Very disappointed with Campy Centaur
Bikes: 84 Trek 660 Suntour Superbe; 87 Giant Rincon Shimano XT; 07 Mercian Vincitore Campy Veloce
Originally Posted by tinrobot
Shoulda bought Suntour
(someone had to say it)
CAT6 UTP 568B
Bikes: 2005 Allez Elite
Originally Posted by froze
Well you know that old cheap stuff, I only got 145,000 miles on my Suntour Superbe bottom bracket, that Suntour crap just doesn't last long!!
impressive!
Originally Posted by thewalrus
I just did the math on that, you have an average of 6904 miles per year for 21 years on one bike?!?!?!
impressive!
impressive!
Originally Posted by Figaro
That's putting it kindly. I like the smooth shifting and great looks of the Centaur gruppo. However, after only about 7,000 miles, the bottom bracket is sounding its death rattle. I'll change it when the noise becomes unbearable. Back in early October, I had to overhaul the right ergolever and change the "g-springs" (a mere $9 each). This stuff is too delicate for what it costs.
Tim
Fortunatissimo
7000 miles on one square taper bottom bracket? That's more than double the average lifespan of a Shimano square taper BB... ask any LBS mechanic.
Fortunatissimo
Originally Posted by squeegy200
Go buy a replacement and consider yourself fortunate to be able to ride that much.
Fortunatissimo
Originally Posted by galen_52657
7000 miles on that BB aint to shabby.
Fortunatissimo
Originally Posted by cyclintom
Either the poster had really bad luck or he's pretty hard on equipment.
7,000 miles is a lot? Did I read that correctly? That means every other time I buy a set of tires I should expect to replace the bottom bracket? Does any of that make sense to any of you? Is this the state of quality I can expect from new stuff? So let's see; buy a new bike for $2500, every time you replace your tires you have to replace your chain and gear cluster, every other time you replace your tires you have to replace your chain, gear cluster and bottom bracket!
Either people out there don't know how to care for their stuff or component manufactures are making trash. If it's the latter then I'll be dam if I ever buy a newer bike! But personally, I think it's the former-people don't know how to care for their stuff.
x
Bikes: inbred, GT, dean
so, some little springs that cost $9-15 to replace and what is admittedly not a very good bottom bracket crapped out at 7000 miles? do youself a favor, spend $50 and get a decent bottom bracket:
https://www.greenfishsports.com/index...ROD&ProdID=414
replace the springs and keep riding. So, every 7000 miles you spend $60 on your components? not too bad.
Also, as for shimano bottom brackets, just replaced the bb on my mtn bike, un72 had approximately 10000 miles on it after 7 years on my mtn bike, still spun fairly smoothly....Mike Curiak, if you dont know who that is, google great divide race 2004, see what type of bb he used for that race (hardest mtn bike race in the world)
Bikes: Too Many
I use cup and cone barckets with loose balls - open them clean them and re-pack them.
They turn smoother, they have less resistance and they last forever.
Bikes: Homebuilt steel
Quoted: 2193 Post(s)
Liked 425 Times
Originally Posted by toomanybikes
Bingo - I have NEVER worn out a bottom bracket.
Bikes: Too Many
Well, I have been doing it for thirty years. Never had one pit or rust. And I have never had the cranks wear out, go loose or otherwise be damaged.
I guess the assumption is that I must not know what I'm doing.
Service regularly, use good quality grease and noproblems have ever surfaced.
Of course, now that Ihave been doubly warned I can expect the cranks and axles to fail immediately?
works for truffles
I used to be a clean and service guy as well, but now I embrace the concept of the sealed throw-away. Makes life more simple and leaves time for other stuff, since service interval is usually shorter than replacement interval.
Guest
Posts: n/a
Quoted: Post(s)
7000 miles is about twice what I get from BBs, and better than what you would get from a shimano hollow axle BB-they have tiny bearings. You can get parts that last longer, but then you'd be *****ing about how heavy they were. If you want to last longer, replace with a external bearing BB.
I can tell you and I don't know what we're doing. I mean mine have never rusted or pitted either after 145,000 miles, I must be doing something wrong.
And then the comment about the cranks being heavy if they used larger ball bearings instead of the small ones Shimano (actually Shamano) uses? "You can get parts that last longer, but then you'd be *****ing about how heavy they were." Really? How much more heavy could we be talking about? maybe 25grms more for better bearings that will last far longer. Is 25grms that obscene? Dam, I don't know if I can bear moving another 25grms of weight.
Maglia Ciclamino
We can all complain about one part or another. Your beef is with the bottom bracket life, specifically that found in an AC-H bottom bracket like the one in the left of the picture.
So? Campagnolo addresses the problem and updates the Centaur BB to that in the right of the picture (black). Similar to Chorus BBs of late, while the Chorus BB is closer to Record models. Such is the nature of production.
Provided you get the right spindle length, you can usually upgrade to a better model. It isn't uncommon for 105 users to roll with an Ultegra BB. Doesn't mean the rest of the 105 group isn't a solid performer.
Cathedral City, CA
Bikes: 2016 RITCHEY BreakAway (full Chorus 11), 2005 Ritchey BreakAway (full Chorus 11, STOLEN), 2001 Gary Fisher Tassajara mountain bike (sold), 2004 Giant TRC 2 road bike (sold)
Quoted: 8 Post(s)
What is that in Dog Years?
Faith-Vigilance-Service
Bikes: Trinity, Paradisus, Centurion, Mongoose, Trek
Even if my BB only lasted 7000mi, you can buy Veloce and Centaur BB's from ProBikeKit for $15-$18 a piece. It honestly wouldn't bother me to change out a BB once every year or two of it was only $15. I spend that much at Starbucks every week just on Mochas.
President, OCP
--"Will you have some tea... at the theatre with me?"--
President, OCP
In light of all the comments about how short lived bottom brackets are these days, I third the Phil Wood bottom brackets. I knew a person that toured on Phil Woods bottom brackets and hubs and he had more miles on that stuff then I do on my Suntour!!! I would rather pay a bit more now and keep it for a long time then to keep paying for replacing the cheap crap over and over and over because eventually your going to pay for what it cost to get a Phil Woods anyways. So to say you spend the amount of what it cost for a bottom bracket a week on coffee is an ignorant comment. Wait till your "cheap" bottom bracket breaks while riding 50 miles from home!
Красный Октябрь
Bikes: Kona Major Jake - CX/Gravel Kona Jake The Snake - Commuter, Pinarello Galileo - RoadieAF, Niner Air 9 - HT MTB.
geee freakin whiz.
Want a cookie?
of course, since youre such a "serious" rider, you prolly cant eat one...
Want a cookie?
All posts are crafted by an adult, for adults. Not responsible for hurt feelings. Get in touch with your true self.
JOCP Senior Advisor
Bikes: 1979 Shcwinn Varsity, 2005 Speciazlied Transition Multi-Sport, 2005 Specailized Sirrus
Originally Posted by mellowdave
geee freakin whiz.
Want a cookie?
Want a cookie?
Angery much?
Stop it.
Bikes: 2003 Specialized Hardrock Pro w/ slicks, flipped stem and HB, 2003 Colnago Dream with full Dura-Ace 7700 double, 2001 Bianchi XL Boron/Daytona, Mavic Open Pro/Campy Centaur/DT Champion built wheels.
Originally Posted by Elvish Legion
Angery much?
Eh?
