How to Make bike decals?
Strong Walker
A while ago for fun I made a bunch of these. I used an ink-jet printer on decal paper from the hobby shop, sold for plastic models. When I put the first coat of clear on it it ran - the red in particular; next one I will go *very* light coats to see if that will help. I would probably also run a marker along the edge (before applying) to get rid of the white rim. This is on powdercoat, it stuck just fine:
You could probably test print a few red patches and experiment with different types of clear coat to see what works as an "isolating layer" between the ink and the final clear coat?! Or maybe find a very thin clear adhesive fool to cover the decal before applying the clear coat.
Quoted: 1372 Post(s)
Liked 1,752 Times
How or on what sort of printer do you print or make your own waterslide decals?
These days, I invest a good deal of time preparing and painting a bike. When I go to the trouble and expense involved, I choose to use good quality stickers or decals from suppliers that I trust. In closing, believe this...
In the bicycle dictionary, next to cheap, they have a picture of me and how much I spend on my bikes. I strive for zero, but usually fail. This one, however, did not set me back one single cent...
Why did it not cost a cent? Because I did not buy it. I was lucky to know bikes, a bit, and realized that the Apollo had been repainted as a highly collectable Cyclops. And there-in lies another danger, when it comes to painting a bicycle frame. Issues might surface should the bike ever be offered for sale.
Anyway, short answer - injket jet on clear decal paper.
I didn't even know there was a such thing as 'clear decal paper'.
How does the inkjet ink hold up to fading?
Something that comes to mind is a picture I printed about 5 years ago that I framed and hung on the wall in my office, its faded to about half its brilliance and its not in direct sunlight. The blues turned sort of a very light pastel blue and the reds turned to a pinkish color from what was a bright picture on HP photo paper framed behind glass in an 8x10 frame.
A buddy of mine worked with a guy who had an old ALPS dye sublimation printer years ago, he made me a set of decals for a minibike I restored. They were bright red and blue when I put them on, and we cleared over the decals. Now, 15 years later the red is a light orange color, and the blue turned to a faded turquoise color leaving only the black shading part of the lettering. They looked 100% original when first done but they faded bad pretty fast. Now a days I can buy professional decals, back then they weren't available, but that's not always the case with bicycles and from what I'm seeing, some bicycle decals can get pretty expensive. It wouldn't make much sense to put $50 or more worth of decals on a bike that's maybe worth a few hundred bucks in the end.
Another problem I see is that most of the decals I seem to need are either white, silver or gold, none of which can be printed on an inkjet printer that I know of unless someone is making custom ink these days.
It seems most of the bikes I've needed decals for have been painted black or dark red.
I rarely run an inkjet these days, I switched to a color laser about 15 years ago when Minolta came out with the 2400.
Quoted: 3464 Post(s)
Liked 2,831 Times
contact a known supplier of graphics.
Get the vector art done in an acceptable file format.
The experimentation is fine, but the added cost to get them pro printed will outweigh a bunch of experimentation.
All the home made attempts I have seen fall very short of the time, energy and money expended.
bOsscO
Bikes: 2024 Spec Crux, 2015 Norco Search S1, 93 Mongoose IBOC COMP
Quoted: 296 Post(s)
Liked 355 Times
Mr. Anachronism
Quoted: 526 Post(s)
Liked 256 Times
So has anyone ever tried this on a Cricut using quality vinyl? I just happen to know someone with a Cricut...
