How do I manage hand tension after ride as professional musician?
Version 7.0
Bikes: Too Many
Quoted: 1341 Post(s)
Liked 2,482 Times
Recently, I restarted playing piano after decades of hiatus.
Cycling and strength training trash my hands, arms, neck and shoulders and a hard cycling workout also trashes my posture for sitting at the piano. I find it all bad. My approach is timing the practice sessions and use marginal gains on the bike and in the gym to try to reduce stress on my hands.
I really like the SRAM Etap electronic shifting since it spreads shifting the rear derailleur between the two hands versus just using ones right hand. I ride with as light of a touch on the handlebars as possible.
Aerobars might seem like a way to go but they round the shoulders and generate more neck and shoulder fatigue - at least for me.
In the gym, I use more machines and less freeweights so that I do not have to rack weights and load heavy weights on leg press machine - marginal improvement.
Also, I use mtb cleats, as the shoes are walkable. However, I'm wondering, do actual road biking shoes/cleats/pedals (Speedplay Zero pedals, for example) help one accomplish this better?
Strengthen your core so that you don't put much pressure on your hands. I ride in the lower portion of my bars (drops) probably over 90% of the time and have no issues. My friends laugh at how weak my hands are, too! Here is a pic of my Torelli just so you get an idea the position I ride.
What kind of music played?
What kind of core strengthening do you do?
I'm a classical musician.
How tightly are you grasping your handlebars?
Another possible cause/need for the extreme grip (if that's the root cause of your pain) is if the bike isn't tracking accurately. Are you able to ride with no hands, and the bike continues to go straight? Or do you have to maintain a grip on the bars because the bike veers? If it veers, make the proper adjustments so that it doesn't do that.
Dan
Dan
Not very tightly.
for inaccurately tracking, what are the proper adjustments to fix that?
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4393 Post(s)
Liked 3,016 Times
Worth checking, but maybe not the most likely cause of your problem.
Quoted: 97 Post(s)
Liked 106 Times
Classical- great! I am a huge fan of Debussy, Ravel and Rachmaninoff's piano works. I had the fortune to hear Alicia de Larrocha play in Houston and always wanted to hear Aldo Ciccolini and Rudolf Serkin. Guitar is cool and I heard Andre Segovia play, too!
Sr Member on Sr bikes
Dan
Palmer
Quoted: 1671 Post(s)
Liked 1,825 Times
Professional pianist: 'It hurts when I do this.'
Doctor: 'Don't do that.'
Seriously, how about cycling in a similar position with similar hand pressures as piano playing?
Zircon Encrusted Tweezers
Quoted: 261 Post(s)
Liked 132 Times
Yeah, not only is it easy on your hands and wrists, but you are much less likely to have an upper body injury should you go down.
