velo-dilettante
Quoted: 1628 Post(s)
Liked 3,114 Times
was lowish on cycling sox. got four pairs of each. should hold me through this s****y year.
Likes For GreatDane84:
Quoted: 7350 Post(s)
Liked 2,475 Times
What materials are the socks you wear? (I'm addressing anyone, not only those who just bought socks.) I've learned never to wear cotton socks on any occasion. They absorb sweat and hold it, and as I'm prone to fungus, that helps the fungus collect and grow on my feet. I normally wear socks that are 85% wool ant 15% nylon. Sometimes I'll wear 100% synthetic socks. And I'm very careful to change my socks every day, sometimes twice a day.
Likes For noglider:
Bikes: SL8 Pro, TCR beater
Quoted: 989 Post(s)
Liked 586 Times
Picked up my 2021 TCR Pro 0 Disc on Monday. Only upgrades/modifications are the following:
-11x32 R8000 cassette (replacing the OEM 11x30). 95% of my rides are in mountains (over 3000ft of total elevation per 40-50kms) so I am expecting some improvements during my climbs.
-Dura-Ace rotors (not installed yet - currently in the mail).
To my big surprise, the bike didn't come with RideSense (speed&cadence sensor) even if it's the top-of-the-line non-SL TCR. LBS was not able to explain why since it came factory on the 2018-2019-2020 but I suspect that it's because cadence is available through the OEM Power Meter & speed is available through most of the bike computers and that Giant wanted to save on production costs.
Likes For eduskator:
Quoted: 20810 Post(s)
Liked 9,456 Times
Sunshine
Quoted: 10965 Post(s)
Liked 7,492 Times
I have a lot of defeet and sock guy brand socks and my favorite are the sock guy socks that are a blend of 75% Acrylic, 15% Nylon, 10% Spandex.
They stretch easily(big feet), are double stitched in the heel and toe, have held up thru years of washing, and they don't shrink in the dryer.
Lots of different colors and designs too from plain to wild.
Example-
Example-
Pair of Wellgo dual platform (SPD/regular shoes) Quick Release pedals. They pop on and off perfectly and work brilliantly. Gonna switch all my bikes to these now. Dirt cheap from Aliexpress too, but they keep running out of the combo of that pedal and the QRD2 mechanism vs the earlier clunkier V1.
Bikes: 2006 Litespeed Firenze
I've been on a month long escapade of trying to find a proper fitting bike shoe. I'm a D+ / E in width, local shops are low or out of stock on any shoes so I've been ordering and returning numerous pairs from online stores looking for one that fits correctly and doesn't numb my feet. Thanks manufacturers for having multiple nonstandard sizing charts, last dimensions, and numbers charts; nothing like a trigonometry equation to figure out if my shoes will fit. I've purchased Bont Vaypor S, Bontrager Velocis, Bontrager Velocis Wide, Specialized S-Works 7, Lake CX238, and Lake CX241 recently.
Quoted: 800 Post(s)
Liked 512 Times
Chianstay protector
Sunshine
Liked 7,492 Times
microshift advent 1x9 mtb. 11-42 cassette that'll be mated to a 30t ring.
good price off ebay thru 365cycles.
Its going on a '95 Trek 950 frame and will replace my wife's current mtb.
Bikes: 2021 Litespeed T5 105, 1990 Gios Compact Pro 105
Quoted: 167 Post(s)
Liked 325 Times
Advocatus Diaboli
Quoted: 4737 Post(s)
Liked 1,533 Times
Campag crank bearing puller kit
Likes For Sy Reene:
Quoted: 152 Post(s)
Liked 173 Times
I've needed something like this forever and finally decided to get one.
Likes For August West:
Quoted: 83 Post(s)
Liked 157 Times
Garmin 530. My 3 year old Garmin 520 reports incorrect climb numbers and sometimes resets itself during the ride. I tried to do the factory reset and now it is stuck on the Garmin Logo whenever I try to power it up. I hope 530 will be more reliable.
Bikes: Mezzo D9, Nigel Dean Tour Master
Quoted: 55 Post(s)
Liked 62 Times
Got my gear ratio down to 20!!
I wanted to reduce my gear ratio from 24 to 20 to help my hill climbs.
So time to buy a replacement freewheel with a nice low 34 tooth ring. Fitted it and got a problem with the derailleur clashing with the large gear.
I thought I would need to replace the rear changer but I found this great small hanger extender! Problem solved!
Nice low gear ring for GBP 17
The little piece of metal that made a huge difference! for GBP 6
Before without the hanger extender
All fitted and running smoothly!
total Newbie
used my Strava Le Col coupon and picked up a cycling cap, some winter gloves, and a sport jersey. the jersey is slightly too tight for me but i'm also at my highest weight ever (up 20lbs from the summer, due to lifestyle change) so i'll fit into that jersey easily for the spring season. it's my goal.
I just picked up a set of Zipp 303 Firecrest wheels with Chris King hubs for my R3. Still need to get new tires and brake pads before they go on the bike, but I found the wheels (used) at my local shop and I think I got a solid deal on them.
Another 100% S2 in TACT BLACK
Blast from the Past
My fall project is a Felt FR1. Have most of the DA stuff on hand. I've ridden the Ergonova bar for years, but it is no longer made. So I just picked up a new 3T Superergo bar and an Apto stem.
Trying to keep up
Bikes: Pinarello Prince, Orbea Onix, Ridley Fenix
Quoted: 79 Post(s)
Liked 136 Times
Favero Assioma power meter pedals. Do I actually need them? No. Am I fast enough for them to matter? Obviously no? But do I like playing with data? Yes!
