How to get lube inside completely clean chain?
Quoted: 5793 Post(s)
Liked 2,590 Times
Hi FBinNY. Regardless of where the noise was coming from, or if it was the chain, do you suggest I re-clean the chain with the ultrasonic cleaner, and then either heat it or soak it (as you prescribe)? If I leave a chain that has been cleaned (ultrasonic) for a few days (not riding, just sitting), without heating or getting the water out, can it cause permanent damage?
BTW- if your ultrasonic is large enough, don't wash the chain in water. Instead put the chain in jar with some OMS or naphtha, close the lid tightly and put that into the ultrasonic. Glass is transparent to high frequency sound, so you'll get the same powerful cleaning action, without the drawbacks of water cleaners. Change and save used solvent in a tightly closed container, where the dirt will settle so you can reuse it in the future. You might need 3-4 rinses to be sure the chain is clean. When you pull the chain out, these solvents will dry completely within a short while (don't bake since the solvents are flammable).
BTW- do not use a flammable solvent in an ultrasonic, except in a closed container. The ultrasonic increases the evaporation rate of solvents, and greatly increases the flammability.
FB
Chain-L site
FB
Chain-L site
S'Cruzer
Next time dry the chain, either by soaking it in fuel alcohol (not isopropyl) or acetone, which will absorb the water and evaporate dry. Or heat the chain in an oven or if you live in a sunny a solar oven (your car, parked in the sun with one window cracked open about 1/2"). Once it's dry, you can oil the chain with the lube of your choice.
obviously, you didn't put anything up there that was dripping wet, but I baked the water out of several pieces of waterlogged electronics like a cellphone, by leaving it on top of the TV for a week.
kinad hard to do with today's flat panels, hahahah.
Liked 2,590 Times
If you wash is water, spin out as much as you can (outside) then bake it dry, or use a hair dryer.
FB
Chain-L site
FB
Chain-L site
Liked 2,590 Times
my old favorite place to dry stuff was on top of the big TV set, back when they were CRT's. they generated lots of nice dry warm air that rose out of the top.
FB
Chain-L site
FB
Chain-L site
Yes, you might as well wash it again since it probably has a water/oil emulsion inside. Wash it thoroughly with multiple rinses until nothing comes out. The put it onto the oven at 200 for about 20 minutes (Warning, if it isn't hot, your oven is broken). let it cool and oil it. If you're using Chain-L or Phil Tenacious, oiling while the chain is warm speeds things up and makes wiping excess off easier.
You provided excellent info ... thank you.
S'Cruzer
mine is A) in the garage, B) natural gas (humid exhaust fumes), and C) so well insulated it doesn't get warm on the outside.
an incandescent 75 or 100W light bulb in a desk lamp makes an excellent dryer. put whatever it is in a pan, shine light on it from a couple feet away.
again, not so good with CCFL or LED lighting :-/
btw, I second the emotion about using warm oil and/or oiling when warm. oil hardens to wax when its cold, and flows much easier when its warm or even hot.
Liked 2,590 Times
Do you think the water emulsion can prevent rust for the next 12-24 hours? I really can't get to this tonight. Well, unless my chain is likely actively rusting. I actually did 3 chains at the same time, so it's kinda a pressing issue if I fubared the whole thing.
FB
Chain-L site
FB
Chain-L site
Thanks. I will definitely re-ultrasonic the chains tomorrow, and probably take the heating route. BTW, maybe noob question, but what do you mean by OMS or naphtha? I'm guessing I don't have them on hand.
Liked 2,590 Times
OMS seems to be the solvent of choice among the knowledgeable here on the forum. I prefer naphtha because it dries faster (it's also more flammable) and seems to be a slightly more aggressive solvent.
Treat either with respect, use in vell ventilated areas, away from ignition sources (no basements), and either wear gloves, or limit contact with your skin. Handled with reasonable care either is relatively safe to work with.
