Deformed Tire
I am guilty of that also, but I have been trying to get better at the follow-up. some people take a lot of time to reply to threads and I figure they should get at least a thank you and in this case there was a visual to show and for me to learn from. And you reminded me to reply to another thread about rims that I ended up buying.
Quoted: 6196 Post(s)
Liked 4,811 Times
I liked riding 27" tires on road bikes. I even miss them. However they went by the wayside before the turn of the Century and 700C's are the favored now for road bikes.
As a result you see all the new tire tech and high quality tires only marketed as 700C's or what ever the normal size is for other types of bikes sold today.
So you might think about that some. I got rid of my favorite ride 10 years ago because the choice of 27" road tires was so limited.
Bikes: More bikes than riders
Quoted: 1446 Post(s)
Liked 762 Times
https://www.continental-tires.com/bi...rand-prix-5000
Continental list the GP5000 has "3/330" for TPI. They're saying that there are three layers of fabric with a "total" TPI of 330. But that means that each layer is 110 TPI...and they've just layered three together. The math doesn't work that way. In other words, a tire with 5 layers of 20 TPI fabric is not "supple" like a tire with 2 layers of 50 TPI fabric, or some other combination of higher TPI count casing layers. Schwalbe's website states they list the EPI (Ends Per Inch, but same thing) for a single layer of fabric, even if multiple layers are used. So Schwalbe would list the GP5000 as "110" TPI.
Unless you know exactly how TPI is measured, the marketed or claimed number may not be useful (or even misleading). I would say the Kenda tire is probably in the 20 TPI range. You could probably measure it yourself -- take that tire that you removed, cut it open, and lay a ruler on the inside, perpendicular to the threads. How many are there in an inch? It looks pretty coarse -- as in, large threads with a relatively low TPI count.
Mad bike riding scientist
Quoted: 6220 Post(s)
Liked 4,221 Times
The S-bulge isn’t an indicator of a blow out. If you look at rogerphotog’s picture, you can see that there are still cords holding the tire together. There is more than one ply of fabric in the tire. For the tire to blow out at the bulge, it would need to break more plies and the rubber of the tread. That’s a lot to break through. The tire will wear faster because of the increased squirm but it won’t necessarily blow out.
Stuart Black
Stuart Black
Liked 4,221 Times
Stuart Black
Stuart Black
Bikes: '04 LeMond Buenos Aires, '82 Bianchi Nuova Racing, De Rosa SLX, Bridgestone MB-1, Guerciotti TSX, Torpado Aelle, LeMond Tourmalet 853, Bridgestone Radac
Quoted: 101 Post(s)
Liked 46 Times
Quoted: 18378 Post(s)
Liked 4,512 Times
Really Old Senior Member
Which is the primary reason I have no further interest in ever trying to assist the OP.
