vintage road bikes, no granny gear
Bikes: Tommasini Super Prestige, Kamra Triathlee, Nishiki Tri-A equipe', Sakai 2000
Found a pretty informative link explaning the how, why and when of it all - https://bikehugger.com/post/view/the-...-compact-crank
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
All in the motor (see: legs). As for Potter's, there were too many people walking to literally ride a bike, no matter your strength or gearing. I was forced to get off my ordinary and walk because it was bottle-necked to a stop. Did you not ride this year? Twister was *much* worse than Potter.
BTW, what time of day do you generally do your riding? I keep hoping to see more ordinaries and unicycles on the route, but I must go at the wrong times...
- Scott
Quoted: 659 Post(s)
Liked 595 Times
My Trek 460 being their entry level racer has the typical 52/40 crankset and the middle of the road gearing on the freewheel, 14/24. Still, it is no granny gear. More akin to jezebel's sister by time I get to the top of a steep one.
Bikes: Surly Trucker
Twister didn't seem as bad. Maybe the crowd was more spread-out or I was in better shape this year. (Oh man, that "Last smoothies before KILLER HILL" sign afterward was evil...)
- Scott
- Scott
We leave between 7 and 9 in the morning and ride about 12-14mph depending on wind and such.
Liked 2,568 Times
- Scott
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
This is simply not the case. Many racers of course used Campagnolo cranks when these came out, and the smallest chainring these would take was a 41 - though these are rare. Initially, the smallest was 44, until the bcd changed circa 1966. But Stronglight made a number of double cranks intended for racing that allowed for a 38 inside chainring; the Williams C1000 (a common choice in its day in the UK) took a 32 (the AB77 cotterless double could take a 26); and Magistroni made a number of doubles with 116 bcd that could take smaller inside chainrings. There are more examples.
Quoted: 967 Post(s)
Liked 1,630 Times
Bikes: '39 Hobbs, '58 Marastoni, '73 Italian custom, '75 Wizard, '76 Wilier, '78 Tom Kellogg, '79 Colnago Super, '79 Sachs, '81 Masi Prestige, '82 Cuevas, '83 Picchio Special, '84 Murray-Serotta, '85 Trek 170, '89 Bianchi, '90 Bill Holland, '94 Grandis
Liked 12 Times
No Money and No Sense
feros ferio
Quoted: 1393 Post(s)
Liked 1,328 Times
The low gear on my Bianchi and on my Peugeot is 42/26; Capo #1 has a very similar 38/23. These admittedly will not get me up Fargo St. (Los Angeles), but they work for everything I encounter around here. The Bianchi came geared 52-42 / 13-23, which I dropped by 10% across the board for the Capo, to 47-38 / 13-23. That 10% decrease in ratio is quite noticeable.
If you are stuck w/ a 144mm BCD crank, consider swapping the rear cluster, chain, and rear derailleur -- 42/34 or even 42/32 will let you conquer most hills. Alternatively, a 48-34 compact double makes sense.
This is simply not the case. Many racers of course used Campagnolo cranks when these came out, and the smallest chainring these would take was a 41 - though these are rare. Initially, the smallest was 44, until the bcd changed circa 1966. But Stronglight made a number of double cranks intended for racing that allowed for a 38 inside chainring; the Williams C1000 (a common choice in its day in the UK) took a 32 (the AB77 cotterless double could take a 26); and Magistroni made a number of doubles with 116 bcd that could take smaller inside chainrings. There are more examples. The big influencing factor on the relatively large size of inside chainrings on racing doubles until about 1962 or so was the commonality of half-step gearing (though some touring types would use a "half-step-plus-granny" setup).
Sorry
Marc
Bikes: Schwinn, Bottecchia, Miyata, projects
If you can find one of these (or something similar), you may be able to have your triple, keep things vintage and not break the bank.
Sugino AT
Sugino AT
52-42 chainwheels, 14-28 rear clusters were common throughout the 1970's bike boom but even then knowledgable writers like Fred Delong and Frank Berto were complaining about them. Buying a higher end bike back then just got you a narrower range rear cluster (since you were supposed to be racing it). We didn't complain because we all had 17 year old knees and didn't mind mashing up a steep hill with all our leg hinges screaming. Experienced cyclists who knew the value of spinning on a long tour equipped their bikes with triples from Stronglight or T.A. where chainrings were available in every tooth size and so were freewheel cogs so a gear-head could put together his perfect combination.
The 1980's produced some nicely equipped touring bikes with triple chainwheels like some of the ones already pictured. Seek these out, they can be great bikes on many levels (tire choices, fender and rack mounts).
I don't consider a compact double to be an improvement on a triple for C&V bikes. With a triple you can set up the large and middle chainring to provide a tight range of gears for the riding you spend the majority of your time in. The small chainring is available for steep uphills or regular uphills when you've loaded your bike with extra gear. The small chainring doesn't need a great chainline to the rear cluster; it's usually used with only the three or four largest cogs anyway that it already lines up well with.
Triples are considered too clunky on modern bikes only because modern brake/shifter click shifting mentality did not match the nuances of front derailleur cage placement necessary on a triple. There are some brake/shifters that can do a good job of placing the front derailleur cage but that can't be operated with the same mindless abandon that a rear derailleur can.
With a compact double its most used gears in the middle range are achieved with severe cross chaining, large chainwheel/large cog and small chainwheel/small cog combos. Going from one chainwheel to the other always involves a large gear change in the rear cluster. This can be mitigated somewhat with a smaller large chainwheel, 48 or 46 tooth, that you use for most riding with the 30 tooth in reserve for hills.
I agree that a compact double is the cheapest and also a pretty good solution to putting lower gears on an older bike.
If you're putting together a high end touring bike check out this crank offering from Compass Bicycles; Rene Herse Crank. It will be available in triple with a wide variety of chainring sizes and low Q.
Bikes: 2014 Trek Domane 5.2, 1985 Pinarello Treviso, 1990 Gardin Shred, 2006 Bianchi San Jose
Quoted: 62 Post(s)
Liked 28 Times
My experience with a compact crank does not match that of MKahrl. 50-34 and 12-27. I spend the majority of my time riding in the big ring and can use all ten cogs; today's modern chains aren't bothered at all. If I need to climb, I use the small ring. 50-15 to 50-19 is a very popular range and happens to be in the middle of the cassette with a very nice chainline. I ride the same way on my bike with the traditional crank except I move to the small ring a bit sooner and my favorite range is 52-17 to 52-21 for most flat to rolling roads.
The difference in gearing between a 53-39 and a 50-34 is not so much; not nearly the big deal some people make it out to be. One less gear at the high end in exchange for 1.5-2 gears at the low end. As for the triple, the 30T ring gets you another gear or so at the low end over the compact.
But everyone is different; we ride on different roads, terrain and have different capabilities. So get out the gear calculator and figure out what works best for you. sheldonbrown.com/gears
Where are the pics of the quad cranksets?
Liked 12 Times
I think it's also worth mentioning that the Trek catalog from 1983 - the year the OP attributes his bike to - shows a number of models with SR cranksets with 40-tooth inner chainrings - surely the Trek 400, 500, 600 of the day qualify as a "common production roadbikes."
Bikes: Nishiki Prestige, Reign, IH Warrior, Rockhopper, Brompton, Q-Bike, Forever, Free-Ride, Dahon, Merckx Premium, Litespeed Teramo, Raleigh MTi 1000, Motobecane Fly Ti, OnOne 456, Kona Unit, Transition TransAM
For what it's worth, it's very possible mix and match parts with non-indexed downtube shifters. I converted my Nishiki Prestige from the original Sugino VP 165mm double crankset 52T/ 42T with 6 gear cassette 13T - 26T, to a triple crankset and new wheels with a mtb cassette/rear derailleur. It was surprisingly cheap and easy.
Original drivetrain, with which I couldn't make the Santa Anita/Chantry Pavement climb.
This is a summary of my mods:
1) 48/38/28 triple 170mm square crankset up front (took the 52 from the double crankset to replace the 48, $16 used).
2) Re-spaced the rear triangle to accommodate my new Maddux wheels (135mm, $60 new wheelset). Tires kept slipping off original wheels anyways.
3) 12-32T 8-speed cassette (SRAM PG-850, $20)
5) Old MTB 8 speed XTR rear derailleur (lying around in the garage, free!)
6) 68 x 127mm BB. Eyeballed and measured up the spacing required to accommodate the triple (Shimano UN-54, $19). This part cannot be underestimated. The original 116mm BB
with a triple would not work. The granny front ring would literally mash into the rear
chain stay and not allow the cranks to rotate.
7) SRAM PC-870 chain (8 speed, $15)
$130 with almost all new drivetrain parts, along with a new bottom bracket and a new wheelset. Shifting is like butter with the non-indexed shifters. The bike still weighed under 24 pounds and I'm able to make the Chantry Pavement climb 50% faster than guys with mountain bikes.
Here it is now (more or less):
Mostly Mischief
For me 39 front-28 rear will do most things except the oddball 15-20% hump some guys were writing about earlier. As my knees age I'm starting to see the compact advantage, though. Either the 39 ring or the switch to a compact crank/new BB is not too costly. Long cage classic Suntour derailleurs are still affordable on eBay.
Good luck!
Location: Rhode Island (an obscure suburb of Connecticut)
Bikes: one of each
Quoted: 8 Post(s)
Liked 12 Times
Turns out I work at an old folks home at the top of a steep hill. I'm really into granny gears. Sounds like I'm joking but it's true.
Go to the dump and get an old dead mountain bike and steal the triple off of that. Here's one on my old Raleigh;
Or steal the big cog off of an old dead freewheel. Drill it out and bolt it up. Here's one on my old Raleigh;
Quoted: 3464 Post(s)
Liked 2,831 Times
I dont know about a 39, but there are some quite steep hills in the greater LA area. The hills i am riding with a group are Palos Verdes Estates. It's one of the local places bicyclists go to ride hills. There are other hills, probably a lot more steeper in places such as San Fernando Valley, San Gabriel, and Pasadena, where riders seek out the hills. I am not particularly lookign for hills but riding in groups, it is common for rides to have some hills, they look for them.
Build a base on the flats, or ride the bigger lower loop of the PV Drives and Western.
It's a beginner friendly group. Sometimes there's someone on an older steel framed hybrid, like my 2 hybrids. I have done the ride with my 2 hybrid bikes, my problem is the Trek 760 gearing which is inordinantly difficult.
IF anyone's interested if you google Palos Verdes and biking you can see info on rides and elevations re these hills. It looks like the highest point is about 1400 feet above sea level. The ride i am doing starts at sea level but doenst go to the highest point of PV but it isnt that far off. The ride I am doing has about 3 hills in succession that are pretty challenging for beginners.
To recap info on my Trek 760 from above, it seems like my front cogs are 52/42 (which is harder gearing uphills than a bike with a compact double crankshaft) and my rear gearing is 12-21 (which is harder gearing going uphills than modern mountain bikes or roadbikes and also harder gearing than lower end 1980's road bikes not made for serious racing.)
So my problems stem from the gearing on the front and the back.
On the other hand, i have been riding this bike all around town on mostly flat surfaces and some very small rolling hills and it is an awesomely smooth ride and i like the smooth shifting (it has Suntour Supreme deraillers i think) and the close gears in back.
I think for the kind of group rides i am doing and want to do (ie the Solvang half century ride is coming up, and a prelude ride on the same course that is very hilly), I really would benefit from having a modern triple (or at least a bike with modern gearing in back and a compact double crankshaft in front.)
My local bike mechanic has said he can swap out gears on my Trek 760 either in back or in front, but i didnt ask and he didnt tell me the details of the parts he would use. If i do a swap out of parts in front or back, Im sure he can get me more useable gearing maybe low enough to go up the hills (which I can do now on my hybrid bikes but they are heavier) but I would lose the close gearing i like now, and the Trek 760 only has 12 total gears. He also said he could swap out all the gears with modern components front and back (for a price) but I am not sure i want to throw the money into this bike, particularly when it is really great riding as is (for everything but rides with steep hills.)
So I am thinking maybe of leaving this bike as is and getting something like a new Surly Pacer frame (which is steel) and having it built up with a modern triple setup, to use on group rides, charity rides etc, with big hills.
I like steel, but i was recently tempted with a used Trek Discovery Channel bike which i think was a 1500 model (aluminum with carbon forks) but with the discovery paint/limited edition. I test rode that (it has a triple) but (1) the ride is more jarring than my Trek 760 and 311 bikes (my 311 model is too small for me but i am having the headset stem swapped out/raised) and (2) this bike had tiagra components (deraillers and brifters) and i found them to be clunky (not sure if it was the deraillers or maybe the frame itself causing vibrations etc.) So i didnt like the aluminum framed Trek.
So i am considering Surly Pacer, Cross check (think i would prefer Pacer as it is lighter) or else buying another old steel frame to build up with modern triple....
Can anyone tell me if i got the 7 speed Megarange shimano cassette would i have to
1- change the rear wheel
2- change the deraillers front back or both?
3- change the chain?
Also does anyone have any experience using that on a bike like mine with 52/42 in the front? Will this be a good solution for me? Will it be useable for daily riding around town and also up and down steep hills with that big jump in gears to get to the mega gear? I mentioned this Megarange cassette to my repairman and he was negative on it, saying its a big jump to that easiest gear and he didnt like it as a solution.
The experienced riders on my group rides going up and down the very steep hills have instructed me to use my gears (I am on my hybrid bikes when i do this ride). Going up the hills i try to keep momentum and speed, downshifting gears as needed trying to keep same cadence, until i get down to the granny gear and then i just pedal as i can to reach the crest of the hill. Then going downhill, i shift through the gears trying to keep the same cadence as i upshift and gain speed. If i have that Megarange cassette it seems that this technique would go out the window because of the big jump in gearing, so this leads me to believe its not a good solution for me if i want to do a lot of rides on hills, that i would be much better off with a modern triple.
