Track Cycling: Velodrome Racing and Training Area Looking to enter into the realm of track racing? Want to share your experiences and tactics for riding on a velodrome? The Track Cycling forums is for you! Come in and discuss training/racing, equipment, and current track cycling events.
Interesting finds around the web
Old 01-26-18, 02:37 PM
  #1601
Poppit's Avatar
Quoted: 111 Post(s)
Liked 5 Times in 4 Posts
Harry Tanfield
Poppit is offline
Old 01-26-18, 03:53 PM
  #1602
Quoted: 17 Post(s)
Monkeyfudger is offline
Old 01-26-18, 03:58 PM
  #1603
Quoted: 17 Post(s)
Old 01-26-18, 04:00 PM
  #1604
Poppit's Avatar
Quoted: 111 Post(s)
Carbonwasp bars
Poppit is offline
Old 01-26-18, 04:01 PM
  #1605
Quoted: 17 Post(s)
Pics from VeloUK, my URL keeps hiding itself
Old 01-26-18, 04:04 PM
  #1606
Poppit's Avatar
Quoted: 111 Post(s)
Not sure what happened for Charlie to catch Dan in the final
Poppit is offline
Old 01-26-18, 04:06 PM
  #1607
Poppit's Avatar
Quoted: 111 Post(s)
BTW, I think Dan’s CDA is now around 0.17
Poppit is offline
Old 01-26-18, 04:30 PM
  #1608
zizou's Avatar
Quoted: 21 Post(s)
I dont know if accurate but on the kgf instagram live video Tanfields 3000m split was given as 3.07...That is well inside world record pace. Maybe explains the catch - I was a little surprised he sat up afterwards maybe went out so hard the wheels were about to come off!
Of course i may have misheard the 3.07
zizou is offline
Old 01-26-18, 06:37 PM
  #1609
Bikes: Marin Stelvio, Pogliaghi SL, Panasonic NJS, Dolan DF4, Intense Pro24 BMX
Quoted: 365 Post(s)
Liked 87 Times in 58 Posts
On these pursuit positions, isn't there a UCI rule stipulating the forearms have to be horizontal, not tilted up or down?
Baby Puke is offline
Old 01-26-18, 06:41 PM
  #1610
Lapped 3x
taras0000's Avatar
Quoted: 325 Post(s)
Liked 23 Times in 20 Posts
I believe that the upward extension of the aero bars is allowed to be 100mm above the elbow rest. so about 4" (102mm).
taras0000 is offline
Old 01-26-18, 06:45 PM
  #1611
Morelock's Avatar
Quoted: 282 Post(s)
Liked 50 Times in 37 Posts
they changed it a few years ago (again) and you now have some leniency with tilt.
Basically... so long as you keep the pads to the tip of the extensions within the 10cm limit, go wild. And since most jigs measure a flat plane on the pads, you can "cheat" the system if the pads are angled as well because the top of the pad will be considerably higher than the "middle" of the pad.
Morelock is offline
Old 01-26-18, 09:06 PM
  #1612
Bikes: Felt TK FRD
Quoted: 59 Post(s)
The graph regarding UCI rules for TT extensions.
File Type: png
Godsight is offline
Old 01-26-18, 11:28 PM
  #1613
jsk
Bikes: Trek Madone, Blue Triad SL, Dixie Flyer BTB
Quoted: 160 Post(s)
Yeah I knew UCI relaxed the rules a bit a while back to allow more extension rise, but his sure looks like a lot more than 10cm. I guess it must be measured from the highest part of the pad, he's got those pads tilted quite a bit so he's probably gaining several cm compared to if you measured from the back or from level pads. Definitely not a typical/old-school pursuit position, looks a lot more like a TT roadie or (gasp) triathlete far as narrow elbows, high hands, etc.