FB
Chain-L site
FB
Chain-L site
S'Cruzer
napha is, I thought, more flammable than gasoline? OMS is pretty much light kerosene, give or take.
since you ultrasonic'd it in a water solution, I think I'd go with the acetone (because I have a can) or denatured alcohol (safer) soak and agitate to extract any remaining water, then compressed air blast it to get rid of that stuff, then drop it in a can and cover it with some warm oil, leave it overnight to let it thoroughly soak in.
So, one of the reasons I invested in an ultrasonic cleaner is because I was tired of the toxic chemicals. It seems the recent advice is steering me back that way. There are three reasons to limit the extreme chemicals: health, being kinder to the environment, and I don't have a garage. Is there a downside to ultrasonicing the chain in Simple Green & water solution, and then rinsing thoroughly, and then heating in the oven? I've got to admit, there is probably someone reading this forum that thinks we've all gone off the deep end of OCD. LOL.
If your ultrasonic cleaner has a heater in it the Simple Green will drive you out of your house. Otherwise I guess it's up to your nose.
I use Chain-L according to the directions. No ultra nothing, no solvents. Wipe the chain clean then..........well, follow the directions. No chain worries.
Quoted: 1438 Post(s)
Liked 1,092 Times
If you decide to dry the chain in the oven after thorough water rinses, set the oven to 250 degrees or so. You need to get the water above the boiling point long enough for it to vaporize and be driven out of the tight spaces in the chain. If you don't get it hot enough it will take a surprisingly long time to fully evaporate. Then lube the chain and go ride.
Honestly, I adopted my motorcycle chain cleaning mantra after years of worrying about constantly cleaning and lubing my chain I decided that I would just occasionally wipe it down with a rag and maybe a little kerosine and then relube it every once in a while. I figured chains are only about 70 bucks and it wasn't worth my time to constantly clean and lube and I could just replace the chain more often.
But the interesting part was it turned out my chains lasted longer this way.
I think constantly cleaning/relubing can just get dirt and crud in there and just keeping it lubricated works fine.
I remember we used PJ1 on motorcycle chain. It sprayed on like WD40 then set up with a "waxy" feel. I never had chain problems. It worked fantastic on door and hood hinges also.
Insane Bicycle Mechanic
Quoted: 809 Post(s)
Liked 712 Times
If you live in a house the next best place is on top of the hot water heater. If Jeff Wills is reading this, the hot water heater is one of my cats' favorite places when it's cool. We discovered this spot when trying to figure out why he had short whiskers with little balls at the ends on one side only.
1. The water heater is in the garage.
1a. The water heater is a recent, high-efficiency gas unit, heavily insulated.
2. My current project in the garage is generating copious amounts of fiberglass and Bondo dust. It's hard enough wearing a filter mask, much less putting one on a cat.
Back to the original sidebar: I'm of the opinion that over-cleaning the chain will kill your chain faster than not maintaining it at all. For my last couple chains I've just cleaned the dirt off the outside, scrubbing it with a shop rag sprayed in Simple Green, then lubing lightly if it's started squeaking. They've lasted through Pacific Northwet winters with weeks between cleaning.
Jeff Wills
Jeff Wills
Quoted: 809 Post(s)
Liked 712 Times
Jeff Wills
Jeff Wills
Liked 2,590 Times
The water heater itself is a new high efficiency, well insulated unit. The top is just a bit warm, which is why Pesto likes to sleep there. It's the flue pipe that is hot enough trim whiskers.
FB
Chain-L site
FB
Chain-L site
So, just want to spice it up a little ;-). I see these road cyclists ride by me (other side of the steet, of course ), and I never see them worrying about their drive train noises. So, are they mostly expert home mechanics, blissfully ignorant, or have plenty of money to spend for quality maintenance?
That said, I appreciate everyone's attention to detail, and their way of doing things. I'm reading all input, and synthesizing. Much appreciated.
Liked 2,590 Times
FB
Chain-L site
FB
Chain-L site
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
