 9-11BAR. If calculator claims that 8BAR is optimal then you are not running tire to manufacturer specs. Of course this doesn't mean that bad things will automatically happen, just increases bad outcome chances.
#79
Liked 5,166 Times
#81
All right, it's case specific scenario. One more thing to be aware of is that sometimes those values listed on sidewalls are effect of thorough analysis by company and sometimes those numbers are just what they think is safe(for them to not get sued). In most cases of higher end tires and reliable manufacturers those printed numbers are not random.
#82
Quoted: 7151 Post(s)
Liked 11,352 Times
#83
Liked 5,166 Times
For example my GP5000S TR has a maximum pressure on the sidewall of 78 psi. But that is not a recommended pressure for everyone to run. For most riders it would be well above the optimum for both speed and comfort.
Another example, my Pirelli tyres have both min and max pressures on the sidewalls. I can’t remember the range, but it is very wide. Pirelli do supply a chart with their tyres with actual recommended front and rear pressures for your weight and rim width and suggested adjustment for wet conditions.
