KERS bicycle
maybe you have seen it, but for me is stil and enigma how it works https://www.youtube.com/watch?feature...&v=UHPrOloikVE
Quoted: 14 Post(s)
Liked 13 Times
ya it demonstrates kinetic recovery but not much power is achieved. only half a bike wit no rider and it didnt travel very far. most effort put in the design of cvt i feel.
This will not move the bike suddenly and give a sudden jerk to you.
what about the sudden jerk applied by the flywheel in rear sprocket ???
there is slip in the clutch to avoid this. cork on steel, so not as sudden jerk
have you used nuvinci cvt in it or just a simple sprocket ?
what % of slip you are talking about ?
no cvt was used, i would recommoned using one, but due to budget/ time concers , it was avoided. the precentage of slip was dependent on the force applyed on the clutch. the clutch force was controled by the braking system on the handle bars the harder the lever was pressed the less or no slip .
how about changing the material of the flywheel?
Quoted: 1572 Post(s)
Liked 644 Times
I remember reading about one way back in the 60's.It used a piston in the bottom bracket to pressurize air inside the hollow frame tubes. A lever reversed valving to use the compressed air to drive the piston the other way.
I think that I read it in the April issue of some magazine.
We are trying to do the same experiment..We are thinkin of using a flywhel of mass 5 to 7 kg n gear ratio of 8:1 and flywheel dia of 20 to 25 cm....any suggestions???
Bikes: Jamis Quest Comp
Quoted: 169 Post(s)
I think it's quite a fun project!
I can also imagine it evolving into a bike people would like to own, perhaps; a 5kg flywheel plus drivetrain and fittings is still a significant amount of weight, but there are plenty of people who willfully ride 38kg bikes everyday.
Of course, most of those heavy bikes are comfort oriented and fully kitted-out, so maybe rendering your flywheel in a Dutch style fabbed in Alu would be the target.
Anyway, keep at it guys, and keep us up-to-date!
hell, some tours get by with less...
hi myself balaji from india .,i want to know that if we bent and turning at the turns in the road there will be a chance to upset
the clutch actuator used
I am working on the same project (KERS bicycle) but due to lack of sources i am facing problem in making clutch actuator .... How did you made the clutch actuator?? can you please send me the design
Randomhead
Liked 3,713 Times
you can see the pictures above. The clutch is made of cork. This thread has some hints if you actually read it. It's a thread from 2012, so I doubt the students that made that design are still around.
Nobody likes zombie threads, sorry, I'm closing it. Try to contact them through their youtube account.
Likes For unterhausen:
Raigoki
Training & Nutrition
5
12-30-14 10:03 AM
JAX_11
"The 33"-Road Bike Racing
38
02-26-13 08:40 PM
