Is there a list of vehicles that can be used to haul a tandem inside?
#101
Quoted: 427 Post(s)
Liked 340 Times
This is not true at all and I speak from a lot of experience. We have driven thousands of miles with out Co-Motion tandem on a rear 4-bike receiver mount rack. With both wheels still on and the handlebars turned 90 degrees only, the bike is within the width of the mirrors on either side of our Odyssey minivan. It does stick out, but definitely well within the traffic lane width and as long as you are not scraping your mirrors on other cars or walls, your tandem is perfectly safe back there. I really think a rear rack is the best solution as it seems impractical to me to go through all of the hassles of fitting a tandem into a small vehicle then not having room for your stoker to ride with you (kind of defeats the purpose). My only recommendation is that you use a receiver mounted rear rack that is sturdy enough for 4 bikes to handle the extra weight and inertia of a long tandem. We have in fact driven more than 500 miles with 2 tandems, a single bike and a TAB on the rack and 6 people to ride them and our luggage comfortable inside the single minivan. With a good receiver mounted hitch almost any vehicle is 'ideal' for a tandem and your passengers and luggage are covered too.
#102
Bikes: Bilenky Coupled Tandem, Pinarello Quatro FP2 DI2, Klein Reve X, Bianchi Volpe
Anyone have any experience fitting a tandem in a Chevy Equinox? The Equinox is the largest rental vehicle that appears to be available when we will be arriving at our destination. We have a coupled Bilenky, and it will be apart for the flight, but want to assemble the bike the night before the event, and be able to transport it assembled to the start.
#103
Bikes: 2005 Felt SR-81 (strait handled road bike), 2008 Kona Fire Mountain 26er HT (planning to upgrade to a 29er), Electra Swing Tandem 3i (cruiser built for 2), 2013 Trek Shift 2 WSD (comfort solo for my fiance)
#104
Quoted: 427 Post(s)
Liked 340 Times
Regardless, I hardly think driving down the road like this could possibly be considered legal or safe. As it stands, even with the angle the entire rear wheel would be completely hanging off the left side of the car, and the front wheel is more than halfway off the right.
#105
Bikes: Custom 650B tandem by Bob Brown, 650B tandem converted from Santana Arriva, Santana Noventa, Boulder Bicycle 700C, Gunnar Sport
Quoted: 23 Post(s)
Measure and see for yourself. A medium tandem without wheels is about the same length as a 54cm -56cm 700c single with wheels. Remove wheels and use the rack on the same vehicle with the same overhang.
#106
Quoted: 427 Post(s)
Liked 340 Times
Here are pictures of our tandem on the rear receiver hitch rack (Yakima). I took pictures from the front so you can see compared to our mirrors. This is a large CoMotion Cappuccino (700C wheels).
Also, normal highway lanes are 12 feet wide so an 8 foot wide vehicle (tandem on a rack) has 2 feet on either side to the lane lines if the vehicle is centered. If a truck is 8 feet wide and centered in the lane next to you there would be 4 feet of clearance between you and the truck.
We have the front wheel turned, but the wheel is still on the bike. If you took the front wheel off and straightened the handlebars you probably could slide the bike more to the driver side, but we never bother to. Some smaller vehicles are not as wide as our Odyssey, and also many vehicles taper to a narrower width in the rear (for aerodynamics), so in that case the bike is going to look a lot wider compared to our setup.
For our bike to hit something we would have to hit it with our mirrors first.
We have also had a Bike Friday tandem on the rack with our CoMotion and both fit within the mirror width, so I can say at least 2 tandems fit behind our Odyssey.
#107
Tandem Mountain Climber
Bikes: Calfee Tandem, Litespeed Gravel, SuperSix Evo HM, Larry vs. Harry Bullitt (e-cargo)
We had no problems driving 4 vans (each with one or two tandems fitted horizontally, on the back) across the country and back during Race Across America. We also had the same arrangement on a van during the Hoodoo 500, plus the drives to/from SF, CA <-> So. Utah
Note the front wheel locker is down in the pic, adding to the width. The bikes are about the same width as the van's mirrors at the widest points, with the bikes secured.
#109
How long are your tandem bikes from end to end? My Electra Swing Tandem is about 100 inches from the edge of the rear fender to the front edge of the wheel (8'4"). Is that normal?
https://www.bikepedia.com/QuickBike/B...g#.UkpzKxAiwiE
I also found this on the internet:
https://www.dot.ca.gov/hq/traffops/tr...size/width.htm
I imagine the rules are similar in other states. Either way, that's cutting it close. It would be quite hilarious trying to fit one on a bus rack...
GENERAL RULE
35100. (a) The total outside width of any vehicle or its load shall not exceed 102 inches.
#110
Quoted: 427 Post(s)
Liked 340 Times
Our Co-Motion Cappuccino is about 8' 1" tire to fender.
#111
Dodge or Chrysler Stow and Go systems the only way to go. I've had four sequentially (99 02 05 13) and they will transport our Santana Visa with both wheels on AND THE SEATS STOWED IN THE FLOOR - Takes less than five minutes to have the entire back end of the vehicle totally open and absolutely flat. To the best of my knowledge, no other Van can do this. We could leave the right side mid and rear seat up and still fit the bike.
