I need to get better on the hills
#127
Quoted: 4027 Post(s)
Liked 7,578 Times
OK, as I said, I did NOT feel like I was out of gas at that point. For me, "out of gas" is when I can no longer maintain a given effort level and have to dial it back. I was still doing pretty good at that point, just hating life. I made the call to dismount, not because I couldn't stay on the bike, but I felt that staying on the bike would use more energy than walking.
#128
Quoted: 2333 Post(s)
Liked 2,097 Times
Which is harder? Is either sustainable? For how long? No, it is not even close to a game changer. You will suffer regardless.
When fit, amateur cyclists take on hills approaching 20%, there is no gearing that lets you spin (unless you are on a tadpole with Schlumpt mountain gear and 406 wheels)
#129
I presume you're referring to my post about parking garages - sure, retail parking decks will be full on weekends, and corporate parking decks will be busy on weekdays (some of them, at least) - but there might be one nearby that's both easy to access and quiet enough to ride on. Just a thought, really.
Likes For aliasfox:
#130
Quoted: 4605 Post(s)
Liked 5,144 Times
It would take the cadence from 30 rpm to around 37 rpm with gearing to 28 inches from 34 inches. And, the point you missed is about 370 watts instead of 300 watts at 30 rpm.
I just did a simulated climb of Bealach na Ba on my Kickr Bike with a 35/33 lowest gear (https://cyclinguphill.com/100-climbs/bealach-na-ba/). Steepest gradient is 20% and the steep ramps are relatively long. My lowest cadence on the steepest part was 37 rpm at 300W and I was right on my limit by that point in the climb. I'm pretty sure I would have stalled just one gear higher (very close to HR max and 37 rpm is about as slow as I could pedal with that torque). My average cadence for the whole climb was 66 and I was in my lowest gear for everything over 8%. I used slightly higher gears for the shallow sections, but never higher than 5th gear (35/19) and mostly in the 33 or 28 rear.
I'm pretty sure I could climb this hill faster with a 35/36 or even a 33/36 gear. I might try this at the weekend as I can program any gearing into the Kickr Bike.
#131
Method to My Madness
Quoted: 2067 Post(s)
Liked 1,560 Times
For a few years I used a Garmin chest strap thing on a rowing machine, found the numbers it gave me seemed to correlate to what I was feeling during use. Tried it for swimming laps, didn't work so well though purportedly waterproof. My thinking at the time was water's movement altered sensor proximity to my chest.
Traded an early M1 chip MacBook Pro for an iWatch a couple years ago, watch does all kinds of neat things telling me about what my body's up to. During the Pandemic I found it useful monitoring blood oxygen content. Had opportunity a couple of times to check it against a more sophisticated system (local clinic's finger-mounted sensor) and pleasantly surprised to find it within 1% of the value the finger-mounted sensor was getting. So I'm inclined to trust the watch's more basic heart beat numbers; I wear it on my left wrist most of the time.
It'll do ECG too - which I don't find of much use - but that requires having my right-hand index finger in contact w/it, making any other hand operations impossible for the duration. Supposed to be able to detect a-fib telltale signals as well. I have yet to see anything telling me I'm prone to such, which is some comfort.
#132
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2713 Post(s)
Liked 6,014 Times
^ You don’t even know you are wearing a chest strap after you get going unless you have it WAY too tight. it’s not a bra, just a thin strap, but then a few here might prefer a combination bra/strap.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
#133
I see what you did there!
1-2 minutes is a pipe dream, at least for me. The section of the course we're talking about is uphill for at least three, maybe four miles. It just doesn't get to that nasty grade until about 1-2 miles from the top. And this is already 26 miles into a 34 mile ride, after a 1 mile swim and before a 10 mile run. I wasn't out of gas yet. Getting off the bike was a decision made to conserve energy for later in the event.
No parking garages where I live.
With the current gearing OP's cadence would have been around 30 rpm. Increasing from 23T to a 28T won't make matters much better.
Studying the course profile in advance and pacing a bit slower leading up to these short walls is a better strategy than hoping a few more teeth will help. Then when the 1-2 minute wall appears, you have the anaerobic reserves to use. Nonetheless, OP would benefit from something more like 1 to 1 or lower.
Personally, I find 40 rpm to be a reasonable lower limit for balance on 15-20% grades. At 17% with OP's gearing, 80 rpm would take me 800 watts. Aint' happening. Those short walls are always full grunt territory, nobody is spinning up them
I haven't done it, but I've heard it mentioned in the past: If you're cool with doing hill intervals and have access to a parking garage nearby, that would be a way to get in a quicker workout. Lots of short, 8-10% ramps with a flatter part in between could help build power.
