1973 Paramount brake quandry
I recently acquired a decent 1973 Schwinn Paramount; not a perfect bike but the flaws it has I can live with. It is currently equipped with Modolo Speedy brakes, but I did come with the original Weinmann calipers/dia Compe levers. Would you source a set of pre CSPC Campagnolo calipers, or just mount the original centerpulls?
My bikes: '81 Trek 957, '83 Trek 720, '85 Trek 500, '85 Trek 770,'81 Merckx, '85 Centurion Cinelli, '85 Raleigh Portage, '92 RB-2, '09 Bianchi
Quoted: 1088 Post(s)
Liked 1,206 Times
EDIT: Pics, please!
Master Parts Rearranger
Quoted: 1556 Post(s)
Liked 2,026 Times
Are you concerned about the brakes matching the componentry? Is the rest of the bike Campagnolo? It sounds like you have a P13 with the road/race geometry (or P10 if it has that geo, but with fender eyelets). Do you simply wish to never use the Speedy's for functional or aesthetic reasons? Do you like the way the centerpulls look and work, or do you wish for something more stylish or powerful or race-oriented? If the rest of it is Campagnolo, then running Campagnolo calipers would my personal decision as it ups the 'purity' factor for this matchy-matchy-oriented rider.
Got any pictures of it???
Quoted: 4520 Post(s)
Liked 6,406 Times
And of course the Campy's should come onboard at some point but also agree with getting it on the road first.
Modolo's not work? While the centerpulls could have been original, I am not a fan of these for this just because, regardless of often poor performance they require the cabling and hangers that seriously gack the vibe IMO.
And yet mine still has the centerpulls but it came with them ready to go, I did add the Schwinn approved Suntour bar ends though.
Likes For merziac:
Both Campy Record brakes and Weinmann brakes are good choices and correct for this bike. I'd lean towards the Weinmann centerpulls. They are a better choice for a general recreational riding, even touring. So yeah, new pads and cables etc, but I vote Weinmann.
I could for sure support going either way though. The medium reach campy brakes you'll need for a Paramount are going to be a little less common than short reach. They are out there though. (make sure you get the right ones, and measure the brake bridge to rim distance first, before you buy anything.)
Modolo brakes are cool in their own way, just not right for this bike, IMO.
Likes For Salamandrine:
Veteran, Pacifist
Quoted: 3907 Post(s)
Liked 4,853 Times
i've always been in the 'get it on the road first' then worry about mods as riding time allows.
sometimes the technique quells N+1, for a period of time. for good or bad.
Quoted: 5890 Post(s)
Liked 3,475 Times
Centerpulls will look right on this bike.
Likes For bikemig:
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,398 Times
Is this a new-geometry P13, which was designed to accommodate Campagnolo sidepulls, and uses clamp-on cable clips?
Or is it an earlier P13 or P15/P10 with slightly longer brake reach and built-on cable stops which aren't always where you want 'em?
It helps to know what one's playing with.
-Kurt
-Kurt
Likes For cudak888:
Liked 6,406 Times
Yep, you might be stuck with the centerpulls although with the Modolo's on there it should work with Campy's too.
-Kurt
-Kurt
Likes For nesteel:
Liked 4,398 Times
Bike in question:
Original brakes:
Original brakes:
Likes For nesteel:
That's good info to know, thank you.
The Modolo setup just doesn't look right. Those will likely find their way onto the '83 Serotta that showed up last week should I decide to keep/build it.
Their are early Wienmann Carerra calipers in the parts bin, and Suntour Superbe 4700's.
The more I consider it, the less I like the center pull aesthetics. Perhaps after it's cleaned up I'll toss a set of spare Campagnolo calipers on it and check the looks.
Liked 6,406 Times
I have always been dismayed at Schwinn's use of them but I guess they had to do it for sheer volume since they used them on everything.
I think that people have a prejudice against Weinmann center pull brakes because they were so common. I know I did. That changed when I saw my first real in the flesh René Herse touring bike, perhaps 30 years ago. Guess what brakes it had? Weinmanns. He could have picked anything. This was clearly a no expenses spared custom bicycle. Made me re-evaluate. I had them on my Super Mirage when I was a kid, and I remember that they always worked well for me. They stop well. They are solidly made. The 'cheap' perception seems to originate mostly because they came on so many less expensive bike boom bikes, not from any inherent quality of the brakes themselves.
Liked 6,406 Times
I don't totally dislike the Weinmann's, they are iconic but think they dilute the Paramount"s classiness.
Options were limited back in the day and Schwinn was buying them by the truckload so a no brainer I guess.
Just think it ironic that a Varsity had Paramount brakes or that a Paramount had Varsity brakes.
They were always excellent quality and very well made but when paired with "Safety", turkey levers, yep even often on Paramounts and anything other than perfect setup and adjustment with good pads, they performed well below what they should.
feros ferio
Quoted: 1393 Post(s)
Liked 1,334 Times
There is nothing wrong with Weinmann centerpulls that cannot be fixed with KoolStop pads and modern cables and housings. Last year I replaced the rear brake cable and housing on my UO-8 (Peugeot-branded Weinmann 999) -- what a difference!
Likes For John E:
Liked 4,398 Times
My only objection to Weinmann centerpulls is that the shoe mounts are so far apart that they need wide rims or thick pads for the brake shoe to hit the rim squarely. Otherwise, the pads angle upwards into the braking surface, with only the lower edge making contact. I see this very frequently in pictures here on the forum, and I'm always curious what the owners aren't saying about the performance of their brakes. Also, sometimes I see Kool-Stops haphazardly thrown on, which does compensate for this, but it doesn't excuse bad setup/adjustment.
