When internal cable routing sucks
#51
From comment #39, it sounds like it depends somewhat on what shifters people use. In my case, it's the Dura Ace 7800 shifters, and I've had two break with those shifters. It seems plausible that shifter design accounts for some of the different experiences people are having. Shimano likely made Dura Ace shifters smaller to reduce weight, causing the bend radius to be smaller than other shifters. My new bike (with the internal routing) has GRX 810 shifters, which feel considerably larger in hand than the DA 7800 ones, so I'm hoping the bend radius will be larger on those.
#52
Bikes: Shmikes
Quoted: 10212 Post(s)
Liked 5,919 Times
#53
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 275 Post(s)
Liked 460 Times
Internal routing can be heavy if cable housing is included. 2021 Domane SL6
May be I need Di2 to drop weight.
#54
Newbie racer
Bikes: Propel, red is faster
Quoted: 1575 Post(s)
Liked 1,569 Times
My 2015 Propel is mech and is junk to replace the FD/RD cables. I had such issues with it I custom made a bottom bracket clamp deal for the cable housing and now run the added weight of cable housing internally instead of bare cable.
If I have to do it again, I swear I'm going Di2. Run it that LAST time.
#55
Bikes: Shmikes
Liked 5,919 Times
If you have to run conduit and are worried about weight, use this stuff instead of actual housing. It's also great for reducing friction, e.g., at under-BB guides.
Likes For MoAlpha:
