Compressor With Adapter
Quoted: 1814 Post(s)
Liked 923 Times
Thanks for all the responses and tips - the two things that stand out for me is rubber hose and quick release hardware - and I now have some ideas on different inflators and compressors - so now check my thought process - our local NAPA store has rubber hoses at various lengths and all have plastic threaded end pieces , Home Depot carries Seneco and Ace hardware has Craftsman compressors .
So now I'll need a female quick release adapter for one end of the hose and a male for the other end - did I get it right? anything missing ?
Compressors and air hoses generally come with the quick-connect fittings these days.
I have one of these- without the nailer. It has a tiny motor/compressor, and takes a long, somewhat noisy time to come up to pressure, but is light, small, & portable.
https://www.amazon.com/Senco-PC0947-...ef_=ast_sto_dp
Also been using one of these for 15 years. Compact, QUIET, but surprisingly heavy. Recommended.
https://www.amazon.com/Makita-MAC700...00SCSBPQA?th=1
Advanced Slacker
Quoted: 2763 Post(s)
Liked 2,537 Times
Quoted: 5232 Post(s)
Liked 3,600 Times
Thanks for all the responses and tips - the two things that stand out for me is rubber hose and quick release hardware - and I now have some ideas on different inflators and compressors - so now check my thought process - our local NAPA store has rubber hoses at various lengths and all have plastic threaded end pieces , Home Depot carries Seneco and Ace hardware has Craftsman compressors .So now I'll need a female quick release adapter for one end of the hose and a male for the other end - did I get it right? anything missing ?
senior member
I see you're NW of Boston , our daughter lives in Newton .
Liked 3,600 Times
Yes , if you click the second link above provided by WoodCraft you'll see a compressor and right below a picture of a highlighter yellow hose - that's the same one NAPA carries - my issue now is getting the right male fitting for the hose to insert into the compressor, not sure if they're included with the compressor ??
Quoted: 1616 Post(s)
Liked 2,218 Times
4.5 HP 20 gal compressor always at max pressure. Only good for about 110 PSI so use the floor pump to take it the rest of the way.
Liked 923 Times
There are two main types of connectors, but one- now called "M" style, has become near universal so you mainly just need to get either male or female threaded ends as needed- they're cheap- get both.
senior member
Thinking about doing similar, Park inflator with either Senco or Craftsman compressor - could you post a pic of the hardware at each end of your hose and also did you have to thread a 3/8" NPT fitting onto the Park so that it was compatible with the female fitting on the hose - with a pic I'll also be able to see the fitting that goes into the compressor - thanks in advance .
Jedi Master
Quoted: 2026 Post(s)
Liked 1,096 Times
The park inflator comes with a regular M-style male connector. I guess there's also a Q connector, but I can't remember ever seeing one IRL. I've never thought twice about it and every pneumatic tool or connector I've ever bought has been compatible. Maybe I'm just lucky?
The Park inflator doesn't seem as badly designed as cyccommute claims but it is way too expensive. Prestacycle sells their Prestaflator, which is similar to but a more versatile compressor inflator with an analog or digital pressure gauge at far less cost. Amazon, Performance and other on-line bike shops sell them.
Quoted: 7 Post(s)
Depends on the setup. I have a big shop-compressor in the garage that I never use for bike tires, but the tanks on this little compressor fill in about a minute, and I can inflate bike tires in a few seconds. It's definitely more useful if I'm inflating a bunch of tires or installing new tires, seating the bead and inflating from zero. For topping off two tires on one bike it may be only a few seconds faster and probably not worth the hassle. I also use an hand pump if that's more convenient so it's not an either/or thing. I spend a few thousand dollars a year on my cycling hobby so a nice little compressor/inflator that will last a decade or more isn't that significant to me in the grand scheme of things relative to the joy it gives me every time I use it. I've definitely spent more money on things that are less useful.
I run road tubeless 28c and have been looking at this unit. Does it seat tubeless tires without a problem? I have not seen any minimum spec for compressors to be able to do this. I suspect it is as much about volume of as raw pressure although both are related. I don't want to spend too much on a unit that I will only use 3 or 4 times a year.
I see you also use the Park tool. Can this also be used on car tires?
Bikes: Spot ACME with Shimano Alfine 11 & Gates Carbon Drive
Quoted: 39 Post(s)
Liked 78 Times
I have one of these for inflating my tires. You just set the PSI on the illuminated display, and the inflator shuts off automatically when it reaches that pressure setting. It comes with a presta adaptor too.
https://www.amazon.com/gp/product/B0...e?ie=UTF8&th=1
Quoted: 2333 Post(s)
Liked 2,097 Times
EVT 3-1 is fantastic.
Jedi Master
jtburn, I don’t have any tubeless bicycle tires so I can’t confirm this compressor will work for that specifically. I have used it to seat tubeless motorcycle tires so I assume it would work for bicycle tires too. I have a different inflator that I use for car tires so I’ve never used the park inflator for that. It might work, but the angle would be cumbersome on my cars.
Quoted: 7 Post(s)
Quoted: 681 Post(s)
Liked 949 Times
Quoted: 39 Post(s)
Liked 78 Times
yep just got one as I had plenty of makita batteries works great. wish you did not have to sue an adapter I debated on changing the head. my only complaint is for some reason it does not have a locking trigger. easy to fix wit ha zip tie but it seems a silly thing not to have.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Then I just remove it when I'm going to air up my vehicles tires.
Quoted: 681 Post(s)
Liked 949 Times
Yeah, it would be nice if an adapter wasn't necessary but I just leave one of these in mine all the time and it's a snap to top off my prestas.
Liked 923 Times
Someone was giving this away, so I acquired it. They said maybe it leaks, but the air hose fittings were loose & not sealed, so I think the owner just didn't know.
Low power, & crappy reviews because of easily broken manifold, but quiet and sort of compact.
senior member
The inflator is threaded into the hose or more commonly into a quick connect so that you can swap heads on the hose for other uses.
The Park inflator is a lovely bit of kit. Unfortunately, it makes for a better wall hanging than an inflation tool. The tool is heavy. It’s awkward to use. The angle of the tool on the valve is wrong. It’s a very expensive hot mess.
Quoted: 681 Post(s)
Liked 949 Times
12.00 and now the akita is great no adaptor needed. works for both the only thing I noticed it did not show the pressure till I started it. so maybe it was not pushing the valve down enough.
I went back to using a Lezyne floor pump with Topeak smarthead.
Works great and not much effort required to inflate to 100 PSI which is the most I ever use.
Bikes: 2016 Masi strada vita due, 2019 Kona Dew Plus
Quoted: 268 Post(s)
Liked 80 Times
Ive got one of those! Had it for cpl years/works great. Have used it to blow off disc brakes, but just bought an adapter to fill tires.
Mad bike riding scientist
Quoted: 6240 Post(s)
Liked 4,250 Times
I didn’t say the angle of the head is wrong. The whole angle of the tool is wrong and makes it difficult to use. If the handle were at about a 15° angle to the head, it would be much easier to use.
Stuart Black
Stuart Black
