Nishiki Serial Number Database
Old 07-19-21, 03:57 PM
  #2426
Quoted: 4722 Post(s)
Liked 3,039 Times in 1,877 Posts
Originally Posted by Thorbjoern
Can anyone help me with the year of this serial number:EC104671. How can I know if it's from 70-80-90? I only have the frame, so there is no other clue. Thanks for the help
It's a European market model manufactured by Kawamura of Japan and almost certainly built in 1983, which would make it a 1983 or 1984 model. Kawamura wasn't using an alpha character for the year in 1973, at least not in the North American markets, so I assume it was the same for Europe. By 1993 the brand had been sold to Derby Cycles and manufacturing had largely moved away from Kawamura, to less other manufacturers.
However, you can increase your confidence from frame characteristics. While there's no set rule, here are some general guidelines
1973: lugged construction, with traditional fork crown, long horizontal rear dropouts with 120mm spacing and little if any braze-ons. 120mm rear dropout spacing.
1983: lugged construction with traditional fork crown and short rear dropouts with 126mm spacing. Typical braze-ons would be top tube cable tunnels, water bottle bosses and down tube shift lever bosses.
1993: TIG welded construction with a unicrown fork and vertical rear dropouts with 126mm or 130mm rear spacing. Typical braze-ons per 1983 but likely with two sets of bottle bosses and a pump peg on the back on the head tube and possibly a front derailleur hanger.
Edit: I saw the photos of the seat cluster and head tube in your gallery album. The lugged construction, embossed stay caps and top tube cable tunnels point to 1983 manufacture. .
T-Mar is offline
Old 07-24-21, 12:32 PM
  #2427
A BIG thanks for the help - and a nice summer to you
Thorbjoern is offline
Old 07-28-21, 04:13 PM
  #2428
sunburst's Avatar
Bikes: Giant, Peugeots, Motobecanes, Kona, Specialized, Bike Friday, Ironhorse, Royal Scot, Schwinns
Quoted: 188 Post(s)
Liked 97 Times in 52 Posts
Can anyone identify the model of this 1980 Nishiki mixte? I can not find a catalog from that year. It has a chromoly frame so I assume it was their top-of-the-line model, if they had more than one. The serial number is KJxxxxx which I decode as USA, 1980.
sunburst is offline
Old 07-28-21, 06:05 PM
  #2429
I
i dont know how to post!
Rolley is offline
Old 07-29-21, 08:54 AM
  #2430
This is not high end. Nishiki did not have mixtes above very low mid-range during this era. Based on the serial number it is a 1980-1981 model, manufactured in 1980. During this period the CrMo models typically had chrome plating on the forks. If it is CrMo, it would appear to plain gauge and only for the main triangle, as the fork dropouts appear to be stamped. The derailleurs and brakes are mixed. Based on the CrMo tubing, crankset and what appears to be a SunTour Vx front derailleur, my leading candidates would be either an Olympic 12 or Royale, which would place it upper entry level to very low mid-range.
T-Mar is offline
Old 07-29-21, 10:44 AM
  #2431
sunburst's Avatar
Quoted: 188 Post(s)
haha, I'm used to restoring gas-pipe Peugeot UO-18's with heavy all steel cottered-cranks and wheels. I've done over a dozen of them. To me anything with alloy parts (eg wheels, cotterless cranks) is good, and with chro-moly frame is great! I don't rate mixtes like normal road bikes, as I have only seen fairly low-end ones, even Japanese, with the exception of this Nishiki.
sunburst is offline
Old 08-02-21, 10:33 PM
  #2432
Does anyone have any insight on the pedals offered on these bikes? My '83 Rally has some KKT's, but I don't believe they're original. Any Rally owners that care to share?
