Zipp's wheel claims: do you believe them?
#176
Bikes: Trek T200 plus enough others to fill a large shed
I think we can end this one quite easily. I was never much good at the theoretical bits of Engineering, but I did like practicals. Here is one for the Zipp engineers or those rich enough to buy 2.
Equipment:
2 Zipp wonderwheels
Metal fixing rod
Parking lot
Wind
Anemometer
Safety goggles
Method:
Fix 2 wonderwheels together connecting the LHS of one hub to the RHS of the other hub and place them in a parking lot such that the wind hits them at 15 degrees.
Measurement:
Do the wheels move into the wind or away from the wind?
At what wind speed to the wheels start moving?
Andrew Salmon
M.Eng Oxford 1999.
Equipment:
2 Zipp wonderwheels
Metal fixing rod
Parking lot
Wind
Anemometer
Safety goggles
Method:
Measurement:
Andrew Salmon
M.Eng Oxford 1999.
#178
Elite Fred
Bikes: 2009 Spooky (cracked frame), 2006 Curtlo, 2002 Lemond (current race bike) Zurich, 1987 Serotta Colorado, 1986 Cannondale for commuting, a 1984 Cannondale on loan to my son
Quoted: 60 Post(s)
Liked 43 Times
You are correct. Post number 1 claims a negative drag, but not a negative drag coefficient. I suppose you could have negative drag with a positive drag coefficient if your area or density is negative (but not both negative) or your speed is imaginary. Please forgive my mistake.
#180
#181
Overacting because I can
Bikes: Merlin Agilis, Trek 1500
Okay they're being sloppy with terms here - they really mean that at certain wind angles there is "lift" that creates the vector equivalent (as asgelle might say) of negative drag (i.e., thrust).
The question isn't word choice, it's whether the phenomenon exists.
“Courage is going from failure to failure without losing enthusiasm." (Churchill)
"I am a courageous cyclist." (SpongeDad)
#182
Elite Fred
Quoted: 60 Post(s)
Liked 43 Times
There are special cases where the projected area is infinite so a modification to this definition is required. An example is an infinitely long circular cylinder. In such cases a drag coefficients for a unit length of the body is employed. In the literature the first type of drag coefficient is a capital C with a capital D subscript. The second kind has a lower case d subscript.
In any event to get a negative drag force you must have negative drag coefficient because area and dynamic pressure are non-negative quantities. Again no "vector arithmetic" is required if you use the term "drag" how it is being used in fluid mechanics and aerodynamics.
#183
The dimples in that application , and for golf balls is used to generate lift, and this comes at the cost of increased drag. Except at Zipp, where the opposite happens.
It's fine if you want to believe Zipp, but then you should really pick up a Q-ray: the combination is unbeatable and may actually cause you to roll uphill.
Edit: It seems someone else drew almost the exact same diagram.
#184
So what did YOU do to it?
Bikes: 2006 Fetish Penna, 2014 Fuji Cross 2.0
How much does it weigh?
Bikes: Lotus Fixed, Bianchi Virata 2004
I used to hate this thread, mostly because I was being bashed around a bit.... but now I love this thread, it's the first time I've seen BF go into an actual discussion in questioning marketing hype.
+subscription
+subscription
#187
Just shy of 400W
Bikes: Cannondale System 6, Klein Palomino
I think what everyone here has missed is that there are 2 separate forces acting on the wheel.
#1 - The torque applied at the hub
#2 - The aero drag
(I am neglecting hub friction, and tire friction.. etc.)
The wheel CAN produce "negative drag", it is spinning from an outside force which is not responsible for the rotation. If the wheel is completely still, not rotating, then no... no way for it to produce "negative drag." The measurements are taken in two different directions... they are just choosing to ignore one.
Think of it this way... a helocopter rotor. Sure, each blade has drag associated with it, BUT since it has a torque applied to the center, and it rotates, it produces more lift than drag. Which, is what I assume they mean by negative drag. The copter has a "negative drag" in the upward direction, and similarly, the wheel has a "negative drag" in the forward direction... Im guessing... this is what they are talking about.
Zipp is only measuring the drag though... and not the force going in to keep the wheel in motion. The wheel isnt "adding force" it is merely reducing the effort you need to put into it to keep going forward. The total force to keep the wheel going forward will still be positive, otherwise Zipp has created a perpetual motion machine.
#2 - The aero drag
2008 Cannondale System Six
2016 Pivot Mach 5.5
2016 Pivot Mach 5.5
#188
No, but apparently the negative drag of the wheels will **** you when you take them out of the box.
and oh yeah, shipping is cheaper, these wheels propel themselves when moving through air or with the angle of wind that's *just right* - just give 'em a light spin to start off. Careful though, once you've given a little spin, they'll **** you.
#189
That is not at all what is going on. See post #88.
#190
Elite Fred
Quoted: 60 Post(s)
Liked 43 Times
So, it is theoretically possible that there is an force in the plane of the wheel that pushes it forward if the wheel is yawed with respect to the freestream? Sure. Is it due to negative drag? No way. That is my main complaint. If it is true it must be due to lift.
#191
Making a kilometer blurry
#192
Dirt-riding heretic
Bikes: Lynskey R230/Red, Blue Triad SL/Red, Cannondale Scalpel 3/X9
Quoted: 5 Post(s)
Liked 8 Times
This is getting fun to watch--I think someone just whittled their slide rule into a shiv.
"Unless he was racing there was no way he could match my speed."
#194
Trying to keep up
Bikes: Pinarello Prince, Orbea Onix, Ridley Fenix
Quoted: 79 Post(s)
Liked 136 Times
The direction of the drag force is understood to be aligned with the freestream velocity. Much like weight (a force) is in a known direction in everyday applications so one need not explain the direction of the weight of an object on the surface of the Earth. It is understood. Since the direction of the drag force is known the specification of a single scalar quantity will define the force vector. The communication problem that we are having is that you want to make the drag force go in a direction other than in the direction of the freestream velocity. You want to align the drag force with the wheel instead and that is not the correct direction for the drag because the wheel is yawed and not aligned with the freestream. You are talking about a component of force, but it isn't the drag.
But then again, I am just a social scientist. I'm not even sure what I just wrote, but I am happy to say that both Mollusk and asgelle are right. But not DocRay. Never DocRay.
#196
rex
Burning Matches.
Quoted: 4077 Post(s)
Liked 1,003 Times
I guess I must've missed that law in fluid flow. It certainly would make the data given by Zipp much less useful, though; I grant you that.
ElJamoquio didn't hate the world, per se; he was just constantly disappointed by humanity.
#198
Burning Matches.
Liked 1,003 Times
Get with the 21st century, Doc. I know technology hasn't progressed that far in medicine; but in engineering, these days, I use a 5-Axis CNC to machine my slide rule into a shiv.
I find the 1/8" single-flute ball mill to be quite adept at carving in some dimples. My shivs thrust themselves into other people's bodies. When it's windy out, my shivs thrust themselves into lesser engineers' bodies.
#199
Dirt-riding heretic
Quoted: 5 Post(s)
Liked 8 Times
Whittle my slide rule into a shiv?
#200
newbie rider
i thoughts sails produce thrust not create negative drag.....
im confused....too many pseudoscientists in this thread!!!
