I would LOVE to see photos of your MTB conversion
#251
Bikes: Rebuilt Trek MultiTrack 850
Just starting a rebuild of my '94 Trek Mountain Track 850. It used to be some sort of ice blue/green color. A friend and I completely stripped it to bare metal. I had thought to leave it that way, but weather in Seattle being what it is, decided to put on some coats of rattle can gray. Actually looks kinda cool, although I do miss the details of the brazing.
Here is the start of the build.
Parts used:
Bars: Origin 8 Tiki
Headset: Cane Creek S-1
Fork: Surly Long Haul Trucker
BB: Shimano something...maybe LP-27? Simple and cheap with square taper.
Crank: Dunno, it's going to a Christmas surprise.
Brakes and shifters are also hopefully going to be a Christmas surprise, but might turn into a New Year's surprise.
**edit** Wheels: Stock wheels & hubs from the '94 Trek (Alivio I think). These will be replaced when the money is available with some custom jobby.
The plan right now is to get as many parts in black as I possibly can. I'm then going to do the Bright Bike thing (google bright thread I think) and do some sort of design in retro-reflective material on the frame.
Parts used:
Bars: Origin 8 Tiki
#252
Not really a conversion, Made this way by Koga Miyata (NL)..
could put Knobby tires on it to trail ride,
minus Racks and such, I suppose, suspension fork is short travel though.. rack fitted with OEM custom parts..
more a gravel road adaptation.
WB Bicycle Gallery: Robert Clark's Koga Miyata WTR
Since then saddle and seatpost changed (thudbuster ST), Red nylon Karrimor has been retired in favor of a Canvas Carradice ..
Halogen headlight replaced by a eDelux LED & taillight wired up to headlight
Crank to a Shimano M730, with a Surly stainless 38t. 110bcd. Ergon Pedals
#253
@fietsbob
I was just looking at your bike on cyclofiend. I love that site for getting ideas on how to proceed with my conversion. Nicely done!
https://www.cyclofiend.com/working/20...clark1008.html
#254
David H.
Bikes: 92 Koga-Myata road bike, 07' Gunnar Rockhound 29'er mtb, 06' Kona Cinder Cone 69'er Gravel Bike, Windsor 8 spd IGH steel commuter, 99' Trek 520 tourer, Minnesota 1.0 Fatbike
Quoted: 8 Post(s)
Here is my 1991' Miyata Elevation 400. Triple-butted chromoly frame, 20 inch size. I took it down to bare metal and rattle-can painted it in a new scheme inspired by folks on this site.
Ancient Sun-Tour bar-end shifters from a 1980 Holdsworth Elan Frame. Tru-Vativ external bearings hollow-crank MTB crank with 44, 32 and 22 rings. 13 thru 28 7 speed freewheel in back. Wippermann 7 spd chain. Carbon fiber touring bar with Brooks tape to match the B17 saddle and some really great Cane Creek aero brake calipers. Nashbar front racks. Rear rack... I cannot remember. I will be using my tried and true old Breezer Grocery Panniers for rears with lightweight dry-bags for clothing and such from my kayak camping days since those panniers are just wide-open Grocery panniers and just got a pair of the Nashbar front Panniers and a wicker basket from my LBS. Vitorria Randoneuer Pro tires 26 by 1.5 on a set of older Mavic 36 hole rims and hubs that are in almost-new shape, Lezyne pump, Shimano LX front De and Campy Mirage rear De (they matched in color... what can I say?) And a third bottle cage thanks to Minoura. I replaced the old brakes with the Nashbar $19.00 set all around and cool-stop pads. Great deal for brakes.
The headset is a 1 1/4 inch threaded... Wild! I used a 1 1/8 adjustable stem with a shim to finish off my headset/stem set-up. It cinches down tight enough that I have no worries at all after testing it pretty roughly for give. The aluminum fenders are from a German 3 speed I bought some years ago at a garage sale. Nice to finally use them! Being a pack-rat and bike-junk collector does have it's advantages I guess...
The ride is fantastic.
I hope you like it and thanks for all the inspiration!
Here is a "before" shot:
And here is post conversion:
[/INDENT]
[/INDENT]
#255
Bicycle Repair Man !!!
What about if you go the other way and start converting a hybrid into a mountain bike ?
I have a matching 45 for the rear and if I pulled the fenders could run even wider 29'r wheels and tyres.
#258
This makes more sense to me then a full-on MTB conversion. Especially if you are going long on 'mostly' smooth roads. Must be pretty wide 700 rims to take a 45? Nice, once again 65er.
#259
Will probably run a pair of 38 cross tyres in the summer.
#263
Bikes: Too many to count. Changes on a frequent basis.
Quoted: 8 Post(s)
I just picked this bike up yesterday. It's a Specialized Hardrock Sport. So far I replaced crank, tires, saddle and added rack and day panniers. I have it set up as is for commuting, but plan to reset up this spring for short tours, centuries.
#266
missing in action
Quoted: 42 Post(s)
Liked 49 Times
The latest incarnation of my Rockhopper. I replaced the brake levers and added some of Velo Orange's hammered fenders (45mm x 650b.) Lipstick on a pig really, but I'm a sucker for shiny aluminum...
#267
The 2.5 watt halogen that is wired to the generator is decent although I will be looking to replace it with the LED version as they are brighter and have a nearly indefinite bulb life.
#269
How did you find those marzocchis? I have a pair and am tempted to try them - not too heavy, enough travel for trails but I'm a bit concerned with them being air suspension. I understand they need more maintenance to stop the seals wearing.
After having used road bikes for touring for several years, I thought that MTB's would cause less trouble on bad roads. To try the idea I just put a rack and a low rider on my first MTB I owned. It was built on an italian custom made CroMo frameset and had a Marzocchi suspension fork with about 35-40 mm travel back in the mid 90's. But this bike was originally built for sport, and its geometry forced me in a position with my back nearly horizontal, causing back and neck aches. So after one trip I had to decide for something else. The next touring MTB was a Specialized Rockhopper with steel frame. Unfortunately the frame was too weak for travelling with panniers, resulting in nervous shaking of the whole rig from about 25 km/h - dangerous and very scary
The third approach was a Cannondale F-800 in 1998, which finally worked. I did a lot of trips with that one and also used it to go to work every day. The Headshock suspension fork is as stiff as a rigid fork and was one of the first to provide a lock-out. IMO the best suspension fork for touring (with coil springs, not air) . However, last spring I decided to let my hard working mule enjoy its well-earned retirement. The bike is still in use regularly, but not for loaded touring any more.
Attachment 112100
Attachment 112100
#270
here's my convert...
Marin Rocky Ridge, first overnight trip. And yes, that's a solar panel on the back.
But I'm in the process of getting a legit touring bike now.
#273
Stealing Spokes since 82'
Bikes: The always reliable kuwie
Its much nicer having the metal fenders huh chris, since i got the steel ones i hate riding my bikes with the plastic fenders on them.
#274
I purchased this Trek 950 SingleTrack new in 1997 for $550. I immediately converted it to a commuter. Most bicycle shops thought I was nuts and tried to steer me in another direction. The ones that didn't tried to sell me a smaller frame and a front suspension. But I knew what I wanted and I knew what would work for my purposes. This generation of MTB's were a true value; good components and bullet proof frames.
I've always wanted to tour on a bicycle, and as I approach retirement/empty nesting this will probably be bike on which I test the waters.
#275
missing in action
Quoted: 42 Post(s)
Liked 49 Times
