Best Rear Light for $25?
#126
Devil's Advocate
My iPad with its auto exposure doesn’t capture the brightness of these blinkies but they are all quite blinding — and inexpensive!
Stratus
XPC Planet Bike Grateful Red Serfas Stop Sign by andyXchrist, on Flickr
RANS Stratus XPC by andyXchrist, on Flickr
https://www.amazon.com/Akale-Recharg...V50R3H19MKQK0K
https://www.ebay.com/itm/Serfas-TL-S...72.m2749.l2649
https://www.ebay.com/itm/PB-Grateful...72.m2749.l2649
First link is to set of 4 for $18.99 which comes with one pair of red flashing tails and one pair of white to mount on handle bars.
Stratus
#128
Quoted: 529 Post(s)
Liked 255 Times
These are my favourite tail lights. These have built in solar chargers. You don't need to recharge them, or replace batteries.
At the time of writing, you can buy these on ebay for less than US$3.
#129
Bikes: Dawes Lightning DLX, 1988 Klein Performance, 1991 Peugeot Safari, 1985 Raleigh Alyeska, Carrera Phantom, 1973 Raleigh Record
Quoted: 282 Post(s)
Liked 130 Times
Those are worth a try, but you may still want to replace the battery eventually. My solar marker lights on my driveway don't hold a charge for long anymore. I've been meaning to replace their batteries.
#130
Quoted: 529 Post(s)
Liked 255 Times
However, at less than $3 per light, it is probably easier to replace the light. If a light got broken or stolen at some time, replacing it should not cause financial stress for most people.
More information here: Solar bicycle lights
Likes For alo:
#131
human being
I love anything by KNOG. I've owned several. Seems that battery life is on par with other products out there (if not better), interface with bike is fantastic and features/settings are excellent.
#133
Quoted: 194 Post(s)
Liked 206 Times
I received my latest tail light today, about 3 dollars, no idea who the manufacturer was but was common on 1960s Romet bikes from Poland. I am not sure how bright it will be, but it will snuggle up close to its bottle dynamo.
Likes For 10 Wheels:
#135
Quoted: 7402 Post(s)
Liked 2,583 Times
I suggest an LED bulb for that tail light, @Geepig. If it casts its light in many directions, you'll get more light per watt.
#136
Quoted: 194 Post(s)
Liked 206 Times
#137
This is a Pannier/ Tailbox. I built this to make the recumbent bike community happy
Testing a new Samsung Galaxy phone...
Likes For hotbike:
#138
Making GIF animations to show the directional indicators.
Likes For hotbike:
#139
The all-important left turn signal
"I'm taking the lane"
Bicycles usually go around parked cars, not slam into them.
This is the only way to get the message across, it seems...
Anyway, IIRC these lights cost about $1.67 each . The OP asked about the cost of the light,, not the cost of the battery, which is 12 volt. I recently converted from. Lead/acid to Lithium Iron Phosphate, but the cost of LiFePO4 has come down to where it is more economical than lead acid.
Likes For hotbike:
#140
Quoted: 282 Post(s)
Liked 130 Times
Some day I plan to make brackets to attach to my racks so I can fit multiple tail lights. A motorcycling friend once surmised that car drivers seem to recognize a triangle of lights much better than a single light, so that's what I'm aiming for. It would also give a better sense of the width of the bike so, hopefully, cars will give adequate space when passing.
#141
This 🔝 is what I have my tail lights mounted on.
I’m working on a 15 inch cube next (So it will fit in a 16” cube cardboard box).
I want you to see the plan, so you can grasp the simplicity of it. It’s one box that does the work of three , left, right, & top.
Corrugated Polypropylene can be found at Home Depot, it’s right next to the plexiglass, near the shower doors.
LED lights can be found on Amazon.
I buy LED blinker modules by the 5-pack
This plan is better than making brackets.
Likes For hotbike:
#142
Quoted: 282 Post(s)
Liked 130 Times
#143
Glues. I’ve used hot-melt glue, which bonds quickly, as soon as it cools. And I’ve used a construction adhesive called Loctite PL, which comes in a tube that fits in a caulk gun. It requires a lot of clamps. I had to use boards ,1”x4” , about 28” long, and sandwich the seams, with carpenter clamps outside, there was no way to fit the clamps otherwise.
⬇️⬇️⬇️Creasing method shown below ⬇️⬇️⬇️
⬇️⬇️⬇️Edge of a cutting board. ⬇️⬇️⬇️
⬆️⬆️⬆️ Clamping method shown above ⬆️⬆️⬆️
I might have a few photos
Likes For hotbike:
#144
Front and rear are cut from another piece of Coroplast (or similar corrugated polypropylene) keeping the grain horizontal.
The pattern for the sides, bottoms, and wheel arch. You could conceivably cut two of these from one 48” by 96” sheet, if you fudge it a little bit, I’m leaving two inches of flap to fold over and glue…
Pattern with locations marked Blue lines cut Red lines fold
Pattern with measurements marked in millimeters (And I spelled “height” wrong)
Likes For hotbike:
#145
Quoted: 425 Post(s)
Liked 385 Times
Has anyone used the Lumintop tail light? I see good things here about the headlights, but not much about the tail lights-- the tail light isn't even shown on their site.
https://www.amazon.com/LUMINTOP-Rech...t-items&sr=1-2
(Thinking about getting the C01 headlight, but not sure if I should also do the tail light or go for another brand there.)
#146
Live not by lies.
Bikes: BigBox bikes.
Quoted: 860 Post(s)
Liked 784 Times
I bought 2 very similar to this. However, they were not used for commuting, but so my kids could ride around campground after sundown. I was satisfied with them for that purpose.
#147
Quoted: 425 Post(s)
Liked 385 Times
I did buy the Lumintop lights and they seem okay for my purposes (very occasional after-dark riding). I chose the cheaper of the two headlight options and like it; even on lower settings it's bright enough for me to see what's in my path. Not as sure about the tail light since obviously I'm never behind me observing how it works, but when I just look at it on the bike it seems nice and bright (maybe I should park the bike and walk a couple blocks down the street to see how visible it is). Can't speak to longevity since I've only used them maybe 4 times since getting them.
#148
This thread is right up my alley. I use these. Less than 3 bucks each
https://www.ebay.com/itm/19566854385...Bk9SR6Dv1_KJYg
Not necessarily from this particular vendor, but just search for "5 LED USB Rechargeable Bike Tail Light". Include results from China, Hong Kong, Taiwan. Yes, they're from China and take about a month to be delivered, sometimes less.
I get one red and one blue light to "simulate" cop lights. I use the 4th setting. Not too busy, not too stale. And yes, I'm about 90% positive they're legal in my area because I've checked the statutes. Also, I've been passed by many cops in the area and no one has said anything,
Use the micro usb that's included. Gently insert and take out. I've broken a light by applying too much pressure. My rides are for about an hour and a half, maybe more. I recharge every 3 rides. I could probably get 4.
#149
Liked 2,583 Times
I once had a light that flashed blue and red, and an oncoming car pulled over because he didn't know what I was driving. I decided I won't use blue and red anymore.
#150
Liked 2,583 Times