#134
OK, so I thought a visual representation would be good at this point. This picture is with the Alex wheel that originally came on this bike. This is NOT the wheel I had on last Saturday. This cassette has a 27 tooth top gear. Looking at it now, I wonder if my chain is too short for this gear? If I put a longer chain on, do you think I could fit a 30 tooth with this derailleur?
This picture was taken in my garage, and yes, I know I need to sweep.
#135
Liked 1,560 Times
#137
Having lived somewhere where road riding was ill advised (few shoulders, short sight lines, and lots of large trucks), and the only decent option was a rail trail with maximum 1.5% grades, I’d have been happy to have a parking deck nearby for a few workouts. As it was, there weren’t any, but at least one neighborhood had a 1/2 mile 6% hill as part of a little loop that I could practice on.
Likes For aliasfox:
#138
Bikes: 1972 Motobecane Grand Record, 2022 Kona Dew+
Quoted: 168 Post(s)
Liked 153 Times
The one you posted with a different wheel shows chain on largest cog up front, which I doubt would be your practice when mashing uphill. When on the smallest cog it moves the derailleur cage well back from where that pic shows it to be I think a 28 or 30t wheel at the back would work fine.
#139
Bikes: Lemond '01 Maillot Jaune, Lemond '02 Victoire, Lemond '03 Poprad, Lemond '03 Wayzata DB conv(Poprad), '79 AcerMex Windsor Carrera Professional(pur new), '88 GT Tequesta(pur new), '01 Bianchi Grizzly, 1993 Trek 970 DB conv, Trek 8900 DB conv
Quoted: 759 Post(s)
Liked 811 Times
Yet another in a series of threads by this OP about portions of a ride she's having a hard time accomplishing. There are no quick mechanical (an extra 2-3 teeth on a rear cog helps, but isn't the problem) fixes or secrets to make things better..she needs to get in better shape/condition...pretty simple.
Is the cross-chained config in the pic above something you ride often?
OP..post a pic of you riding your bike..and take advice(about fit, gearing, etc) from there.
#140
Quoted: 168 Post(s)
Liked 153 Times
S'truth re: conditioning vs. mechanical aids.
Still, different gearing may facilitate a shorter path to better conditioning. It'll still take time to reach a particular goal, but once that's achieved, returning to the original gearing may well be gratifying.
#141
Liked 5,144 Times
#142
Quoted: 8426 Post(s)
Liked 9,345 Times
#143
Klaatu..Verata..Necktie?
Quoted: 10613 Post(s)
Liked 12,230 Times
I don't think the OP was posting the bike in Biggie Bigs as a gear she might use, but rather because Biggie Bigs is one way of determining whether your chain is long enough. And it is.
Likes For genejockey:
#144
Quoted: 168 Post(s)
Liked 153 Times
I'm taking this thread as inspiration for my own practice. Being rather new to cycling (after taking twelve+ years off) as well as entirely new to riding in an area offering some awesome hills to climb, I'm learning to overcome prior practices that may not be helpful for one at my age (74-1/2).
There's a hill I found last w/e that's a rural, paved road between a ridge and a coulee bottom. It's 0.7 miles in length with an elevation change of 250 feet end-to-end.
Last w/e I just coasted down as I'd already done about 8 miles to get to the start. Once down I had another two miles to get back to my car, so I was taking it easy. Brakes on going downhill all the way while watching for sand, gravel, branches, critters lurking around the bends....
Earlier this morning I went back, did it uphill for the first time. Only trepidation was the 1' wide streak of diesel someone had left from the bottom to about the 3/4 point exactly where I would have preferred to put both wheels.
This was a 'baseline' ride so I wasn't mashing, just doing a first attempt to use to measure future progress. Took me 9 minutes to do the .7 miles, stopped for a minute half-way up. Felt pretty good overall, no time today to do a second pass. Strava tells me 142 W avg. power, 4.7 mph, heart rate 134 avg., max. 153. This was using the 40/24 lowest gear my MB came with. If I can source a decent French-pattern freewheel w/ 14-28 cogs this hill will be my first ride to see what the gearing changes about the experience.
Going back downhill it took just 3 minutes w/ 0 watts expended and again, brakes on pretty much all the way down.
