Electronic Shifting - What's the Point?
#151
If I had a mechanical shifter with a disconnected cable I think I'd notice that the day before the ride. And even if I didn't, I could replace the cable in less than 10 minutes.
#152
Quoted: 6196 Post(s)
Liked 4,811 Times
He had to ride mtb instead until he had time to think what was happening. So yes, that was easy to diagnose.
#153
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
At the same time, I am strangely tempted to buy a solenoid and one of the microcontroller project kits and build one. Because I'm attracted to cool but pointless ideas I guess.
Likes For wphamilton:
#154
Liked 4,811 Times
Well you have another 30 years to be able to compare with mine. I used to be finicky too and in my early days took my bikes apart down to the bearings and beyond.
Still, no one is forcing you to use electronic shifting..... yet. I still feel that eventually it will be the norm. And it's just a different skill set that you will need to learn.
Likes For mrblue:
#157
Quoted: 3956 Post(s)
Liked 7,309 Times
#158
David
Likes For David in Maine:
#159
Earlier this year BC (Before COVID) I purchased a bike with SRAM Force eTap AXS.
So far I haven't been very impressed with electronic shifting or at least with SRAM's electronic shifting. I haven't tried EPS or Di2 so I can't really compare apples to apples. However I do have a couple of other bikes with Shimano Ultegra, 105, Campy Record 12 and Chorus 12--all mechanical. I don't think the SRAM eTap shifts any more consistently or reliably than any other groupset I have. As a matter of fact I sometimes think the mechanical groupsets might shift better. The one thing I do think is pretty cool, but not all necessary, is the wireless connectivity.
Am I missing something? What are others' thoughts on electronic shifting?
My bikes both have internally routed cables and they are a pain to deal with. I also have some problems with cable friction, even with Campy's latest maximum smoothness cables for 12 speed. Force is so easy to set up that it's ridiculous, although there are some people who spend hours setting up the FD, that I did just this morning in about 15 minutes. I got my first disc brake frame recently and I'm trading parts over from one bike to another.
I'm finding a lot more cross compatibility than expected with Force. I managed to run the new 10-36 cassette with the standard FD, not the wide model and also found that the Campy 12 cranks work fine with AXS. I'm also using Shimano GRX 46/30 11 speed cranks with AXS, but I do use some shim washers to eliminate the +2.5mm chainline.
#160
Liked 7,309 Times
I think this sums it up. I think this question, as well as disc brakes on road bikes, comes down to personality and philosophy. I find a simple bicycle that I understand how to work on appealing. I'm spending way more time with technology trying to be a teacher during a pandemic so I appreciate my analog bicycle even more. I don't even use a gps computer on my rides generally unless I'm exploring an unfamiliar route. I totally accept that others feel differently and I'm willing to acknowledge that electronic shifting is better performing--I just don't care.
Likes For tomato coupe:
#162
I've considered electronic shifting for my latest N+1 purchase, but decided not. I'm using my bicycles for long multi-day and sometimes multi-week trips, and another set of batteries that need charging is unwelcome. In addition, I *can* fix a broken drivetrain on the road when it's mechanical, but that's unlikely when it's electronic. Finally, I expect any electronic shifting system to be obsolete in about ten years. I know that when I maintain my mechanical campagnolo gruppo well it will last for at least forty years. But will I be able to re-program or read out my EPS, Di2 or Etap in forty years? Surely not.
#163
On Your Left
Quoted: 3004 Post(s)
Liked 2,434 Times
I've considered electronic shifting for my latest N+1 purchase, but decided not. I'm using my bicycles for long multi-day and sometimes multi-week trips, and another set of batteries that need charging is unwelcome. In addition, I *can* fix a broken drivetrain on the road when it's mechanical, but that's unlikely when it's electronic. Finally, I expect any electronic shifting system to be obsolete in about ten years. I know that when I maintain my mechanical campagnolo gruppo well it will last for at least forty years. But will I be able to re-program or read out my EPS, Di2 or Etap in fourty years? Surely not.
Electronic is not for everyone and every circumstance.
Do you plan on bringing a cell phone?
#164
And yes, I do bring a cell-phone, but keeping it charged over a week of bikepacking is not always trivial. Then I have to keep my GPS unit alive, and a GoPro if time and opportunity allows...
#165
On Your Left
Liked 2,434 Times
FYI... I get around 800 miles on a charge using Sram eTap. And that's when the RD LED goes from green to red. If I swap front to rear batteries,I bet I can get 1000 miles before both need a charge.
Likes For GlennR:
#166
Quoted: 645 Post(s)
Liked 797 Times
Not doing electronic at the moment because I don't need it - my 10sp Ergos were just overhauled and are crisp&delightful, and I have a few 10sp cassettes to get through. I used to be skeptical of electronic, but I acknowledge that electronic's the future, and I'm sure I'll love it when I ultimately make the change. Really, the only hurdles I can see are (i) the cost - I'm not ready to fork out for Super Record - let's see some trickle-down to Chorus, and (ii) having to retrofit my frame for electronic - I have a 20-year old Ti frame that I love and don't want to replace. There are firms that can apparently retrofit Ti for electronic (and disks, although I'm not wild about them trying to cold set 6/4 Ti for a wider rear hub), which would likely be cheaper than a whole new frame. The other option is to hold out and see if Campag come out with wireless electronic.
#167
Bikes: Turner 5-Spot Burner converted; IBIS Ripley, Specialized Crave, Tommasini Sintesi, Cinelli Superstar, Tommasini X-Fire Gravel
Quoted: 406 Post(s)
Liked 389 Times
Around me, there are a couple other people with campag equipped bikes (mostly older 10 speed stuff) but I have never seen a modern Colnago in the wild.
#168
Quoted: 3242 Post(s)
Liked 2,089 Times
I was diligent the first year or so to check that the system was functioning before leaving the house if doing a remote ride. It always was and is, for years, so you kind of take it for granted. I’d bet few folks actually run the shifters on a mechanical system before a ride to make sure no cables have broken. Funny that in order to get the BT back I had to basically re-boot the bike. Same kind of troubleshooting you do with a phone.
#169
Bikes: Giant TCR Advanced Pro 0 Disc
Quoted: 105 Post(s)
Liked 69 Times
I love my Di2. No broken shifter cables, no jumping gears, set it & forget it, auto-trim, dumping gears with one click, switching Garmin screens with buttons on the hood, sprint shifters (I ride on the drops a lot), and countless other stuff. Di2 looked like an unnecessary luxury until I owned a bike with it now it's a must-have.
Likes For rower2cyclist:
#170
Bikes: 2021 Trek Domane SLR 7, 2012 Giant Defy 0, 2012 Trek Domane 6.2 P1, Bianchi Infinito CV disc Di2
Quoted: 212 Post(s)
Liked 1,000 Times
I have four road bikes - all have the Ultegra Di2 groupset. Two are 10 speed, two are 11 speed. I will never by a bike without Di2. Anything you read about batteries dead is wrong. The shifting is crisp, precise, reliable and maintenance free. Worth every nickel. That’s over 30,000 miles of hard riding experience talking.
FWIW, 19 of 21 Tour de France teams ride Dura Ace Di2............
Ride hard and ride on......
Likes For wthensler:
#171
#172
Bikes: Trek 970, Bianchi Volpe,Casati
Quoted: 358 Post(s)
Liked 122 Times
Auto - shift
I'm waiting to buy a new bike. I will wait till it shifts by itself and I don't have to pedal.. 😎
#173
Quoted: 358 Post(s)
Liked 122 Times
The problem with electronics is that it's not a skillset that you can learn. Most electronics, including Di2, run on propietary software. You don't know how it works, Shimano doesn't want you to know, and unless you reverse engineer it, you won't know. So if a firmware update makes it fail or whatever happens, you're screwed regardless of what skills you have.
#174
On Your Left
Liked 2,434 Times
Seriously, I have Sram eTap, left shifts left, right shifts right and both changed the chainring.
Doesn't seem that hard.
#175
You knowing what button does what has nothing to do with having an idea of how the system works at the electronic/software level. You simply don't know that and won't be able to unless you are a SRAM or Shimano engineer.
It's true that, theoretically, you don't need to know it to use the system. Until your system fails and is out of warranty and SRAM considers it obsolete. Meanwhile, there are lots of 30 year old derailleurs that still work.
