Nashbar Touring Bike Build
Quoted: 4539 Post(s)
Liked 1,676 Times
At this point you either have a slight measuring error, or your frame and fork were set up for a JIS headset. Frame prep tools can be used to enlarge the headtube to 30.2 (and fork crown down from 27.0 JIS to 26.4 ISO), or you can buy a threaded JIS headset. But threadless are going to to be 30.2.
BTW, why do you want to replace the fork?
Quoted: 9 Post(s)
My plan is to go with this headset...
https://www.worldwidecyclery.com/pro...yABEgKNl_D_BwE
and this fork...
https://www.bikenashbar.com/cycling/...yABEgKDZPD_BwE
Liked 1,676 Times
I think it was a measuring error, its hard to get pictures with the caliper in the head tube. But when its fully extended its 30.16-30.20. The fork was bent and rusted. It looked to be beyond surface rust.
and this fork...
and this fork...
You could also measure the crown on the old fork if you have any doubts - 27.0 for JIS, 26.4 for standard that pairs with 30.2.
Those are nice products.
The fork is not a touring fork, which may or may not matter to you. Touring forks typically have more rake (offset) to their blades to make the trail low for carrying heavy loads on front racks. Some folks don't think this is really necessary, and you might not plan on even mounting front racks. You might also want to confirm that the carbon fork's axle to crown measure of 391mm is in the ballpark of the original fork. If it isn't, the bike is still rideable, it may just feel a little bit more or less "sporty".
https://www.sheldonbrown.com/rinard/forklengths.htm
Also keep in mind you're only saving 100 grams with that carbon fork overy a steel Surly Cross Check fork for $89. Not playing favorites, just giving you the information.
On the headset - that is a super nice, very pricey high end piece. Be aware there are lots of other choices that even use cartridge bearings that are priced more appropriately, like this one:
https://brandscycle.com/product/orig...iABEgLxdvD_BwE
I have never viewed headsets as particularly important. As long as they aren't too heavy and they last, that's all I need to steer.
Quoted: 9 Post(s)
I’m not quite sure what to measure on the old fork. The tube is 25.4, but where the bearings sat it measures in the low 30’s? I’m from NC and really like the guys at Cane Creek. I may end up going with the 40 they have to save a few $$. The axle to crown is a little lower but not enough that I’m worried. I think I can pick it back up with the stem if it’s an issue. I think the 45mm rake will be sufficient and for my planned trips I’m thinking 40-50l would be enough so the loss of a front rack I can live with as well.
Quoted: 101 Post(s)
Liked 49 Times
and this fork...
and this fork...
The Cane Creek Ten series stuff is about a quarter the price and works just about as well The Forty is good stuff. I've got the version of that Nashbar fork without the canti studs and it works great and looks amazing for the price.
About your measurement, it looks like you are measuring the bearing race at the base of the steerer tube. This is another removable part that slides down the tube and seats onto a slightly larger diameter section of the tube. The good news is that you don't need to measure or match that. You need to measure the new fork. Or not measure because it will be a published spec.
Still stupid and seriously neglected..
Quoted: 9 Post(s)
I am starting to finalize my parts list. Ive been back and forth between flat and drop and I have decided to go with the a flat bar. Build list is below.
Nashbar Cyclocross 1" threadless fork
Cane Creek 40 Headset
Surly Moloko Bar
Cane Creek Flat Top Brake Levers
Cane Creek SCX5 Canti brakes
Shimano SL-RS700 Shifters
Shimano Ultegra FD-R8000-B Front Derailleur
Shimano Ultegra FC-R8000 Crank 50/34
Shimano Ultegra RD-R800-GS Rear Derailleur
Shimano Ultegra CS-HG800 Cassette 11-34
Shimano SM-BBR60 Bottom Bracket
Hope to have the frame cleaned, prepped, and painted this weekend.
Surly Moloko Bar
Quoted: 9 Post(s)
Finally had some time to work on this over the last month. I was able to get the several layers of paint down to bare aluminum and went back with a Italian Olive. Got the crown race on, and cane creek 110 pressed in. I have run into an issue with the cantilever brakes on the front. I replaced the fork that came with the bike with a surly cross check fork. The studs on the fork are smaller than those on the frame. I should have check before purchasing, but I didn't know canti studs had different id's. I am going to try and find some hardwear that fits the surly stud, and will sit into the brake cup. Any advice?
Bikes: Koga Miyata GranTourer 1985, Koga Miyata Adventure 1992, Cinelli Sentiero, Giant Terrago 1993, Presto Amsterdam 1975(?), Dahon Classic III Stainless
Quoted: 38 Post(s)
Liked 37 Times
Paint job looks great. The different canti stud sizes surprise me. As far as I know, all canti bosses have the same outer diameter. Did you take actual measurements of the front and rear studs? I'm asking because the cantis flopping around on the studs may also be caused by a missing bushing. Some cantilever brakes have thin brass bushings that like to fall out and roll under the fridge while you're looking the other way. When you then put the canti back there is going to be lots of play between canti and stud.
The fixing bolt that threads into the stud and retains the cantilever should be an M6.
Quoted: 761 Post(s)
OP this nashbar touring bike seems to have be the reincarnation of the fuji touring and windsor touring bike (2014 Bikesdirect). I have the Fuji and compared it to the other two bikes and they are identical, even down to the FSA *Vero* crankset.
So perhaps researching those bikes would help?
Hello to all.
I have always been a mountain bike guy and just recently picked up an old Nashbar Touring bike that the plan is to strip down, repaint, and modestly upgrade. Bike came with Shimano 105 group set, Tektro inline brakes, FSA Velro 30/39/50, shimano 11-36 , Mavic Open Sport with 28C continentals on it. The front fork was pretty rough so my plan was to get a new fork and headset. I got the bike stripped down and go the headset removed. This is my first threaded fork Ive worked on but everything came apart pretty easy. I went to research fork/headset combos and quickly got confused. The measurements on my head tube do not seem to match and headset I can find. The headtube has two flared cups, one on the top, and one on the bottom. The cup on the top has an ID of 39.4, the cup on the bottom has a ID of 42.06. The depth of the top cup is 7.15 and the depth of the lower is 9.89. I am looking for advise of possible headset fork combos that might work. It wont let me attach any pictures currently, but I will as soon as I have enough posts.
Quoted: 9 Post(s)
Quoted: 9 Post(s)
That's good information, and you're right they do look identical.
Quoted: 38 Post(s)
Liked 37 Times
The canti sit on the stud fine, but the bolts wont thread into the boss. The OD is the same its the ID that is giving me an issue. I looked on surly's site and it list the thread pitch as M5x1, I don't have anything at the house that will thread into it so I am going to take the fork to the hardware store to see what I can figure out.
Quoted: 9 Post(s)
Got it mostly buttoned up. Ended up ordering the nashbar carbon fork like I originally wanted. Still have a few things but I’m super happy for my first build
Bikes: 2009 Masi, 2014 Specialized Crossroads 1975 Schwinn Unicycle
Quoted: 12 Post(s)
Hello, It looks great. Might have been power coated? Originally. In the 1980's Nashbar was selling a few complete bikes. Back then, delivery was *riding the dog*. They'd deliver it to a Greyhound Bus terminal of your choice. You have the newer one. Back then it was the *Nashbar Toure* Had a lost wax,finish. Half-step plus granny triple crank. cheers
Barchettaman
Bicycle Mechanics
12
02-23-11 03:40 PM