Likes For spclark:
#145
Quoted: 6351 Post(s)
Liked 4,950 Times
3x bike for the ride in question? What gear were you in when you bailed out and got off? If you were still in the big ring, then you need to learn to shift to a lower gear ratio and keep your cadence up. Pushing hard gears will wear you out quick.
#146
Liked 12,230 Times
OP indicated she was in 30 x 23.
#147
Liked 2,097 Times
Or it allows you to ride slower with less power at the same cadence.
My only real point is OP needs to survey a course's profile before travelling to a Triathlon and plan. Gears don't get you up walls, grit does. When there is a wall like she encountered, it is best to pace conservatively leading into it in order to maximize the capacity of that battery or W' because short steep walls like that are always hard. And, her decision to walk may have been the correct one given she had to do a marathon or half after the bike.
#148
Liked 5,144 Times
We have the same low gear, SRAM 35x33. You have a better power to weight ratio, I am claiming my senior citizen excuse. 300W is typically more than threshold for most riders. From the first turnpoint on one's lactate curve (LT1) to the second turnpoint (LT2 or approx. FTP), one starts to slowly consume a reserve of power typically referred to as W' or AWC. W' is the amount of KiloJoules one can expend over a certain, arguable critical limit. If one has 15kJ of reserves or so-called W' and they use this battery-like reserve for 150 seconds, they can apply an additional 100 watts (15,000 divided by 100). (I know you know this, just putting the nitty gritty for completeness)
I expect the OP was just grinding too much for comfort and chose to walk at a lower speed with less effort. Riding a lower speed is usually easier than walking if your gearing allows. She said she wasn't gassed out, so I think a lower gear might have kept her on the bike and moving a little faster than she could walk.
#149
Show us a pic with the wheel you were riding last Saturday please.
#150
OM boy
Bikes: a bunch
Quoted: 554 Post(s)
Liked 714 Times
I work 12s the next three days. Will post a pic later in the week.
Only pic I have is more or less head on, so not sure how helpful that would be.
Actually, I do ride like that quite a bit. Really didn't know it was a problem. No real plan to it, I just find shifting on the rear to be simpler and more convenient when those gears will do than shifting both. It's not that I'm afraid to use the front. It's just that there's often so much overlap that I can get away with most things on the big gear where I live.
I remembered this grade from last year but didn't recall the exact course. I knew it was coming but I am not so familiar with the route that I knew where I was in relation to it at any given point. I may not be quite there yet, but I'm getting close to cashing in that senior citizen chip too. What's the age minimum on that thing?
IF, you're committed to this Tri thing, and cycling; then really becoming knowledgeable about the very basic and super important part 'gearing' is to cycling your best is KEY!
Riding by 'feeling' is an important part of cycling. certainly. But knowing yourself and how that relates to the entire range of gearing of your bike which available to you, is absolutely
essential for effective cycling, any cycling not just competition.
You need to know and understand your gearing range and how that works for you on each section of riding you do.
It's not something which can be TOLD to you by others. Each rider has their own degree of understanding which gearing (gear combo of the Front 'CHAIN RING and Rear 'COG') they use for a segment type. YOU need to develop that same knowledge.
It costs nothing, money-wise. It is completely FREE for you, because it is SCHOOLING and LEARNING of how to learn to use the gearing available and and why.
1st step is to make a gear chart for the combos of Chainring and rear cogs you have - your 3x front rings and 9 or 10 cogs on the back.
You can do this, or you can give the Forum your Chainring sizes and the Cassette/cog range on the rear - I'm sure someone here will give you a link to that chart - then you can also learn how to MAKE YOUR OWN CHART.
With that you'll start to develop an understanding what each gear combo means, relative to your riding capabilities, based on the gearing, in either 'GEAR INCHES' or 'DEVELOPMENT' (same thing/idea, different ways/numbers to express the 'gear' of any combo, I'm completely schooled in the traditional 'gear inches' and relate to that).
These 'gears' on your bike, becauses they are combos of front and rear, will have 'overlap'/sameness at points, so 3 front rings & 10 rear rings produces 30 gear combos, but likely there are only 27 or 26 or 25 gears which might be unique.
Once you know this, then you need to figure out how to use all these combos most efficiently, thru shifting progression... that takes time and awareness and shifting skills...
THEN
You can become estute on how to use them well and allow you to ride your best/fastest.most efficient. All this is up to you and your desire to learn and improve.
It's NOT an age thing... it's a 'desire', motivation, learning thing
Good Luck
Ride On
Yuri
Likes For cyclezen:
