Modern bicycle components/systems
With a mighty wind
Quoted: 1088 Post(s)
Liked 862 Times
Old 7 and 8 speed triple systems were a pain to keep in tune. I was messing with it nearly every ride until I just got used to where it over shifts and under. When I needed to shift past then come back down. It was ok but not nearly as maintenance free as my newish 10 speed stuff. With modern 1x, it's become even better.
I hated my hydro's when I first got them. Total pita, I think I posted a rant here about them. Then I learned that all you need to do is make sure they're bled, push the pads out with a tire lever, and pump a few times once the wheel is back on. It's pretty amazing actually. Bleeding is a couple minutes every year or so, but I know some people go a lot longer than that.
I've never heard a bad thing about electric. Better in every way with the added ability to mix mountain bike and road groups. I just can't/don't want to afford it.
Tubeless is superior if you're riding a lot. I've got 5 bikes and I ride them all but sometimes not every month. If I am worried about sealant congealing on the bottom, I'll swap to tubes. When riding a bike a lot, it's well worth it to be tubeless. Probably even more if you you have fewer bikes.
Seems like the OP was a complaint about things he doesn't understand.
Likes For rosefarts:
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
No doubt I am a cheapskate. Frugal, very frugal. Was raised that way, and have stuck with it because it does not bother me. Working at low wages in a bike shop also gives credence to frugality and simply put frugality is a necessity. I work in a shop and can buy things at near dealer cost, I can also buy things at near dealer cost on the internet, but that does not entice me to change cables and housing when it really is not needed. To my way of thinking that is wasteful, and when it comes down to it, environmentally irresponsible as it produces needless waste. As we all agree, to each their own.
QR-disc must die!!!
Bikes: '99 Trek 520, '20 Kona Sutra (FOR SALE 48cm), '21 Simon-Bikes mini-velo and a chromoly-framed folding bicycle with drop-bars and V-brakes, that rolls even while folded.
Quoted: 397 Post(s)
Liked 199 Times
The problem with disc brakes is not the brakes, it is the manufacturer trying to sell them with a frame/fork that were made for QR-skewers. Disc brakes don't belong on those frames/forks but people buy them because they don't know any better. I didn't know either, I just managed to get lucky, in that the bicycle I was interested in was made for thru-axles. People need to know that disc brakes paired with QR-skewers are a scam. Let bicycles with those mis-matched components rot on the retailer floor. The retailer shouldn't be trying to sell them.
As for 8spd triple crank, mine, a Shimano 105, has worked flawlessly for its 21 year existence. My new bicycle as well has a triple crank. I never saw a need for 1x or 2x. Fewer is not more.
Advanced Slacker
Liked 2,537 Times
It works just fine.
Quoted: 6972 Post(s)
Liked 10,971 Times
Wanna tell us what is so horrific about QR dropouts with disc brakes?
Likes For Koyote:
Quoted: 550 Post(s)
Liked 325 Times
I’ve come to the opinion that some of the technical ‘advances’ of certain bicycle components and systems may not necessarily be intended for us mere mortal bicyclists. They seem to need more “support” than the traditional counterparts they replace, which we’re not able to provided. I’m talking about components like disc brakes (cable and hydraulic), tubeless tires, and wireless/electronic shifting.
Bolting on new rotors takes less skill than lacing on new rims.
Tubeless tires are much less likely to require installing an intact inner tube after a puncture.
Electronic shifting never requires cable replacement which can be a bimonthly event when you ride a lot.
All of those improvements are friendlier to "mortal bicyclists."
Likes For Drew Eckhardt:
n00b
Bikes: Surly Karate Monkey, Twin Six Standard Rando
Quoted: 428 Post(s)
Liked 466 Times
I can use this here. it applies to BF in general. y'all are a bunch of crusty old curmudgeons and I love you for it. never change.
Likes For mack_turtle:
Destroyer of Worlds
Look at the 2021 cars....they literally drive themselves, have more computing power than my gaming rig (slight exaggeration), and have more technology-based systems than I could fit in a 30 minute speech. It's called........progress. So yes, your "new" car would require a support crew, that's what a car maintenance shop is. If you're coding for various tech related bugs or issues with the computer system, I doubt you're fixing that yourself. You're taking it to the dealership...your personal support crew.
Quoted: 1581 Post(s)
Liked 1,189 Times
That said, I too find thru-axles to be better on a disc-brake bike; have 'em on my newer one.
Likes For badger1:
Quoted: 1109 Post(s)
Liked 1,200 Times
I'm a geezer. But the only reason I don't have electronic shifting and hydraulic disc brakes is that between the wife and I we have 8 bikes with mechanical shifting, rim brakes and extra wheels that we're happy with and give us what we need. 8, 9 and 10 speed, 4 road, 2 mountain and 2 "gravel" (cross frames we set up at least 10 years ago for what is now known as gravel riding). I might switch my wife over to hydro disks before myself just because she might benefit because of hand strength issues. I might switch to electronic shifting sooner rather than later because my arthritic elbows are sensitive to the motion needed for mechanical road bike shifting, Shimano worse than Sram.
I would actually look forward to learning how to install and maintain these modern systems. We might take the plunge to new "real" gravel bikes and since they might be the last bikes we buy (HA!) and might give us wider tire options than the limitation of the rim brakes we have now (V and canti), I think I'd try electronic shifting, because do I want to die before I try it? Of course not.
But so many bikes we're very happy with and so many wheels! That's a lot of inertia!
By the way, I like it when the neighborhood kids make lots kid noise and invade my yard! I also pay them to mow grass and shovel snow!
Clark W. Griswold
Quoted: 4359 Post(s)
Liked 4,001 Times
People will always complain about things that is what we do and of course more complaints about the new stuff because it is new but we have had enough posts on rim brakes, inner tubes, cable actuated derailleurs, single speeds, fixed gears, friction, indexing, steel frames, aluminum frames...people complain it is what we do here.
New technology is a useful thing sometimes. It can be bad in some situations and more often can be excellent. It is a constantly evolving industry you get good and bad.
Liked 2,980 Times
-Oh Hey!
-Oh Hey!
Likes For Troul:
Quoted: 338 Post(s)
Liked 408 Times
The new stuff is just better, especially if you avoid becoming an early adopter.
Sure, mechanical shifting works great and is easy to adjust when it doesn't, if you aren't mechanically inept, and is a touch lighter, but DI2 works a hair better and is even more reliable. On TT bikes the ability to shift from multiple places is a godsend.
Disc brakes work better and I don't have to fret about using swapping my deep section carbon wheels in winter time, rain, snow or whatnot.
Tubeless, now it's matured a bit? Simply brilliant.
