What unlikely tools or products do you keep in your bike repair/restoration toolbox?
Quoted: 1372 Post(s)
Liked 1,752 Times
Home made cotter pin press...
Two x Four lumber for frame work...
Big bolt for fixed cup removal/installation...
Alloy polishing wheel home made...
Home made truing stand and dishing tool...
Aluminum foil for polishing races and cleaning off chrome plating...
Likes For randyjawa:
Quoted: 4560 Post(s)
Liked 2,802 Times
Cotton swabs with hollow plastic stems. Great for making liners that thread through metal cable guides on bottom brackets and seat clusters, to prevent metal on metal abrasion. Slicks up the feel of shifting and braking. I tried that when I couldn't find any cable liner locally. Works fine.
elcraft
I too, have a home made Cotterpin press. But as I am a goldsmith, I have a vast assortment of rotary tools, particularly burs. I really like Cut-off silicon carbide discs for trimming cut cable housing ends. I have at least five professional grade flexible shaft machines with expensive quick release handpieces, that speed up tool bit changes, too. While most people can get by with a Dremel style tool, I have so many more options on rotary tools than most people. I am also fan of larger tweezers for placing or retrieving ball bearings. I have assorted grinding wheels for thinning or modifying tools for specific jobs, e.g., thinning a cone wrench for adjusting Huret pulley cones. I have altered cone wrenches for Sturmey Archer projects, as well.
Quoted: 1303 Post(s)
Liked 1,912 Times
Taking a fixed cup off while on tour is way down on the list of things I need to carry the tools for. I’ve done close to 20,000 miles of loaded touring and never had to do any kind of maintenance on a bottom bracket. For the shop, I think you are talking about the Sheldon Brown method but I’ve never found that work all that well. This method works much better.
Nope. I reuse my grips and I’m not going to use an oil on them. I’d rather have my grips not be lubricated so that they just spin on the bars.
Likes For Mad Honk:
Quoted: 472 Post(s)
Liked 1,028 Times
On the other hand I have a bit of rubber refrigerator magnet. Way too weak to magnetize anything but strong enough to pull ball bearings out of a bearing cup and out of the OMS after a good bath.
Quoted: 1106 Post(s)
Liked 1,328 Times
2-Wheeled Fool
Bikes: Surly Ogre, Brompton
Quoted: 1385 Post(s)
Liked 677 Times
I had trouble with steel tweezers being slightly magnetic and not releasing the balls. In my pile of "interesting materials" is a bit of scrap bamboo flooring. I've made 2 or 3 bamboo tweezers. Work great and do not get magnetized.
I have several different sizes of ball bearing tweezers, and I DO have problems with them being magnetized. I have a small, non-electrically-powered demagnetizer and it does a marginal job of de-magging my tools. I really get pissy when I have to do a lot of ball-bearing jobs, and I rely heavily upon the tackiness of the grease to pull off the bearing balls and set the balls into place. I really must get a better demagnetizer!
Quoted: 2488 Post(s)
Liked 2,957 Times
Sounds reasonable, but if you happen to come across a flat bar that's being discarded, try the WD-40 method for removing and reinstalling grips as an experiment. You'll find that the grip comes off easily (obviously) and goes back on easily but then adheres to the bar. Seems counterintuitive, but the grip stays put.
Liked 1,328 Times
Liked 1,328 Times
Interesting solution.
tantum vehi
Quoted: 1167 Post(s)
Liked 992 Times
Quoted: 3811 Post(s)
Liked 6,716 Times
This DIY tool for spreading rear dropouts and forks was a staple of the first LBS where I worked back in the late 80s. When that shop was closing and the owner let me choose any tool I wanted, this was the one.
Likes For nlerner:
tantum vehi
Liked 992 Times
Too late:
Looks like a good way to keep fuzz out of your hair and eyes when using a polishing wheel on aluminum parts...
Likes For mountaindave:
Mad bike riding scientist
Quoted: 6220 Post(s)
Liked 4,221 Times
I buy aerosol carburetor and brake cleaner by the case. I use it to remove grips both on golf clubs and bikes. I dries clean and within less than a minute so the grips can be reused easily and quickly. It can also be used to lubricate during a grip install. Not something most keep in the tool box. Smiles, MH
Stuart Black
Stuart Black
Likes For oneclick:
Passista
Quoted: 868 Post(s)
Liked 721 Times
Interesting. Is 1 hand force enough, or only for bodybuilder-type mechanics??
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3890 Post(s)
Liked 6,488 Times
Likes For SurferRosa:
Passista
Quoted: 868 Post(s)
Liked 721 Times
Not bike related, but I heard hunters use condoms on their rifle muzzles to keep them clean in wet/muddy environments.
Liked 6,716 Times
Reverse tweezer for bearings
2-Wheeled Fool
Liked 677 Times
I've been a mechanic in one form or another my entire life, and I've never heard of this. Weed must be legal in your state...
tantum vehi
Liked 992 Times
1970 Gitane TdF; 1973 Gitane TdF
1979 Trek 710; 1981 Trek 412; 1981 Trek 710
1984 Specialized Stumpjumper Sport; 1985 Specialized Allez SE; 1988 Specialized Sirrus; 1989 Specialized Rock Combo
1984 Ross Mt. Hood
1988 Centurion Ironman Expert
1991 Bridgestone RB-1
1992 Serotta Colorado TG
2015 Elephant NFE
1984 Ross Mt. Hood
2015 Elephant NFE
