Wide vs Less Wide Tires, Another View
#126
You should never trust power data unless you are certain that the unit has been properly zeroed. Knowing it's been calibrated recently is also desirable. It goes without saying that one-legged data is useless for this application.
#127
Bikes: 1979 Raleigh Team 753
Quoted: 3378 Post(s)
Liked 372 Times
But going faster doesn't break physics. All you need to do is make an adjustment for overall air drag coefficient, and then all of a sudden you can accurately predict speed change relative to power output change again. Someone above even listed a site where you can do just that, without having to get pencil/paper/calculator out.
I just posted two teens solo speeds. One in a training ride, one in a TT. Both on TT bikes.
Both would give up about 2mph on a road bike.
I have not found an online calculator I can plug known parameters into that really works at high speeds. The competitive folks test a whole bunch. More popular now is using the Velodrome as they realize riding you learn things you don't in a tunnel (and it generally costs less).
#129
Do you have your overall air drag coefficient sitting around? I don't. I get I can pay money to get it. And it changes. From tucking your neck to elbow width or shaving your arms.
And yes, I have plenty of drag areas sitting around (drag coefficient doesn't do you much good without frontal area). Robert Chung has described a protocol to do it yourself quite clearly, and you can do it just fine on the open road. A velodrome is not needed and may be counter productive since you won't get a realistic Crr. He and others have shown accuracy equivalent to a quality wind tunnel. All it takes is the desire and a little time.
#130
Quoted: 18883 Post(s)
Liked 10,646 Times
I've seen multiple "tests" where the wider version had a lower rolling resistance than the narrower tire. However, that's under lab conditions, not real world. Also, the make and model of wheel may affect results. My conclusion is based on road riding with a single set of wheels on one bike. In other words, YMMV.
But as with all things, it's a double edged sword. Skinny tires also weigh less and have slightly less frontal area ( think air resistance ).
Then you mate them to rims, air them up to taste, etc, and a small change in any one of those numbers might not be such a big deal anymore.
#131
Liked 372 Times
Yes, it takes some effort to get the parameters for the model. Again, that isn't the model's fault. If you aren't willing to put in the effort, don't blame the model for giving poor results.
So which is it? Do you have known parameters or don't you?
I doubt I have all the parameters it wants and I expect it does not have the parameters I want.
I have shoulder width, and rolled width and drop and neck tuck, but there are things you see like the head above the rider's back that are easy to fix, spot but I'm guessing may not be a parameter - neck / head gap. I can see it in a video riding behind. Also position changes a wee bit at speed, so seeing a rider at speed helps. So rolled solders at 20 may not be at 28. Is the rider nervous, are their tires too thin, pressure too high? I think you pick that up from the road, esp videoing from behind.
Really though, I'm not going to go through the work or take the time. We've been fine tuning for a while. On new equipment we test. Things like diet, sleep, mechanical mistakes, preparation have more bearing on outcomes, but the little stuff matters.
#132
Bikes: Garmin/Tacx Bike Smart
Quoted: 649 Post(s)
Liked 296 Times
I think it's the opposite: skinny tires can show less rolling resistance in an idealized, simplified lab setting ( spinning on a drum ) but have more rolling resistance outdoors, on the roads and trails.
https://www.bicyclerollingresistance...0s-ii-23-25-28
Anyway, I agree that less weight and less air resistance can be factors.
#133
Quoted: 649 Post(s)
Liked 296 Times
I didn't say the feel faster, I said I *was* faster. The numbers bear this out. And yes, I had some training time, but it's late in the season, so that's not a factor. I'm not going by feel, I'm going by average speeds over a two week period over the same courses under *very* similar conditions.
#134
Liked 372 Times
Guess this was my point. You need to plug in Effective Frontal Area. Obviously they are trying to figure drag. But that number changes on how you tuck you neck, arm - shave your arms. I want to get that number from changing the angle of the foot, booties on or off and then compare to a Sub 6 shoe with sleeves.
That is the number I want calculated. I don't want to enter it.
So when I put in the lowest number in the range .4 it says about 50 more watts are needed to go the speed that was gone.
I expect slop etc is off or tires were too thin.
#137
Quoted: 1245 Post(s)
Liked 202 Times
I just do a roll down test every now and again:
https://janheine.wordpress.com/2012/...ance-of-tires/
#138
Liked 372 Times
This one attempts to figure the effective frontal area out by position and ...tires?
Or maybe the tires are Crr. This calculator say Tubulars are better, drops are better.
Still off by 100 W or so.
Not a useful tool.
Not a useful tool.
#139
You don't understand what the kinetic model is and does. If you want a model for CdA, that is something else entirely. There are some, but they don't provide the resolution you're asking for. Given how easy it is to measure CdA directly, there really isn't any reason not to measure it if you care enough. If you don't care to put in the effort, that's fine, but it isn't the fault of the model, that you choose not to get accurate inputs.
#140
Liked 372 Times
You (I assume you) say:
"Very high tire pressures don’t roll much faster. Above an “adequate” tire pressure, the tire’s speed increases only very slightly with higher pressures. "
What is Very High? 120?
I thought they went faster too but was told a test said otherwise. https://www.bikeforums.net/19854496-post86.html
#141
Liked 372 Times
The speed power falls where it does.
#142
I'll even do the work to get you started. Start here https://anonymous.coward.free.fr/watt...direct-cda.pdf and follow the thread for later developments.
#143
Liked 372 Times
Post #129
It is estimating/calculating CdA . Points I likely have now.
I wanted measured CdA to calculate speed and power. If I need to estimate/calculate CdA I might as well just test and see what is faster - set course, set power, similar wind.
#144
(And virtual elevation "estimates" CdA the same way a scale "estimates" weight. This is clear from the Martin paper.)
#145
One thing I have often wondered regarding drumtesting is how well they represent reality. For one, as have been noted, their surface does not represent real roads well, second the drum pulls the wheel at a steady pace. > No real power transfer through the wheel/tyre outside of whatever power i required to spin the wheel, similar to coasting. > Would the results be any different if in stead the wheel pulled the drum at, say, an average of 200w and would it affect if the results if power was pulsed like a real pedalling motion. Im betting everybody on the forums have heard the "swish, swish, swish, ..." from a road bike tyre going at decent power. That is not accounted for.
#146
Not a useful tool.
Attachment 580171
Not a useful tool.
Attachment 580171
#147
#149
Liked 372 Times
It is something that is noticeable, esp out of the saddle. Relative squishy-ness of the various rear tire setups can be felt. I wouldn't necessarily expect what is a low rolling resistant tire to also be the firmest when standing.