I'm a few posts away from being able to post pictures....
gnavs is offline
Old 08-02-21, 10:35 PM
  #2433
only 4 left
gnavs is offline
Old 08-02-21, 10:36 PM
  #2434
3 left
gnavs is offline
Old 08-02-21, 10:37 PM
  #2435
2 left
gnavs is offline
Old 08-03-21, 07:07 AM
  #2436
The pedals could change from on model to another and also change from year to year. Your CC- prefix serial number does indicate 1983 manufacture for the Canadian market, so it could be either a 1983 or 1984 Canadian market model. However, the March 1983 date codes on the brake safety levers have me leaning towards a 1983 model . While I don't have the 1984 literature, I do have 1983 and it does appear to be a good match, outside of the pedals. The pedals aren't spec'd but are non-platform, non-quill, double sided, track style pedal, unlike yours. The Rally was the bottom of the line model at the time and your KKT quasi-platform pedals are upscale for this level, so I suspect they are a comfort upgrade by a previous owner. You may be able to increase your confidence level via the date codes, which should an open alpha-numeric format, typically stamped into one side of the wrench flats.
T-Mar is offline
Old 08-04-21, 09:25 AM
  #2437
thanks for reposting my pictures T-Mar, I plan on starting a new thread to figure out the details with these pedals as I'd love to find some shoes/clips to match. I just don't know enough about this stuff yet to know what to search!
gnavs is offline
Old 08-04-21, 09:28 AM
  #2438
Also spent a bit of time repacking the wheel hubs, cleaning some of the grime off, and adjusting of the brakes. Gotta clean up the rear derailleur next.
That's 10 now! Finally free to post pics!
gnavs is offline
Old 08-04-21, 09:38 AM
  #2439
Here's the little one and I pumping up the tires. This forum's been a great resource so far
gnavs is offline
Old 08-06-21, 04:34 PM
  #2440
Quoted: 5 Post(s)
Hello experts! I found this thread on Google looking for info on a bike I were looking at (I since bought it). It is my very first old bike and so far I haven't done anything except buy it. The original parts left are the frame, fork, brakes, saddle and handlebars (as far as I can tell). Everything else is brand spanking new or almost. Shimano Tiagra 4700, etc.
The first post here have some very nice info, thank you for that. I'm a bit confused by the frame stamp on mine though as it has a W (US?) and I bought it all the way over here in Scandinavia! Anyways, the stamp is WBTO1000. US 1982 I guess? If it is actually a US model that somehow made it to Denmark that would be fun as I also bought a motorcycle that somehow made the same trip from Japan to the US to Denmark (a 1984 Kawasaki KZ700A1). Anyways... pictures!
Edit: Ugh, can't add pictures..
Dahoon is offline
Old 08-06-21, 04:38 PM
  #2441
Quoted: 5 Post(s)
Trying to be sneaky and add image links that doesn't get blocked:
hxxps://ibb.co/CH91W3F
hxxps://ibb.co/xSP4m74
hxxps://ibb.co/Cn7MyKD
hxxps://ibb.co/HNh7sBh
hxxps://ibb.co/0yKPmcS
Dahoon is offline
Old 08-06-21, 04:47 PM
  #2442
Quoted: 5 Post(s)
I forgot to ask a question! Any info on the bike would be appreciated. Especially what Dia compe model brakes it has (I'm guessing they are OEM but unsure?)
Dahoon is offline
Old 08-06-21, 07:11 PM
  #2443
That's a Danish VIN number, indicating that the bicycle is a Danish model imported by Taarnby a/s/. Unfortunately, it's missing the alpha suffix that indicates the year. Based on the Bianchi Argentin influenced paint scheme, I'd say it's circa 1987-1989. To get a better idea of the year, you'd have to check for date codes on the few remaining components. For instance there may be an open (mmyy) format on the back of the brake caliper arms.
Tange #5 main tubes in conjunction with hi-tensile forks, dropout eyelets and the era, suggests an entry level sports frame. I can't positively identify the brakes from the pictures but based on the quick release style they appear to be one of the ubiquitous Dia-Compe G-N, Q-N or QS-N series variants.
Selective photo assist...
T-Mar is offline
Old 08-10-21, 06:34 PM
  #2444
Slow
Galuple's Avatar
This looks just like my 83’ Olympic Mixte, but mine is in red. Definitely a lower end model, mine belonged to my grandmother, and she was far from a cycling enthusiast.
I just registered here so no pictures yet.