jsk is offline
Old 01-27-18, 07:29 AM
  #1614
Morelock's Avatar
Quoted: 282 Post(s)
All the jig's I've seen just have a flat piece that is supposed to lay flat on your pad (to take the 10cm measurement)
If you're pad is angled at all, it can't lay flat on it and instead has to lay on the highest point. The real restriction (considering mantis style positions are good for you aerodynamically...in my experience they are usually good up to a point, then terrible, although with consistently lower yaw indoors it might be different) is keeping your extensions below your saddle. A lot of guys are cutting that VERY close...but I don't know if it's something that comm's actively measure or not. (yet)
Morelock is offline
Old 01-27-18, 09:29 AM
  #1615
jsk
Quoted: 160 Post(s)
I didn't know there was a rule about extensions having to be below saddle. Hard to tell from pics how much extension is under his hands, but it looks like they're at least even with the saddle.
jsk is offline
Old 01-27-18, 10:18 AM
  #1616
Morelock's Avatar
Quoted: 282 Post(s)
it's an obscure way of making sure you don't try to run the Egg position I believe.
It's annoying because this position tested pretty slippery for me.
File Type: png
Morelock is offline
Old 01-27-18, 06:07 PM
  #1617
Quoted: 144 Post(s)
Liked 14 Times in 11 Posts
Originally Posted by Morelock
........................ keeping your extensions below your saddle. ................
Which rule is that?
Thanks
By the way one of the most common rules that is ignored is 3.2.003 " In addition, while riding on the track, riders shall at all times be in firm control of the bicycle and have at least one hand on the handlebar (or extension)."
Both hands up in the air is quite common in World Cup events.
700wheel is offline
Old 01-27-18, 06:55 PM
  #1618
Morelock's Avatar
Quoted: 282 Post(s)
Originally Posted by 700wheel
Which rule is that?
Thanks
Article 1.3.022 in the clarification guide, this diagram shows the limits of handlebars. There is no later diagram related to TT/Pursuit specific positions related to the rest of the frame (like this one) so this one seems to be used.
File Type: jpg
Morelock is offline
Old 01-28-18, 12:14 AM
  #1619
Lapped 3x
taras0000's Avatar
Quoted: 325 Post(s)
Stumbled across this bike in a classified ad. Back half is a BT, the front half is done by Roberts Composites in Vancouver, BC. 62-63cm TT on this bike. [IMG][/IMG]
Old 01-28-18, 01:07 AM
  #1620
Elitist
carleton's Avatar
Quoted: 1386 Post(s)
Liked 92 Times in 77 Posts
How much?
carleton is offline
Old 01-28-18, 07:16 AM
  #1621
aka mattio
queerpunk's Avatar
Bikes: yes
Quoted: 344 Post(s)
Liked 58 Times in 35 Posts
isn't there an arm-angle rule, too? or did that expire? i can't keep track of the changes.
queerpunk is offline
Old 01-28-18, 08:51 AM
  #1622
Morelock's Avatar
Quoted: 282 Post(s)
^One of the good changes that's been made the last few years is that you no longer have to be measured on/with the bike. (From what I understand it was so mechanics for pro tour teams could bring the bike without the riders having to bother themselves with being there standing in line) You get 1 free exemption (-5/0 seat setback or 75/80 reach) regardless of how tall you are. (You can still apply for the bonus 5 to reach if you're really tall, bringing it to 85) So for the most part, things like arm angle are gone.
Morelock is offline
Old 01-28-18, 01:06 PM
  #1623
Poppit's Avatar
Quoted: 111 Post(s)
Carbonwasp bars
Close up of Dan’s bars. They had a bit of a mare this weekend though. BTW, the armrests are a onepiece.
Poppit is offline
Old 01-28-18, 02:03 PM
  #1624
Elitist
carleton's Avatar
Wow.
So, Praying Mantis is back for sure?
carleton is offline
Old 01-28-18, 02:06 PM
  #1625
Elitist
carleton's Avatar
Jenning Huizenga (NED) in 2008:
At the 2008 Olympics in Beijing:
carleton is offline