Even then, I've seen Weinmanns factory spec'ed with rims not wide enough to begin with. Some of the original Weinmann pads were, admittedly, thicker/deeper than many new replacements available today, but I've seen some dodgy factory combinations.
Whatever the case, proper setup and a thick enough pair of pads (threaded canti pads with conical washers don't look good, but often solve the problem) can result in very powerful performance out of these centerpulls - even if spongy.
I never cared too much for them myself (I only have them on my '61 Paramount for originality's sake), but I wouldn't say no to throwing a set on a flipper.
-Kurt
-Kurt
-Kurt
-Kurt
I never felt the C/P calipers lacked any stopping ability, in fact I generally preferred them. They were easier to adjust, they rarely dragged one side or the other, and they gave great clearance for fenders and different size tires. The only downfall I saw with them was weight, the calipers themselves were no doubt heavier than a good side pull and the associated hangers added even more weight. For my purposes though, stopping ability and reliability took precedence over weight. I always absolutely hated dealing with side pull calipers that refused to stay centered. The position of the cable casing has no effect on a C/P caliper like it can on a side pull.
Liked 4,398 Times
For those reading who don't understand what I'm blabbing about, here's an example. Please ignore the April Fools-worthy Campagnolo-badged Dia-Compe centerpull and the cable routing. It's an old pic and the only thing I had on hand:
Thing is, these brakes work much better if the pads are contacting the rim long before they're tilted in this far. I found that a 2mm spacer between the pad and the brake arm usually does the trick, but finding a pad with enough thread to support this hack is fairly difficult.
In that context, the 999's made perfect sense. Though I'd argue that the finicky and PITA unthreaded brake studs on Mafac centerpulls gave them just the slightest edge, as this design eliminates pad-to-rim distance issues.
-Kurt
Oh I remember those angled pads, and the angled rims too. They were kind of a pain. They did make non angled pads too. In fact they made a bunch of different pads, some thicker than others. The brake pad hitting the rim at an angle as the pad wears is an issue on modern dual pivots too. That's why modern pads are so thin. The only brakes that are really immune from the issue are old school single pivot sidepulls.
I'm pretty sure that one of the Kool stop replacement pads will fit those holders. 4 dot probably the best if they fit. It wasn't uncommon for folks to run Mathauser or other aftermarket brake pads. I personally never found Weinmanns difficult to adjust and set up so that they were not spongy or ineffective. The Weinmann calipers have considerably less inherent flexiness than MAFAC, if you've ever compared the two side by side. Of course though, the turkey levers were always a joke. They were OK for casual slowing down, I suppose. I always felt the Weinmann brake levers were too small, but they probably fit more people than MAFAC.
BTW @merziac, I'm pretty sure you had to spring for the Continental to get those fancy Paramount brakes.... That's a whole notch up from the Varsity. It was pretty crazy that the same component was used on both the top model and an almost entry level model. That kind of thing doesn't happen anymore, does it?
Liked 4,398 Times
Problem is, those repop Weinmann 4-dot, 6-dot, and 7-dot replacement pads - far as I know - didn't come out until sometime in the last seven years, I believe - so it wasn't like you could re-use the old holder with the necessary, longer threaded mounting stud. Either that, or I was under a rock.
Oh, and for those curious:
Kool Stop International - High Performance Bicycle Brake Pads Since 1977
The Weinmann levers did come in two sizes though. And when they were designed for turkey wings, they'd sometimes be a bit shorter on top. Between all the variations, plus Dia-Compe levers, and all the aluminum and steel no-name knockoffs, one could pretty much make whatever they wanted with enough parts.
Also, one could simply file away material on the top of the lever to increase the reach. Unless, of course, the lever in question happens to be a built-in QR model.
-Kurt
A combination I'm familiar with, and still have on my '61 Paramount. There was a time when I was awash in Rigida 1320's from every old-time LBS down here. I also regret it - they're soft and they don't build well.
Exactly what I was describing. The 1320's wouldn't have made this any better - they're particularly narrow in comparison to Weinmann box-section rims. The Weinmann pads were thicker at the bottom to mate up to rims with slightly angled sides, so they happened to work better inverted.
Agreed. For a long time until the late 1970's, the only sidepull that could match this performance and not fall out of alignment all the time were Campagnolo Records.
-Kurt
-Kurt
A number of years ago I came across a whole display card full of black Weinman shoes which rather than being angled in one direction they were tapered on all four sides with an X pattern cut in them. These were a good 4 mm thicker overall than the older pads and worked pretty well fit wise on narrow rims, the problem was they didn't stop as well as the old red pads from the early 70's. The black pads felt 'greasy' in hand, they were okay for the first few stops but after they got warm they felt like someone greased the sides of the rims. They looked very similar to the pads that came new on the later Dia Compe 500 series side pulls.
One thing do notice when dealing with older C/P brakes is that they work better with smaller pads, the lesser pad surface allows for more pressure per square inch against the rims, thus they seem to stop better. The lever has to keep a mechanical advantage over the caliper for any brake to be really effective. I had a mid 70's Schwinn Voyager II that came with Shimano Tourney C/P's and narrow Araya rims. The pads were the one's with the little arrow patterns. That was by far the worst stopping bike I ever owned. The pads were noisey regardless of adjustment, and the brakes had trouble even slowing the bike on level ground let alone stopping it in the hills.
Liked 6,406 Times