Galuple is offline
Old 08-12-21, 12:02 PM
  #2445
sunburst's Avatar
Quoted: 188 Post(s)
worked on another '70's Peugeot mixte this week. You guys don't know low-end 'til you lift one of these!
plus there's the plastic parts that break, the heavy(!) cottered crank, steel wheels, etc.
Having said all that, the Peugeot mixtes are one of favorite bikes and I've kept two 56cm frames for myself.
sunburst is offline
Old 08-12-21, 08:47 PM
  #2446
Quoted: 9 Post(s)
Liked 6 Times in 4 Posts
Can anyone help me with the year of this serial number: D10 2477?
It is a Nishiki for the Japanese market. It is probably from the 1990s.
Lugged chain-stays, the rest is welded.
Mono seat-stays down to the brake mount.
Pictures show frame and fork ready for repainting:
Jockie is offline
Old 08-13-21, 09:27 AM
  #2447
Pictures show frame and fork ready for repainting.
My guess would be 1991 but I'm not sure, as I haven't seen many Asian market models and the lack of componets complicates age determination. I find it strange that the frame is mostly TIG welded but that the fork is not a unicrown. If it is a known matching fork, it may be an off-the-shelf Tange model with an alpha numeric date code stamped into the steerer tube that you can use to date the frame.
T-Mar is offline
Likes For T-Mar:
Old 08-13-21, 04:43 PM
  #2448
Quoted: 9 Post(s)
The fork is not a matching one but it is a Tange model with 'Nishiki' stamped in the dropouts.
Jockie is offline
Old 08-15-21, 04:33 PM
  #2449
Londonsworld's Avatar
Bikes: 71 American Eagle Olympiad, 03 Trek 5200 P1, 2013 Trek 6 series Domane, 83 Apollo branded Kuwahara, 78 Trek TX 300, 73 Nishiki Intl. 86 Nishiki Prestige, Nishiki Olympic, 72 and 73 Nishiki Safari', two-speed Electra BMX cruiser 1, 87 Nishiki Linear
Quoted: 32 Post(s)
Liked 65 Times in 38 Posts
Had to ditch the Silk handlebars that came on the bike (Bent) I rummaged around in my pile of parts and found a Silk replacement.
Londonsworld is offline
Old 08-21-21, 05:38 PM
  #2450
jbrams's Avatar
Bikes: Rivendell Sam Hillborne, Rivendell Cheviot, 2007 Jamis Aurora, 2013 Salsa El Mariachi
Quoted: 5 Post(s)
Nishiki Bel Air mixte, 1985 (or 1986?), 3 pulley derailleur madness
Just got a Nishiki Bel Air, appears to be 1985.
Serial number: WE18620 = 18,620th frame produced in 1985 for the US market, right? Is it a 1986 model manufactured in 1985? Or a 1985 also made in 1985?
Brother-in-law family member is moving house and this was in the basement so got donated to the crazy bike guy (me apparently). I thought a steel mixte in red would be a fun project bike but this is a silly fun bike. The Sugino VP triple crankset caught my eye and I had no idea what to make of this Suntour XC 3 pulley derailer, weird! One of the pulleys needs to be replaced but the other two are serviceable. Gold anodizing is clean still. Love the color matched stem top and Suntour thumb shift levers. WE 18 620 (the "2" is obscured by paint and may have been slightly misaligned). I'd guess the bars and stem are original, yeah? Seems to be similar (but not clear if the same as) the shifter lever that Rivendell imitated in 1999 with their Silver shifter - is that right?
Planning to replace cables, housing, tires/tubes, brake pads, grips, saddle. The MKS pedals are kinda cool so they stay, I'll probably ditch the rack and add a basket to the front if the future rider wants. Maybe some handlebars with more back sweep (imitation Albatross or Bosco bars) and a Brooks B67, then if I get real excited I'll swap the rear wheel or cassette for a 9 speed if I can figure a way to have that work with the 3 pulley derailer.
Please let me know your thoughts, questions, and suggestions - this is my first restoration of something from this era so I'm open to suggestions. My other rides are Rivendells (Hillborne, Rosco Baby, and Cheviot).
Sugino VP crankset looks newish, the triple pulley derailer is nutzo but one of the pulleys needs to be replaced, the Avocet seat is shredded.
jbrams is offline
Likes For jbrams:
