Nashbar Fuji Track Pro
#102
i smell bacon
Bikes: Geekhouse Deerfield, GT Edge Ti, Spooky Skeletor, TET Track, Ritchey P-650b, Bridgestone MB-3
So... what doesn't clear? The chainring or the crank arm or both?
I suppose Omnium clearance is out of the question unless I get a non-sucky frame.
#106
モㄥ工匕モ 爪モ爪乃モ尺
Bikes: Custom frame
Oh darn, right. At that point you have no choice but skinny crank arms and 44t :| that sucks,
#109
Ths Hipstr Kills Masheenz
Bikes: tirove
aluminum like the a6 altair or whatever they call it gets a lot of its strength from the heat treating process after being shaped. once you do that, it's going to fatigue and lose a little more and more of its strength. a frame builder would probably be able to heat that section of the stay hot enough with the right duration so that it could be crimped and re heat cycled and it would still be rideable, but at what cost to frame life i don't know and with what percentage of failure i don't know.
it could be done but the skill and engineering that would go into it make no sense for a mass produced frame like this... just get another frame.
unless you're riding it around the street and 44t is fine.... or unless you want to get fsa carbon cranks anyway...
#110
maybe someone can clarify this for me. Just bought an ftp, and with all the discussion about crimped/non-crimped chainstays, I haven't seen what a non crimped would look like in comparison.
Thanks!
Thanks!
#111
GONE~
Congratulation, that looks like it's crimped. An uncrimped one has no indentation between the bottom bracket and that Fuji logo on the chain stay.
#112
Bikes: tirove
has anyone gotten an uncrimped frame who ordered it discounted on nashbar?
i'm beginning to think they are all crimped but it's the seatmast issue that is causing the dump. i guess just never ever ever change your saddle....
#114
Your cog is slipping.
#115
モㄥ工匕モ 爪モ爪乃モ尺
Bikes: Custom frame
Well when you cut it just cut sections off the cutt pieces like a steerer tube spacer,
Wait i have a feeling i dont understand the seatmast issue, whats the issue?
#116
That way we could at the very least compare the two
#121
Bikes: tirove
the seatmast is cut to a certain height but then the seat clamp has about an inch and a half of space inbetween the top of the two bolts and the top of the clamp
https://iucycling.com/_.htaccess/500/...st_Closeup.jpg
that space is supposed to be for fine tuning to give you a little bit of adjustability if you change your saddle or crank length. Problem is, it doesn't work and the only safe way to use it is to slam the clamp all the way down onto the seatmast and then tighten it, so that they mast takes a lot of the force of you sitting and the bolts don't have to clamp so hard. basically, they made the clamp mechanism too loose around the mast and it doesn't adjust at all, it just sits on top so the only means of adjusting is by cutting the seatmast, which has to happen right the first time and then can't be raised up if you, say, get shorter crank arms. I plan on measuring it out with 165's and a tall saddle like the turbo, that way I'm only increasing my knee bend if i switch to my arione and 165's, and not by that much. i'd rather have a saddle that's too low than too high. hyperextended knees are unhappy.
#122
モㄥ工匕モ 爪モ爪乃モ尺
Bikes: Custom frame
Well then, you can just cut spacers from the other half of the seatmast. like 1 inch or 2cm spacers right?
#123
Bikes: tirove
no, the seatmast can't be in pieces inside the clamp because that would compromise the structural integrity of the clamp.
think of wrapping paper mache around a 1' pipe, then hammering on the top of it. not gonna break unless you hammer hard enough to break the pipe.
now wrap two 6" pipes stacked on top of each other in paper mache. hammer and tell me the paper mache won't break. it will.
once you cut the seatmast it's done, you'll never get that frame to have a higher seat. forget about resale value to anyone with longer legs than you, and if you mess up cutting the mast then your only option is longer crank arms or a new frame. or a brooks saddle with stupid tall rails.
#124
Also note that Fuji made a running change to the seat mast design. The first-generation bikes that my teammates have all slip and/or creak. My crimped one also came with a different seat mast assembly that doesn't move or creak. Sighhh ....
