Butted 4130 vs 631 vs 853
Quoted: 4218 Post(s)
Liked 3,895 Times
Break away bike? As in a folding/travel/coupled one? If so i would avoid thin wall tubing. Traveling can be hard on a bike.
As to the difference in tubing between the two riders- Of course the stronger/bigger rider's frame should be made with bigger diameter and/or thicker walls IF ALL ELSE IS THE SAME (as in intended use and riding styles). Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Pointy Helmet Tribe
Bikes: R5, Allez Sprint, Shiv
Quoted: 519 Post(s)
Liked 627 Times
In case it matters: I am going to be using this bike for travel and climbing, so some stiffness in the BB would be nice (with my weight, i dont spin up hills but grind up at 70-75 cadence). Would that change things?
Pointy Helmet Tribe
Quoted: 519 Post(s)
Liked 627 Times
Do you have suggestions on tubing size that might work?
Pointy Helmet Tribe
Quoted: 519 Post(s)
Liked 627 Times
Another update - order for my wife's frame placed. Figuring out the finer points of the geometry, but I had a question re the tubing.
We have settled on:
- TT: 1", 7/4/7
- DT: 9/8", 7/4/7
- English BB
Suggestions for tubing sizing for chainstay, seat tube and seat stays? I would assume a slightly beefier chainstay would provide better transfer while skinnier tubing on the ST and seat stays would provide more comfort. But not sure about what sizing to get that would provide a lively ride without being too flexy.
I'd like to be able to use 27.2mm seatpost, if I can..
We have settled on:
- TT: 1", 7/4/7
- DT: 9/8", 7/4/7
- English BB
Quoted: 321 Post(s)
Liked 263 Times
We have settled on:
- TT: 1", 7/4/7
- DT: 9/8", 7/4/7
- English BB
We have settled on:
- TT: 1", 7/4/7
- DT: 9/8", 7/4/7
- English BB
I don't think anything is going to be too flexy on a frame that small. Reynolds road SS are 0.6mm wall and the Columbus ones are mostly 0.8 I think. I really like the Reynolds ones and I have a bigger frame size (555mm ST centre to centre).
Likes For guy153:
Team Beer
Bikes: Too Many
Quoted: 116 Post(s)
Liked 160 Times
For stays, I would focus on the tire and crank interaction not the butting profile. For example, if you want to fit a 50mm tire (or fender) with a double crank coupled with a short chainstay you will need curved stays or some modification of the stays. That should be your first decision point. If there are butting options in the shape of stays that you need, the make that decision. Most likely there will not be many options.
I'm not one for fawning over bicycles, but I do believe that our bikes communicate with us, and what this bike is saying is, "You're an idiot." BikeSnobNYC
Likes For Cynikal:
Pointy Helmet Tribe
Quoted: 519 Post(s)
Liked 627 Times
Sounds like it's going to be a sweet bike. I like road stays but they don't allow for as much tyre clearance as the beefier curved ones (which are more intended for MTB, gravel and touring bikes.
Thanks again!
