Recommendation for a decent bike for under $1000
I am retired and not on an especially tight budget. I can afford to buy more expensive bikes, but choose to be more frugal. I think we tend to lose sight of the fact that good enough is good enough.
All that said, the Fuji is a pretty nice bike as is the 1.1 from REI. Both are reasonably priced and good bikes. BTW my two companions and I did the TA and a bunch of other tours on our Windsor Tourings and found them quite adequate. We paid $599 delivered, but I think they are $699 delivered now.
Finally, Get a bike you like and can afford, and go somewhere ..Touring is the trip , not the hardware.
Bikes: 1982 Univega Gran Turismo
Quoted: 128 Post(s)
Quoted: 507 Post(s)
Liked 237 Times
Quoted: 1182 Post(s)
Liked 833 Times
@apc65 If you're still interested, REI started clearancing their bikes at 15% off. You might get a better discount on a floor model if you can find one in store.
Quoted: 671 Post(s)
Liked 49 Times
I'd think about used touring bike. Tourists usually maintain their bikes well & since there's a limited # of touring models it's easy to research quickly. I sold a 5-yr old Novara Randonée to a newbie tourer for 1/4 of original price, similar specs as Fuji Touring. Then if you catch the bug you can move up w/o worrying about having already spent a lot.
Quoted: 9 Post(s)
find a 1980's japanese built bike, you will be LIGHT YEARS ahead of all of this. Or if you can find a deal on an early Trek 5, 6 or 7 hundred series bike.. look for Miyata 610/100, Schwinn Voyageur touring bike (not walmart hybrid), univega grand tourism, etc. etc. Call me crazy but these bikes can be had in the $300 +/- range and are far superior to the modern chinese bikes.
Sunshine
Quoted: 10970 Post(s)
Liked 7,496 Times
I couldnt disagree more with the assertion that someone will come out light years ahead if they get a 25-40yo touring bike, or that touring biles from that period are far superior.
Ill try to stick to facts.
- current tubing and frame builds are stiffer than back then. This is good since many touring bikes back then were viewed as too noodly.
- those bikes are 126mm DO spacing. This limits gearing to 7speed at most. Many bikes from that period need to be updated and you are then choosing either old stuff off ebay, or lower end heavier new components.
Yes, the frame can be coldset to 130. This means buying a modern wheelset, drivetrain, cables and housing, etc. Costs go up and the 'lightyears ahead' comment diminishes.
- current touring bikes can typically handle wider tires than older models. Many want to embrace the current trend of wider tires.
- canti brake posts on bikes from the 80s are often incompatible with current cantilever and vbrakes due to spacing differences. This limits you to using 30+yo canti brakes.
- many modern touring bikes have more attachment points which allows for personalization . The salsa/surly forks being one example.
- 27" tires. Yes there are 6 quality 27" tires to still choose from. But thats limiting for sure. Changing to 700c will open up choices but also add to the cost of the bike. Oh, and it may render the canti brakes useless.
- it appears disc brakes are valued by many potential touring bike buyers.
A miyata 1000, voyageur sp, etc etc are awesome bikes for touring...for those who are aware of the limitations and are both wanting to and able to work with/around the limitations.
I build my current touring bike up with the exact components i wanted and for less than a stock new Fuji Touring, but i think that is more the exception thst the rule.
Bikes: 2016 Novara Mazama
Quoted: 3640 Post(s)
Liked 81 Times
I'd love to find a Miyata 1000 some day. It would make a very nice touring bike. It wouldn't be light years ahead of an off the shelf modern option, though. Nice bike? Yes. Perfectly suitable for touring? Yes. Far superior? No.
Also interested in Fuji touring but had the same problem where everyone was sold out & now that the price has jumped to $900, is it worth it to pay $100 more for the REI adv 1.1?
Liked 81 Times
If you've got a Performance Bike near you, may be worth your while to go in and have them check the system for your size at another store. I know there was still at least one at a PB near me last week, they are generally willing to ship them between stores.
None close by in your opinion is the Fuji still worth saving $100 over the REI COOP bike?
Sunshine
Liked 7,496 Times
As for which is worth buying- basically, its $100 more and you get known quality rims and 1 more cog on the cassette. Besides that, the componets are either identical or basically interchangeable in quality.
With that said- the geometry of each bike is pretty different. The REI bike has a higher stack height regardless of frame size. And it looks like the reach is a bit shorter on the REI bike. Longer chainstays on the REI too.
Which fits best is what I would want to base my decision on. No point in saving $100 or paying $100 more if the bike doesnt fit.
Liked 81 Times
If you were originally looking at the Fuji for some cost savings, I'd be more inclined to look to the Nashbar touring model. $800 regular price, but if you wait for a 25-30% off sale (25% quite frequent, 30% generally once a month or so) you can knock a couple hundred off the top.
Otherwise, have you tried either one out? If you do have an REI by you, go check out the 1.1, they should have them in stock. If you like it, take it home and don't worry about what the Fuji would have been.
Panthadad2
Bikes: 2018 Detroit Bikes A-Type 8sp, 2016 Trek 520, 2009 Trek Lime, 2006 Raleigh Route 66 drop bar convert, 1993 Trek 750 drop bar convert, 1983 Schwinn Varsity (Chicago built)
Quoted: 12 Post(s)
Consider the Nashbar Touring Bike (the one listed at $799.99, not the Nashbar TR1 Touring Bike). This bike is a re-badged Fuji Touring bike according to their customer service and specs. You can routinely get it at 20% off, and occasionally 30%, so $560-$640 plus shipping. The components are damn near the same as my 2016 Trek 520, so this is a good deal.
BTW, I'm about your weight and losing as well racking up the miles. Your weight is not a problem on these bikes, especially if you stick to 36 spokes (and occasionally adjust the spokes). I've put thousands of miles on my drop-bar converted 1993 Trek 750 while commuting with smaller loads, and it only has 32 spokes. Good luck and enjoy your riding!
Liked 81 Times
Bikes: 92 Bridgestone xo-2 Turner Sultan
Quoted: 47 Post(s)
I'm being tempted by the Nashbar touring bike which sounds like essentially the same bike as the Fuji Touring and Windsor Tourist. I think this is the last day for the 26% off sale, so I need to make a decision. Any words of wisdom ? It definitely was not my first choice, but it's hard to get past getting a new bike for under $600 delivered. The REI co-op bikes are around $1,000,even on sale.
Aidoneus
68
12-03-15 06:15 PM
Mojo182
35
10-14-12 08:30 AM
jordanrodgers
Touring
33
02-28-10 08:22 AM
