Show Us Your 650B Conversions
#976
Progress on my budget 650b swapped '82 Team Fuji ($50)
Cycles Toussaint 650b wheelset ($245 shipped)
Soma Grand Randonneur tires 42mm ($80)
Sram PG970 11-32 9 speed cassette ($28)
Ultegra long cage rd (free),
Tektro 559 rim brakes and Levers ($110)
Nitto Olympiade B115 drop bars ($5)
Plotting next steps
Plotting next steps
Likes For Headpost:
#977
TXHC
Likes For amillhench:
#978
Likes For Headpost:
#979
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4709 Post(s)
Liked 5,897 Times
Check online for "12 pack can cooler", with a little bit of ingenuity you can easily modify one to act as a handlebar bag.
Likes For gugie:
#980
Quoted: 1088 Post(s)
Liked 1,207 Times
I don't know about the bag, but it looks like it might be using the Nitto F-18 bag support or something similar, which behaves sort of like the vintage Cannondale bag support, with thin metal bars protruding forward to support the bag.
#981
Quoted: 3840 Post(s)
Liked 6,888 Times
Likes For nlerner:
#982
Liked 5,897 Times
Likes For gugie:
#983
Thanks to all. I'll definitely look into these . . . but I still wish there were some cheap knockoff of a handlebar bag like that Acorn that had its own sturdy, simple mounting system--and not some plastic clip to squeak and finally break..
Also, SORRY FOR THE THREAD DRIFT!
#984
Quasi homeostatic system
Bikes: '81 Fuji America, '82 Team Fuji, '85 Nishiki Bel Air, '98 Klein Stage Comp R
Quoted: 48 Post(s)
Liked 205 Times
Ostrich bag from Osaka via alexscycle.com... best bang for the buck in rando bags. Though their $30 mount doesn't leave a lot or room for your hands. The Nitto mount for these bags is much nicer but starts around $120 if you can find them in stock.
Likes For MrGastrognome:
#986
Bikes: '38 Schwinn New World, ’69 Peugeot PX-10, '72 Peugeot PX-10, ‘7? Valgan, '78 Raleigh Comp GS, ’79 Holdsworth Pro, ’80 Peugeot TH-8 tandem, '87 Trek 400T, ‘7? Raleigh Sports, ‘7? Raleigh Superbe, ‘6? Hercules
Quoted: 769 Post(s)
Liked 1,634 Times
Headpost , an FYI/PSA.... Soma has a -35% sale going on of some brands they carry, including Cardiff. Discount code is '353535' apparenlty good through Monday. No idea of the quality, or attachment details, but with the sale you're looking at about $100 for the rando bag..... (confidence in quality not exactly helped by the wrong way they've got the top flaps in the photo........)
https://www.somafabshop.com/shop/car...=117#attr=4993
Likes For ehcoplex:
#987
Quoted: 644 Post(s)
Liked 1,347 Times
Thanks for the PSA! I've been looking for a brown bag for my conversion project...... I just ordered one, we'll see what it's like.
Likes For Murray Missile:
#988
Quoted: 644 Post(s)
Liked 1,347 Times
It attaches to a rack with straps on the bottom, no provisions for attaching to the handlebars. The pictures of the black version have the flaps down along the sides. Fingers crossed the retail price is reflective of the quality. Sometimes you get what you pay for, sometimes you don't.
#989
Quoted: 769 Post(s)
Liked 1,634 Times
One one of my bikes with an Acorn bag I do the straps on the bottom, the rack 'tombstone' in the slot (can't tell if the Cardiff bag has the tombstone slot...) and a couple cord loops with those little compression-thingys from the bag’s strap-rings to the bars just under the brake levers. I don't super-load the bag, but I do carry stuff, often on pretty rough gravel, etc, and it's been fine the past couple years.
Likes For ehcoplex:
#990
Wow, there’s so much to unpack here, [mention]lutemake3[/mention]. This bike deserves its own build thread (if it doesn’t have one already. The lights themselves could be a thread (that I would readily consume!).
I love the aesthetic - it’s a great modification of a classic French racing frame that still embodies the speed of a fast randonneuse.
Félicitations!
Félicitations!
Ron Banks
Fort Worth, TX
__________________________
Ron Banks
Fort Worth, TX
#991
Quoted: 644 Post(s)
Liked 1,347 Times
Closed for renovation....
I still have a lot of work to do to get it prepped and painted but I did a mock up with the wheels and tires to check clearances. There's a mile between the FD and rear tire but up front it's pretty tight between the bottom of the steerer tube where it comes through the crown and the tire so fenders are probably out of the equation if I want to run the 50mm tires...... and I do. The rear tire is lightly touching the ground so even with the180mm crank arms I don't think pedal strike will be an issue. I ground the ends off a few motorcyle pegs in my youth but that was a long, long time ago when I was still "immortal", I think those shiny TA Cyclotouriste crank arms and the MKS Sylvan pedals in transit are safe. The Technomic stem is in just past the Min insertion mark, I'll probably end up running a slightly shorter Origin 8 with a little less reach as I'm a bit stretched out when standing even with the seatpost and holding the bars where I normally ride, this thing has a long wheelbase. I hope it rides at least as well as it did as a 26 incher because there's no going back now.
#992
ambulatory senior
Quoted: 1957 Post(s)
Liked 3,673 Times
#994
ambulatory senior
Liked 3,673 Times
Likes For 52telecaster:
#995
Quoted: 48 Post(s)
Liked 205 Times
#996
Quoted: 644 Post(s)
Liked 1,347 Times
Thanks. I'm running a Shimano 105 FD, initial mock up looked good and good eye on the bars! Yes, B-135.
#997
Quoted: 48 Post(s)
Liked 205 Times
I think I need to track down those bars.... I need a little flare in my life. I did find a pair of 40cm B-114s today at my local co-op, which were the stock bar on my Team Fuji. Mine had riser bars when I found it and I am currently using a 39cm B-115.
#998
Quoted: 644 Post(s)
Liked 1,347 Times
#999
I'm curious to know where folks are getting 650b skewer wheels? Everything I'm finding are through axles and I don't want to use the convertors. thanks!
I'm slow, go around
I'm slow, go around
#1000
Quoted: 361 Post(s)
Liked 328 Times
Andy
Andy
Likes For beicster:
