I need to get better on the hills
#151
Super-duper Genius
Quoted: 768 Post(s)
Liked 984 Times
There is a lot of overlap, but you certainly should be ready to use the full range of gears.
Here’s what I do:
I usually start out on my small chain ring. If I’m going up a hill or I know I will not want much speed, I might stay there for a while. In a race, I usually go up to the big ring pretty quickly. With the small ring, I only use my first 4 or 5 (out of 11) cogs—the largest ones. And with the large chainring I only use the eight or nine smallest cogs. Because of the overlapping ratios, there is no need to ever be in a largest-largest or smallest-smallest combo.
Unless I’m pulling a trailer or starting out on a steep hill, I start on my third or fourth largest cog and work from there, often going to the fifth or sixth pretty soon, along with shifting up to the large chain ring.
I seldom use my largest cog, but I’m really glad it’s there for the steep climbs I occasionally encounter.
I likewise seldom use my smallest or next to smallest cog, only if I’m descending a steep hill and really feel like pushing.
Therefore, most of my riding is on either the small chain ring and the second, third, or fourth cog or else the large ring and third through ninth cogs.
On my bike, it is easiest to shift down to the small chain ring when I approach a stop and know I’ll want a lower gear to get started again. Once I’m back up to speed, I can easily go back to the large ring. This works better than shifting two or three cogs for the equivalent ratio change I desire in this situation. Shifting up or down one or two cogs is for fine tuning my cadence while cruising.
In a race, I will likely be on the big chain ring most of the time, but I dang sure go to the small one when there’s a steep hill to climb, and if it’s very steep and/or long, I might also be on my largest cog.
Google Sheldon Brown Bike Gear Calculator, put in your parameters, and it will generate a nice little chart showing all your ratios. You can look at gear inches, meters development, or gain ratios. You can also see your speeds at various cadences.
Here’s what I do:
#152
Newbie racer
Bikes: Propel, red is faster
Quoted: 1575 Post(s)
Liked 1,569 Times
Either way…for tri related stuff slowtwitch.com is the place to be instead of BF. If you paced that bike course in Z2 before and after the “ramp” you can afford one or two brief VO2 digs in a triathlon. Just don’t make it a habit.
Maybe not mentioned earlier, but if necessary, paperboy that hill.
#154
Quoted: 3260 Post(s)
Liked 2,572 Times
#155
Liked 2,572 Times
#157
pan y agua
Quoted: 1465 Post(s)
Liked 743 Times
That does sound like a plan. Being so short, I could probably do five intervals. That particular hill is right at the 10 mile mark so it would be 10 miles there, do five intervals, then 10 miles home. May not impress some hard core cyclists, but that would be a pretty good workout for me.
That will be of some value in getting generally fitter and training yourself for 2 minute efforts, but its not of much help in training for sustained climbing. The 2 minute efforts are not targeting the right energy system. If you want be able to do long climbs, you need to raise your sustainable w/kg. So doing 2x20s on flat ground will actually do more for your ability to do long climbs.
So while short hill repeats have some benefits, and I agree you should do them; that should not be lieu of doing longer intervals aimed at raising ftp, qhich ultimately will do more to help your climbing.
You could get lost and die.
You could hit a tree and die.
#158
pan y agua
Liked 743 Times
I haven't done it, but I've heard it mentioned in the past: If you're cool with doing hill intervals and have access to a parking garage nearby, that would be a way to get in a quicker workout. Lots of short, 8-10% ramps with a flatter part in between could help build power.
Again, this is a way to build power for very short efforts. If your race has a lot of 30 second ramps, it's great. So a really good workout for an undulating crit for example. However if you want to target raising ftp, you want sustained efforts of at least 6 minutes, and preferably 20 minutes, or more.
Here in North Florida, many people do bridge repeats, with climbs of 60-80 vertical feet when getting ready for big mountain rides. Having raced a lot of races with 10,000 feet or more of climbing, living in Florida and worked with professional coaches for years , that has never been the program. In stead we focus on building threshold power through long efforts, such as an hour just below threshold, lots of 20-30 minute efforts at threshold, and some just above threshold. All aimed at pushing up or pulling up FTP. Bottom line, watts are watts, whether the ability to produce them is developed on flat ground or on mountains
My plan is typically supplemented with a few trips to actual mountains when possible, as much as for practice, as training. And we do incorporate short hill climb repeats, but mostly to top off anaerobic power, not as a principal tool to improve sustained climbing.
Likes For merlinextraligh:
#159
pan y agua
Liked 743 Times
Here is a link to a piece I did years ago, climbing for flatlanders, that elaborates on the above, based on my experience coming from Florida, and years of working with elite professional coaches.
everest challenge x2: Climbing for Flat landers
#160
Quoted: 4546 Post(s)
Liked 5,053 Times
#161
Super-duper Genius
Quoted: 768 Post(s)
Liked 984 Times
In the races I've done (admittedly not very many) a couple seconds right at the start mean nothing. We're going to be out there for a while, and there are plenty of chances to pass; no need to strain coming off the line.
#162
Quoted: 2333 Post(s)
Liked 2,097 Times
ST is certainly a better place for Tri advice, especially if OP had a PM, HRM, and a basic understanding of training.
But she is in the right place for now.
#163
pan y agua
Liked 743 Times
Anything that gets you working at the right power output for the right length of time. I have a similar setup with Swift and a Wahoo smart trainer. I rarely can bring myself to ride it for more than an hour though.
#164
Keefusb
Bikes: 60cm 1992 Paramount, 60cm 1995 Cannondale R900 (son's bike), 1994 Cannondale H300 (mine), 1994 Cannondale H300 Killer V (wife's bike), 60 cm 1989 Eddy Merckx Corsa Extra SLX
Quoted: 83 Post(s)
Liked 58 Times
I run DuraAce 7700-7800 components (9-speed) on both of my (older) road bikes. Shimano says you can run up to a 28T low gear in the back, but in actuality you can run a 30T with a short cage rear derailleur. You will need to screw the B-screw all the way in or install a longer B-screw, which is not a big deal.
I installed Stronglight 38T inner chain rings in the front, which are the smallest you can use with a traditional 130 BCD double crankset. I find that a 38/30 is a serviceable lowest gear for all but the steepest climbs. My biggest issue is my own body mass. At 215#, I'm not exactly a lightweight. I would love to get back to my racing weight (185# to 190#), but since I'm in my 60's now, I don't see that happening. I can't believe that 30 years ago I used to fly up hills running a 39/23 lowest gear, and many of the old school front cranks were 53/42.
There has been a lot of movement lately towards compact cranksets and cassettes with low gears in the 30's, but body mass and CV fitness are still king.
#165
OM boy
Bikes: a bunch
Quoted: 545 Post(s)
Liked 688 Times
But there is a 'condition' of riding 'climbs' which just can't be substituted by 'flat'/rolling training. (except Smart Trainers...)
Gravity is a force which is rarely available in any other situation, than climbing. It's affect is greater than most wind and rolling resistance combined. You will slow if you stop pedaling on the flat, but no where near as much as on a climb.
Slopes 6% and greater have a large effect on your momentum. AS you get into these steeper zones, each pedal stroke means 'acceleration' and immediate Decel. Acceleration saps 'power' immediately. It's quite obvious that you can't ride up a 7% grade anywhere near as fast as a flat section - that's the effect of Gravity.
Lower gears and increased cadence helps to smooth out that Sine curve of 'accel/deccel', but at the expense of aerobic capacity. The cadence limits are much lower on 'climbing' type riding as compared to spinning on a flatter section, so comparing what one can spin on the flat to what one is able to achieve on a climb is not comparable.
If you want to approximate 'climbing' on a flat stretch, then make sure you're riding into a steady 25-30 mph headwind - that'll work. The effort type and cadence limits will be most closer.
If one can add any amount of 'climbing' into FTP workouts, that certainly won;t hurt in climbing ability.
If one can get to 'climbing', go do them...
Ride On
Yuri
#166
Super-duper Genius
Quoted: 768 Post(s)
Liked 984 Times
I bought a TACX Neo 2 smart trainer a couple years ago, and it has been a game changer. I always, ALWAYS get a more effective workout on it than I get riding in the real world. Of course, riding outside is more fun, but riding on the trainer is definitely tougher. For working toward fitness goals, the trainer is incomparably better.
#167
Klaatu..Verata..Necktie?
Quoted: 10529 Post(s)
Liked 12,105 Times
#168
Super-duper Genius
Quoted: 768 Post(s)
Liked 984 Times
I wanted a direct drive as opposed to wheel-on model, and it was not cheap. It's so fun though. I have never done Zwift on it, or anything that involves virtual racing/interaction with other users.
I just use the TACX app (which requires a subscription of $10 per month). I hook it up to my big TV to show scenery of the routes I ride all over the world. The routes are rated as Easy, Moderate, Difficult, Hard, and Extreme, and they're not kidding. Everything above Moderate is very tough for me, and I've never even tried an Extreme route.
They used to have challenges you can take on, like doing a particular five rides in five days, and if you completed one they would send you an actual patch. Not an icon on the screen, but a real fabric patch sent in the mail. I think they've discontinued those.
The TACX Neo has some features that are not particularly useful but make it more fun. Glowing lights shine out the bottom and change color from blue to red (or gradients in between) according to your power output. It also shakes or vibrates according to the simulated road surface you're on, and they've done quite a good job with the realism of this.
#169
Liked 12,105 Times
I just use the TACX app (which requires a subscription of $10 per month). I hook it up to my big TV to show scenery of the routes I ride all over the world. The routes are rated as Easy, Moderate, Difficult, Hard, and Extreme, and they're not kidding. Everything above Moderate is tough for me, and I've never even tried an Extreme route.
The TACX Neo has some features that are not particularly useful but make it more fun. Glowing lights shine out the bottom and change color from blue to red (or gradients in between) according to your power output. It also shakes or vibrates according the road surface you're on, and they've done a really good job with the realism of this simulation.
I've tried using Wahoo's "X", which I guess used to be called Sufferfest, but while it was okay for workouts, wasn't engaging for me as a replacement for a ride outdoors.
#170
serious cyclist
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times
From triathlons? No. It's a lifelong phobia of water. I have managed to learn how to swim a little. It's enough that I could probably save myself from drowning if I were to fall in. But I am truly horrible at it, compared to anyone who swims competitively at any level. It's kind of been a dream of mine to overcome this someday and do just one tri.
Likes For Bah Humbug:
#171
Bikes: yes, i have one
Quoted: 1151 Post(s)
Liked 1,193 Times
#172
pan y agua
Liked 743 Times
Agree with most of that. Use whats available... Even when you look at the Continental development of young riders, many young riders can't get to 'mountains' as often as wanted/needed. Their training/racing is so localized and intensive, that long mountain 'camps' are a rarity, if at all. Yet the Dutch, Belgians and Danes seem to produce some great climbers in their young ranks.
Ride On
Yuri
Ride On
Yuri
My broader point is that if you don’t have big climbs, you’re better off doing longer flat intervals, than busting short bridge, or parking ramp repeats, as the core of a program aimed at improving your sustained climbing.
#173
Liked 5,053 Times
No doubt climbing actual mountains is the best way to prepare for climbing mountains. Raising your ftp on flat workouts will only go so far. Thus, when I was limited to riding in Florida and getting ready for big mountain rides, I still tried to get some rides in the mountains to supplement.
#174
Liked 12,105 Times
#175
So as promised, I'm posting a couple pics. This first one is a Race Lite wheel with a 27 tooth large gear on the cassette. I haven't purchased yet, but I found a Tiagra 30 tooth cassette on Amazon. Should fit, no?
I don't really think this pic will help much but someone above asked if I had any pics of me on the bike. This is the only one I got from Santa Barbara. Don't really know if it will provide any usable information. Unfortunately, they didn't get any of me passing directly by.
Likes For VegasJen:
