What's Up with Conti Tires Blowing Sidewalls?
Clark W. Griswold
Quoted: 4403 Post(s)
Liked 4,035 Times
I have some Conti tires that are 5 years old now and still fine (though getting near the end of life but just age and wear not blowing up. People seem to have problems with certain tires that I don't think are common you may hear about them because those with issues tend to be more vocal then the mass of us quieter folks who run them just fine with no issues or at least not issues as a result of the tire (I did get a piece of glass in one during a rainstorm but I could hardly blame that on Conti.
Looks like in the first picture, the tyre is mounted on a (super) wide rim. That Will expose the side wall more to road debris compared to a narrower rim tucking in the side wall behind the thread.
Quoted: 1529 Post(s)
Liked 718 Times
Yep, although the GP has been my favourite tyre since the 90s, part of the reason has the flipside of sidewall vulnerability. If you want a fast and grippy tyre, it's gotta be supple.
Likes For Kimmo:
Quoted: 2333 Post(s)
Liked 2,097 Times
Check for resin flashing at the rim bead.....or adjust your brake pads to address photo 2. Photo 1 is the price of riding over junk on supple, fast tires.
https://www.velonews.com/gear/techni...-the-pyrenees/
Likes For GhostRider62:
I have had no trouble on Continental 4000 Grand Prix Sii tires. However, was just reading tire reviews on Continental 5000 Grand Prix and Gator Skins, and there is recurring pattern of tires blowing sidewalls or beads, while still almost new. Not everybody, but not just one guy either.
The people say they have been riding for years without this happening.
What say you?
Faulty tires a certain percentage of the time?
Hit something they didn't know they hit?
Installed wrong?
There has to be a reason. Is there a best likely guess?
What say you?
Installed wrong?
I ride Kenda now, the one I have now is lighter than the GP4000 but it's lasted me a few years now and zero punctures. Kenda have full width protection, the entire sidewall. Love em, best part of Kenda, cheaper than Conti but a large margin.
climber has-been
Quoted: 3465 Post(s)
Liked 3,607 Times
Either that tire is made out of vibranium, or you don't ride much.
Likes For terrymorse:
How much is "much" or "not a lot"?
My current gravel/commuter tyres are on their second year. Not sure about mileage, but "a lot" :-) ( thick thread, tough compound)
climber has-been
Liked 3,607 Times
Originally Posted by zymphad;22143944I ride Kenda now, the [b
one I have now is lighter than the GP4000[/b] but it's lasted me a few years now and zero punctures. Kenda have full width protection, the entire sidewall. Love em, best part of Kenda, cheaper than Conti but a large margin.
The GP's ride as nice as they do is because of the supple sidewalls. If debris is a problem you can't see then they are not for you. I understand there are even better riding tires out there but I suspect they my be just as vul. What I don't understand is riding a nice bike on crappy tires.
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2600 Post(s)
Liked 5,680 Times
Had a sidewall blowout on my 5000 Tls with 500 miles on them. Saw glass sparkling on the shoulder ahead, and swung into the road to avoid it. About 60 seconds later - pssssssssssssst. Must have picked some of it up rather than just a random failure. The hole was so large I had to tube it.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Quoted: 1975 Post(s)
Liked 232 Times
Grupetto Bob
Liked 5,680 Times
I had a side wall tear in my Conti 4-seasons last month. Assumed it was a sharp rock. Didn’t get a flat….just noticed the tube bulging out the hole when I was cleaning the bike. In hindsight, maybe a blowout?
Sewed the hole/tear and put a HD radial tire patch on the inside. Tire works fine now.
Bikes: 2022 Moots RCS, 2014 BMC SLR01 DA Mech, 2020 Santa Cruz Stigmata, Ibis Ripmo, Trek Top Fuel, Specialized Levo SL, Norco Bigfoot VLT
Quoted: 464 Post(s)
Liked 182 Times
The one time I had a sidewall issue was with the Conti GP 4000 but I am pretty sure it was my fault. We know those sidewalls are paper thin. I was coming down a fast downhill and suddenly realize that the upcoming sharp turn was a decreasing radius and off-camber one...my scariest combo. So I lean the bike over even more and try to make it through without hitting the brakes. Well, I may have feathered it a bit since I feel the rear starting to slide (while really leaned over) and I thought I could still control it but then...BAM!! The tube blew through a hole in the sidewall about an inch long. Of course, I went down in a split second, it seemed. Then I rolled down the hillside but just for maybe 15 ft. I tried to blame it on the tire, but the tire was having none of it. I eventually patched it with a GU gel pack, got it to maybe 30 PSI which was all it would take without building through the hole again, sat on the toptube, and mostly coasted till the next town where I caught the bus all bloodied up. I saw slight abrasion/scrape marks around the hole so I knew it was user error. Watch those sidewalls...they are super thin and it was a good lesson for me. I still hate that turn and no more flying through it.
