The post your trailer thread.
#276
I can - therefore, I do..
Bikes: '84 Motocruiser, '10 KHS TR 101
She's done...
Finally got the basics done... a few tweaks and newer rims/tires will be in order very soon. All in all, she handles well, a little canting to deal with, but, nothing real urgent to stop my 100 lb. runs into town and back when needed. I use it as a straight flat bed and with the tub held on with the strap.
#277
Trailer Nut
Bikes: Viking Urban Trail. Schwinn Spoiler
New Trailer Build
A few months ago a garage across the road from me was getting done up and I was hauling all sorts of stuff out there skip. A couple of days ago I remembered I'd hauled out a matal frame, so I started work on a new trailer.
Yesterday I had my mate weld on 4 uprights and a 4 bracers around the top (it looks squint! but thats my mates welding lol. Once I got it home I started work on the wooden body.
How it looks so far...
I have now stripped it all down and sprayed it with cheap undercoat (grey) from the £1 shop. Im now in the process of spaying the frame black. Im going to spay the wood grey then coat it with a clear varnish.
I'll post more pics as it progresses
Regards
Tom
Regards
Tom
#278
Trailer Nut
A bit more done...
Finished painting frame black, and as im having the wheels cantilevered I made a couple of big dropouts out of thick angle iron.
I have sprayed my wooden panels grey and im waiting for the varnish to dry before bolting it all together and sealing it.
Regards
Tom
Regards
Tom
#279
Some pictures of my Mongoose Sabrosa hauling our kayaks back to the launch site on our first annual Neyland Drive row out and ride back.
#280
I have my doubts about your drop out - have you used that type before? My feeling is that under load you'll bend that piece of angle meaty as it is of deform the hole you've bolted through although I'd be happy to be wrong. I asked because I'm thinking of something similar for my next generation trailer. Instead of angle I was going to use square tube and run the bolt/axle through both walls of the tube so the cantilever is supported across a longer distance.
DAY
DAY
A bit more done...
Regards
Tom
Regards
Tom
#281
Trailer Nut
DAY
DAY
In answer to your question - Yes I have used angle iron before as dropouts, although a bit thinner than the one im using now. The thin angle I used last time for a quicky ladder trailer (to bring a load of loooong wood home) ended up buckling just as I turned the trailer into my street. - (a trip of about 2 mile)
LADDER TRAILER (Extendable).
The above trailer was only built to bring home the wood its carrying.
I have since built a stronger trailer for long and heavy loads. For this I used the thick angle iron. I had to use 2 pieces to hold on my wheels due to the nature of the fittings on the wheelchair wheels.
I'll try and get pics of the dropouts on this trailer.
I have stood on my trailer without the wheels splaying out or anything buckling, so im happy with it, though I suppose its all down to how much weight you wish to carry?
Might I add if you got the way of angle iron for your dropouts make sure when you drill out the hole for your wheel axle that its a tight fit.
Regards
Tom
#282
Trailer Nut
A pic of the double type dropout I had to make for the fitting of the wheelchair wheels on my big trailer.
Regards
Tom
Regards
Tom
#283
That looks more substantial - I see what your saying about the short axle. The wheels I'm using just come with bearings so I'm free to make any axle I like. If it held your weight the only thing left you have to worry about is shocks under load - keep us posted
DAY
DAY
#284
I have a BoB Ibex that gets regularly loaded with twice the rated capacity that's been modded slightly to add a kickstand to it so I don't need to do that origami fold thing they recommend to park it.
Also found this and thought it looked interesting, not that I'd want to ride one loaded...
#285
Bikes: fuji, specialized, sanwa
catering for james jonathans. Just an old kids trailer tied on with an inner tube. Needs a stronger bed (canvas is tearing) I was thinking about expanded steel grate maybe. Also need an actual hitch. The inner tube method works fine, it's just the opposite of quick release.
#286
Pants are for suckaz
Bikes: Hardtail MTB, Fixed gear, and Commuter bike
Here are a couple of pictures from the recent WABA office move...
loaded up with some heavier-than-they-look boxes.
ladies love a guy with a cargo trailer
trailer catching a bit of air.
#287
Bikes: rockhopper, delta V, cannondale H300, Marin Mill Valley
Liked 5 Times
Nice to see trailers working in DC. Thanks for posting the photos. I've met that redhead. She's cool.
#288
Trailer Nut
Done a little more to my shopping trailer. I reset the wheels a little further back on the frame as I had some fun and games taking a big tv to the recycle center on Sunday. I found a nice stainless steel door on my way home (I think it was from a hotel kitchen unit or someting?), to make a nice lid for the trailer, i had to adapt it a bit as it was a little to wide and a little to short.