#112
Tandem transport
Not "inside" the vehicle, but this is how we transported our tandems on a recent road trip from Colorado to California. It worked out well and I did have some heavy duty chains to lock the bikes when unattended. We did bring them into the hotel rooms along the way, just to be safe!
I don't like having the tandems on top of the car as they seem to get a lot more weather. This is a bit of a compromise vs. "inside" the car, but I don't really want a minivan as my daily driver either.
#113
Yeah, our bike was out in the hail on the way to the Iron Horse on top of the car. Poor bike took a beating but the Di2 still worked when we got there. Our car (TDI) gets twice the mileage of Sprinter van (TDI too) so I will save the van for hauling the boat or when I want to take a LOT of toys along.
#114
1978 Cessna 206
Unfortunately I had to take both wheels off to get through the doors, then flip the bike on it's back to avoid having it sit on the derailleur. Also removed 3 of 4 rear seats. Tied down with bungees and seatbelts, plastic dropcloth to avoid getting the interior greasy.
The roof rack wouldn't work so well on this vehicle.
#115
Quoted: 1361 Post(s)
Liked 425 Times
In a pinch have hauled our Santana in a Mercedes 300e sedan. With the 4-matic, there's no drop down rear seat but by removing the saddles + stoker bar, wheels, was able to set it at a diagonal. Sort of wish to have the wagon version with tinted windows. Would fit with ease. I don't like hauling bikes on racks.
#116
Coffin Dodger
Quoted: 794 Post(s)
Liked 292 Times
If it fit's, it ship's
Scion Xb, with the Santana sitting pretty
Way too scary on the back and NH highways
Pirk
#117
I like to submit my entry for the database:
A rental Ford Fusion.
#118
Trunk view
Back seat view
In this configuration, all I need to do is connect a DI2 cable, a brake cable, and the two couplings. No messing with the eccentric or timing belt. Wheels remain on and no brake or derailleur adjustment needed. I can reassemble the bike and be on the road in 5 minutes.
CJ
Back seat view
CJ
#120
Clipless in Coeur d'Alene
The 2014 Ford Transit debuted at the LA Auto Show. There are apparently two wheelbase lengths, so the stretch version ought to accommodate a tandem. Up to 30 mpg (my Honda Odyssey gets 20).
A couple nights ago I hit a small deer while driving our 2003 Dodge Grand Caravan ES at freeway speed (70mph). According to current conversations with our insurance co, it's possibly a write-off at close to $4k in damage. Sad, because this van was costing us less than $1,000/year to drive, which is far less than year to year depreciation on a new vehicle.
Photo of our van in it's current condition... deer fur and all. IMO the damage to the van looks minimal but the cost to repair isn't. To me it demonstrated these vehicles are quite safe in a head on. Didn't even compress the internal bumper structure which would have deployed the air bags.
We've cancelled our trip to the NWTR and a ETC event in Walla Walla prior to that.
I'm looking back through this thread for ideas of alternate vehicles... I'm kind of tired of driving a minivan at this point, but it is such a useful vehicle (can fit 4'x8' sheets of plywood, etc) it's a bit hard to give up.
#121
Tandem Vincitur
Bikes: BMC Pro Machine SLC01, Specialized Globe, Burley Rock 'N Roll tandem, Calfee Dragonfly tandem.
#122
Bikes: Apollo II, Roadmaster dragster, Hoffy, Speedwell, Gitane tandem
I've got great anticipation on the 2015-6 Audi Q7, which will have an entirely new car platform, the same as the VW Tourareg and Porsche Cayenne, only the Q7 will be larger than these. My idea is that a tandem will fit upright inside between the two rear seats, with a modification to the center console allowing the rear wheel to slide in a groove in the center. This could be done now to the Ford Flex or Lincoln MKT, but these are too ugly.
#123
Bikes: Cannondale Slate 105 and T2 tandem, 2008 Scott Addict R4, Raleigh SC drop bar tandem
Quoted: 22 Post(s)
We were able to easily fit our Cannondale tandem into my Wife's 2011 Audi A6. We just removed both wheels and my seat/stoker bars and it slid right in. We even stopped for groceries on the way home. Next trick will be to get it inside my Jetta.
#124
Well, I was able to fit my Electra Tandem in my Caliber for transport to the bike shop with both seats and handlebars removed, and both the back seat and front passenger seat folded down. The interior of my vehicle is barely past 8 feet from the hatchback to the dash board.
Obviously there's only room for the driver in such a senario. I've also hauled a stack of 8 foot 2x4s in it once as a favor for a friend, but the vehicle isn't really designed to haul loads like that.
Regardless, removing the wheels from a tandem cruiser with hub brakes and internal transmission would be a grand PITA.
#125
We have a 2014 Ford Grand Tourneo Connect. Can fit the road tandem inside without taking the wheels off and can still seat driver + 4 passengers. The MTB tandem has to have the front wheel off to fit due to the height of the bike.
All the rear seats fold flat and don't have to be removed. We have used the van for camping on cycling trips - we can both sleep inside on air mattresses with the road bike inside with us. When on an official campsite we put the MTB outside locked to the wheel to give us more space.
I was looking at lots of different options but wanted something where I wouldn't have to remove the seats as we don't have a garage to store them in. So far have been pleased with the van.