I got my mate Peter to weld small piece of angle iron along the back to hold a padlock. Im going to paint it up and varnish it like the rest of the trailer. I'll get some pics posted up soon.
Next step is designing a light sytem for it - Lights, Indicators, Brake Lights etc. I have most if not all of the stuff I need its just figuring out the wiring and placing of everything.
Regards
Tom
Regards
Tom
#289
Bikes: bunch of junk
Quoted: 22 Post(s)
Here is the kiddie trailer V2. I changed out the flatbed for a more useful container and also added skyways. Since the container is suspended by bolts, it probably wouldn't support too much weight [enough for me] but it feels very secure.
#290
Trailer Nut
Just a little update to my trailer. With the snow still laying a bit heavy on the ground I haven't been able to do much painting, but I did source out an old bed frame that I used to make my new towbar. I have also managed to cobble together a sort of indicator for the rear of the trailer - this still needs a bit of work done on it.
Trailer with new towarm...
Towarm.
(I used a couple of old computer power leads, the wires are threaded along the inside of the towarm to the indicators)
Trailer indicators.
(still have to add a rear light and brake light. this is just a prototype until I scource out better materials)
The stainless steel door/lid I found.
The door/Lid
painted up and a piece of angle iron welded on to take a padlock.
As you can see the lid falls a little short but this will be made up with a piece of wood.
Still have to do a bit more wiring and varnish the lid. ......... Damn snow
I'll keep you all updated as to how things progress.
Regards
Tom
Towarm.
Trailer indicators.
The door/Lid
Regards
Tom
#291
Happy New Year to all!! The trailer looks good BossCat!! I just ordered my 16" SkyWay's and an axle and bearings from BAW, so I can swap out the temp set-up and my trailer will be in final mode once I get everything here and installed. Can't wait to get back to the feed store and load the new version with bags of dog food!! Pics will follow once I start the change over.
#292
Bikes: Raleigh Sports, Giant Cadex, Waterford X-11, Specialized Rockhopper Comp FS, Viscount Aerospace Pro, Scwinn Passage
Here's my conversion. It is based off of a Burley flatbed as I liked the design and it seemed like an easy transition from the original trailer which was a Burley D'Light.
I stripped off the fabric and the high side rails. For the platform I used steel framing studs and for the new side rails I used 1/2" conduit. Both of which are galvanized steel. Using steel did add a bit more weight. The original trailer weighed 15 pounds, and I estimate it weighs 35 pounds in its current state.
I just went for a test ride with about 120 pounds. The ride felt very rubber band like at slower speeds. Is this common?
I'll cross post this in the trailer thread.
#293
#294
Trailer Nut
Yeah, nice refit, but I think you should have raised the side railes above the wheels - easier for carrying certian types of loads. Plus a thin sheet of ply wood screwed/bolted onto the load bed would finish it of.
Regards
Tom
Regards
Tom
#295
My thoughts on this: Plywood could become water logged, it is heavy, and would take away tie-downs. If I need to haul smaller items I'll use a Rubbermaid box, or use panniers.
Higher side rails are a good idea for wider loads- I didn't really consider that when building it. My intentions for the shorter side rails were to protect the wheels from cargo slipping into them. They also fold in for slightly larger loads.
#296
Trailer Nut
A lovely pair of camping trailers
Just thought you guys might like to see a couple of really well made camping trailers I came across while browsing the web. The trailer tent(s) were built by a couple of German guys to use for camping/touring.
Trailer 1:
https://www.guelo46.de/00004.html
Trailer 2:
https://www.w44.de/
This site also shows the construction of the folding top trailer.
Aint they a couple of beauties
Regards
Tom
PS...... Use Bablefish webpage translator if you wish to brows the sites in english https://uk.babelfish.yahoo.com/
Trailer 1:
Trailer 2:
https://www.w44.de/
Regards
Tom
#297
Bikes: 2006 Falcon Explorer Hybrid, 2008 Landrover Visalia Crossover, 2010 Cargo Cycles Senton, 2010 Cargo Cycles Capability, and a 2001 AVD quad pedi-van, 1980 Peugeot Carbolite 10sp racer
Quoted: 21 Post(s)
Liked 24 Times
Those two camping trailers are stunning; I particularily like the looks of the second one.
#298
Hells, I'd do a bit more cosmetic work on them and make them look like Conestoga wagons.
#299
Quoted: 21 Post(s)
Liked 24 Times
#300
